Author Topic: sealing up boat from water  (Read 1709 times)
Gardener
  • Ribble Model Boat Club
    • The Wildlife Friendly Gardener
« on: November 15, 2018, 08:02:39 pm »
do I need to seal the plywood and joints between hull and sides etc with anything other than the acrylic  paint I will use to finish off the boat ?
JimG
Re: sealing up boat from water
« Reply #1 on: November 15, 2018, 10:19:54 pm »
Best to use a sealer such as sanding sealer or brushing epoxy to seal the wood then sand to give a smooth finish. This will be easier to paint than the unsealed wood. painting straight to the wood will need a lot of coats and sanding to give a good finish.
Jim
Dundee Model Boat club
« Reply #2 on: November 16, 2018, 01:39:15 am »
Running epoxy along the joint would also add strength.
Gardener
« Reply #3 on: November 16, 2018, 08:29:48 am »
