Pages: 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 ... 31   Go Down
Author Topic: Andy’s, nothing like a Stevn's arctic build!  (Read 116639 times)
davejo90
Re: Andy’s, nothing like a Stevn's arctic build!
« Reply #275 on: November 06, 2020, 06:54:26 pm »
Looking great Andy  :-))
Taranis
  • Balne Moor MBC
« Reply #276 on: November 06, 2020, 07:13:14 pm »
Thank you Dave
I just found these stanchions in my stock. There are 52 so hopefully enough I will have to do a count up.
I got them for Portgarth but did them a different way and then forgot I had them.
For effect pics
I've also ordered some tube and pre formed bends to try replicating the risers to the fire monitors
ANDY
Taranis
  • Balne Moor MBC
« Reply #277 on: November 07, 2020, 12:08:58 am »
Some companion way and landing work
ANDY
« Reply #278 on: November 07, 2020, 03:12:53 pm »
I just love the little men  :-))
Taranis
  • Balne Moor MBC
« Reply #279 on: November 07, 2020, 03:35:15 pm »
Cheers Phil. I like them too and can be used to add a bit of humour when posed in a group. Also better than an out of scale coke can  %%
Today these servo travel doublers arrived from Flytron. Much simpler than the MRW offering in that it's a straight plug and play.
ANDY
Taranis
  • Balne Moor MBC
« Reply #280 on: November 07, 2020, 03:42:02 pm »
There is always a way to do that awkward solder
Tamiya fine grey primer. I use this purely because of the brass parts
First I tried satin black but decided matt was preferable
The roof is now attached with magnets and four alignment studs
ANDY
Mark T
« Reply #281 on: November 07, 2020, 03:59:37 pm »
Just gets better and better - lovely job Andy  :-))
davejo90
« Reply #282 on: November 07, 2020, 04:18:56 pm »
I know it's meant to be black but it seems such a shame to paint the brass work of the hand rails etc Andy
Taranis
  • Balne Moor MBC
« Reply #283 on: November 07, 2020, 07:18:51 pm »
Thank you Mark. This model just keeps on giving no matter what it might resemble, creative licence is a pleasure.
Dave it has just got to be but I have many hundreds of pictures of naked brass to look at  :-)
Watching TV until after strictly so might not be any update tonight  :kiss:
ANDY
Taranis
  • Balne Moor MBC
« Reply #284 on: November 07, 2020, 09:20:07 pm »
Great show tonight that was  :-)
So this is what I use for info. Most vessels have a generous amount of photo submissions on marine traffic dot com
So you can see there is a lot to add yet and lighting would be far too much to ask as it is bristling and I'd rather have a neat and tidy build than a nightmare of exposed out of scale connections. Each to their own but not for me on this model at this scale
I've started adding the proliferation of aerials using brass tube and 1mm carbon rod that will be painted white
BTW I dropped the mast this evening and it did not break  :P
ANDY
Taranis
  • Balne Moor MBC
« Reply #285 on: November 07, 2020, 10:31:42 pm »
Last one today.
Now the roof is fixed with magnets it will be pretty hard to lift off when windows are fitted,
So I've chosen to make the Graupner compass binnacle the item to grab. (lovely 1:32 item  :-)) ) if you can find them now.
This requires that it be fixed substantially rather than rely on glue so I have turned a piece of scrap dowel to 8mm as an insert to drill and tap 3mm
I allow .5mm tapping in wood and if its not secure apply CA to the tapped hole and re tap when its gone hard.
So this was drilled 2.5 and tapped 3mm
A wedge to level the base
ANDY
Taranis
  • Balne Moor MBC
« Reply #286 on: November 08, 2020, 04:37:48 pm »
It doesn't feel like I've done much today but all the little bits add up and take time.
Wiper motor box and stern light bracket fitted
Wiper boxes to front windows
nowt but a few of the many aerials
ANDY
Taranis
  • Balne Moor MBC
« Reply #287 on: November 08, 2020, 04:49:13 pm »
What I need is a source of fairly priced nav lights in a suitable size and colours etc. Many of the retail offerings are either too big or overpriced and I need LOADS  %%
Or I might have to make my own
EDIT I've just searched for clear acrylic rod and found options that will save a lot of money
ANDY
Nordlys
« Reply #288 on: November 08, 2020, 05:20:44 pm »
Andy, your always thinking outside the box!
I'm now going to look into this myself........
N
Taranis
  • Balne Moor MBC
« Reply #289 on: November 08, 2020, 05:31:59 pm »
Hi Nord
Having given it more thought I will use clear acrylic tube, probably 5mm O.D, 1mm wall and paint the inside as appropriate with Tamiya transparent paint colours.
Edit
 I can make circular tops bottoms and dividers with a hole punch in thin styrene.
I will use C section styrene for the backs where the light is directional
ANDY
Nordlys
« Reply #290 on: November 08, 2020, 05:38:44 pm »
But the tubes are available in 4 colours?
N
Taranis
  • Balne Moor MBC
« Reply #291 on: November 08, 2020, 05:45:32 pm »
No they are solid rod and I cannot find diameters small enough but I can find tube.
EDIT  too many posts with no pictures (slaps own wrist) %%
ANDY
Howard
« Reply #292 on: November 08, 2020, 05:54:05 pm »
Hi Andy,
 Like the H. I P. Plastic sheets have you looked on the HINDLEYS of SHEFFIELD I know they did them in colours. I know lights don't rock your boat but as you say there's lots of on tugs so I normally make one and then make a silicon mould and cast them in water clear resin often putting a resin colour dye in the mix and put a right coloured L E D in before it sets.
                Regards Howard.
Taranis
  • Balne Moor MBC
« Reply #293 on: November 08, 2020, 06:00:51 pm »
I task you with a pictorial guide  :-))
ANDY
Howard
« Reply #294 on: November 08, 2020, 06:06:24 pm »
Now Andy,
 that's a good idea once my hand are a little better I think I'll just do that.
         Regards Howard.
radiojoe
« Reply #295 on: November 08, 2020, 06:12:25 pm »
Hi Andy,  if it's of any interest I get all my lighting items from www.smallscalelights.co.uk  they have all manor of leds / chips / diods / fibre optics etc. may be worth a look
Joe.
Taranis
  • Balne Moor MBC
« Reply #296 on: November 08, 2020, 06:20:04 pm »
Thanks Joe but I'm not interested in illumination only the light fittings
ANDY
radiojoe
« Reply #297 on: November 08, 2020, 06:28:49 pm »
Ok Andy, I thought it was strange Andy fitting lights, I have fitted lighting on several boats but only sail in the day so in reality they never get used so these days I also don't bother with them.  :-))
Joe
Stan
« Reply #298 on: November 08, 2020, 11:17:41 pm »
Andy for one minute I thought you were going to take plunge and install a full lighting system. Maybe one day who knows.
Stan.
Taranis
  • Balne Moor MBC
« Reply #299 on: November 09, 2020, 12:20:05 pm »
Today I thought I would attempt the major ventilation units on the smoke stacks
and......repeat
ANDY
Pages: 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 ... 31   Go Up
