Hi coastie
I have the build booklet for the Hellen which the ABS hull version of the Eileen.
I am also building a French version called the Julieth 4.
Same length hull, but more beam, larger hatch and the wheelhouse has a raised section in the front with skylight and two vents.
A lot better access into the hull, but it adds two pound more ballast to the boat.
Running a 3 blade brass 60mm prop, rock crawler 60 turn brush motor on a 2S (7.2 volt) Lipo battery.
Only using 50% throttle !!!!
Check out my build on this forum site.
Canabus
