Author Topic: Help please - how do I make a mouse (for rigging)  (Read 1620 times)
SteveJo
« on: December 07, 2018, 11:12:07 am »
Trying to finish a Caldercraft Mortar Vessel Convulsion kit - basically no instructions for the rigging.
Plan sheet 5 of 7 shows a 'mouse' on a stay but gives no ideas how to make one - there's no mouse on the parts list
Any ideas on how to make a mouse - 'good enough' is good enough
dreadnought72
Re: Help please - how do I make a mouse (for rigging)
« Reply #1 on: December 07, 2018, 11:24:17 am »
At that scale I think I'd simply wrap thread around the stay, pva'd as you go, until you get to the shape you want. Thread the same colour as your stay rope.
Andy
SailorGreg
« Reply #2 on: December 07, 2018, 11:24:31 am »
At full scale, the mouse was often a piece of rope work that formed a big bulge, a bit like a monkey's fist, probably around a solid core of wood or other material.  For modelling, a big knot would suffice, unless you want to be particularly keen and try some fancy ropework at 1:64 scale? No, me neither!  You could try one of these.
Greg
SteveJo
« Reply #3 on: December 07, 2018, 02:02:02 pm »
Thanks for quick replies.
I don’t seem to have the skill to wrap one thread around another and get any kind of neat result.  Tried and got something close after a few goes and then cut the stay off instead of the mouse end  :((   Ho hum.
Anyway drilled, shaped and painted a little bit of dowel, it’s good enough.
Thanks again
Arrow5
« Reply #4 on: December 07, 2018, 02:54:17 pm »
Would a very small glass bead work ? Craft shops usually have a selection of sizes. Try Hobbycraft or similar.   I used hundreds to simulate rivets on my large scale HMS Invincible funnels, only to find later that said funnels were welded  >>:-(
..well can you land on this?
Steam Boat Willie
« Reply #5 on: December 07, 2018, 07:14:48 pm »
Lead shot fishing line sinkers, ready cut to go around the line.  Crimp it on with a pair of pliers and a spot of cyano.
SteveJo
« Reply #6 on: December 09, 2018, 01:12:33 pm »
Thanks - the beads were a good idea - other half had some small wooden ones that worked fine.
My dowels would have been ok but I glued them in the wrong place and couldn't be bothered to do it all again!
Next question to follow shortly in a new thread  :-)
Thanks again
edinsteve
« Reply #7 on: April 13, 2020, 09:36:14 pm »
The method I used was to first turn an egg-shaped piece from a dowel pre-drilled in a drill chuck then coat it with a piece of fabric elastoplast to give the appearance of rope covering. Then just paint it black.
“Cutty Sark”; “Bounty”;”Northlight” puffer;”Lifeboat B101”;”Fifie”
