Author Topic: Need some help with my submarine  (Read 4556 times)
Tugboat adam
« on: December 03, 2018, 09:27:35 pm »
Hi, I have a Shearline tube but it has some parts missing and some parts need replacing, I will try and upload photos but it might not let me, if someone can help me it will be much appreciated.
Subculture
    • Dive-in to Model submarines
Re: Need some help with my submarine
« Reply #1 on: December 03, 2018, 11:14:55 pm »
Not sure on the present status of Sheerline submarines. Chris Cloke, the proprietor used to post on here, but hasn't appeared for a while now.
Many of the parts were custom made, so if Sheerline can no longer supply, you may be faced with either adapting alternative parts, looking secondhand, or making some yourself.
Fred Ellis
« Reply #2 on: December 03, 2018, 11:16:17 pm »
Hi
 Have a word with Ron at R&R model engineering, www.rcsubs.co.uk
Fred
Subculture
« Reply #3 on: December 03, 2018, 11:38:57 pm »
Unlikely to be anything from Ron’s modules that’s transferable to a Sheerline module, very different designs.
Ron would be happy to sell you a new module I’m sure.
Would be helpful to know what parts of the cylinder are missing.
Tugboat adam
« Reply #4 on: December 04, 2018, 06:37:34 pm »
I would need a new pump, a new set of seals, and the valve system to surface the submarine and a new end plate where the pump is
Subculture
« Reply #5 on: December 05, 2018, 07:56:05 am »
The seals are often in need of replacent on older Sheerline modules. Sadly they are a custom made item, it’s a shame Sheerline didn’t use o-rings like everyone else, but I guess they had their reasons, and they work well enough when in good condition. I honk the original seals were moulded, but you could possibly cut your own from some rubber sheet with a sharp scalpel. An end cap should be easy to make for anyone with a lathe.
Pump  is a commercial item. Pinch valve is easily. made, as it’s just a cam on a servo pinching a piece of rubber hose.
Davy1
  • Association of Model Submariners
« Reply #6 on: December 05, 2018, 08:30:35 am »
Some useful ideas on pinch valves from various folk (including photo of an actual Sheerline, courtesy of "Grimreaper"!) over here:
http://www.theassociationofmodelsubmariners.com/t380-pinch-valves?highlight=pinch
http://www.theassociationofmodelsubmariners.com/t949-solenoid-valve-instead-of-pinch-valve?highlight=pinch
Good to see a Sheerline being "re-furbed". A good, reliable sub in my view.
David
Tugboat adam
« Reply #7 on: December 06, 2018, 04:48:04 pm »
Thanks and I don’t know a lot about submarines to be honest
Subculture
« Reply #8 on: December 06, 2018, 05:37:52 pm »
Are you able to post some pictures of the items that need refurbishment or replacement? What is wrong with the endcap, btw?
Tugboat adam
« Reply #9 on: December 08, 2018, 06:36:27 am »
I will try to the last time I tried to put photos up the site didn’t t let me
Klunk
« Reply #10 on: December 08, 2018, 07:38:39 am »
remember there is an upload limit. use a photo resize programme.
full time penguin
Subculture
« Reply #11 on: December 09, 2018, 06:25:28 pm »
I find photofiltre is great for general image tweaks, including reducing image size and quality to compress the bytes used. It's free to download and use. http://photofiltre.free.fr/frames_en.htm
