Author Topic: Receiver aireals  (Read 1752 times)
Gardener
Receiver aireals
« on: November 24, 2018, 12:04:01 pm »
can Planet receiver aireal wires be replaced when the wires have broken ?
C-3PO
Re: Receiver aireals
« Reply #1 on: November 24, 2018, 12:27:36 pm »
Yes - no reason why not - It's just wire at the end of the day.
As I am sure you know the key is to make sure the replacement is the same physical length.
I seem to think with a bit of encouragement the receiver case will slip off and allow you to get to access the point where the wire can be unsoldered / resoldered.
If not  a clean cut up one of the sides of the plastic case will allow it's removal and some tape will hold it back together.
C-3PO
Gardener
« Reply #2 on: November 24, 2018, 12:33:04 pm »
Thanks will have to find someone who might do repair for me on 2 receivers ...
Skimmer Fan
« Reply #3 on: November 24, 2018, 01:00:23 pm »
When the soldered joint is complete put some hot glue over the joint and on the wire to stop the wire flexing.
Skimmer Fan
Gardener
« Reply #4 on: November 24, 2018, 01:11:49 pm »
Page created in 0.082 seconds with 21 queries.
