Author Topic: Pillar Drill Recommendations  (Read 10056 times)
Taranis
  • Balne Moor MBC
Re: Pillar Drill Recommendations
« Reply #25 on: April 12, 2019, 09:36:40 am »
Hi Charlie
Perhaps bolt it to a bigger sheet of ply or steel that will be easier to clamp to your bench? Or maybe with a bigger footprint it will be stable enough
ANDY
grendel
« Reply #26 on: April 12, 2019, 12:59:48 pm »
a few coach screws would do the  job if you cant drill right through, though my drill this size isnt screwed down, so can be pushed to the back of the bench when not needed
grendel
« Reply #27 on: April 12, 2019, 01:02:33 pm »
just a thought, could you place the hammer in threaded inserts into the bench top, then when needed you can bolt the drill into the inserts, and then they could also be used for your scroll saw
or maybe the furniture ones that go into a hole at right angles, drilled in from the edge of the bench
Charlie
    • My Youtube Channel
« Reply #28 on: April 12, 2019, 01:14:17 pm »
I don't want to drill holes through the bench - i don't want the drill to be permanently mounted there.
« Reply #29 on: April 12, 2019, 03:11:49 pm »
I would make a base board to fix to the tool permanently. Either from one thick board or two thin boards glued together.
Bore a hole for the bolts in line with the holes in the base of the tool, in one board
Bore corresponding larger holes to allow the head of the bolt to be recessed into the second board.
Use inverted bolts to fix the tool to the base board.
The wooden base board should be wider than the tool base on at least two sides. This can then be used as a surface for clamping to the workbench.
« Reply #30 on: April 12, 2019, 03:17:36 pm »
For a VERY simple drill press table, look no further than http://www.woodsmithtips.com/2018/06/28/drill-press-table-2/
I based my drill press table on this pattern, tweaked it to fit my smaller drill.
I wish I had made one yonks ago. I no longer use my small drill press vice.
Charlie
« Reply #31 on: April 12, 2019, 04:21:12 pm »
Thanks TT, that looks to be the best way.
« Reply #32 on: April 12, 2019, 04:32:49 pm »
It is a good way to fix lots of things down to a bench. I use it for my metalworking vice, I have also seen it used for bench grinders, polishing machines, bench sanders and more.
Page created in 0.042 seconds with 21 queries.
