Author Topic: Andy’s, nothing like a Stevn's arctic build!  (Read 153655 times)
Howard
Re: Andy’s, nothing like a Stevn's arctic build!
« Reply #375 on: December 11, 2020, 04:32:10 pm »
Hi Andy,
 I love how you will always go that extra mile with your attention to detail and it being perfect is the only is the only thing you will accept it watching your build that makes me try to do things better you nothing stop learning in modelling.
              Regards Howard.
Taranis
  • Balne Moor MBC
« Reply #376 on: December 11, 2020, 04:39:15 pm »
Gallery link https://techno.smugmug.com/Stevns-Arctic/i-8Qdvwwf
Thank you Howard. The construction is styrene on wood mainly. Crew inspection was favourable {-)
ANDY
Taranis
  • Balne Moor MBC
« Reply #377 on: December 11, 2020, 11:10:15 pm »
Saturday task preview.
Unless I run out of stanchions I will complete the wheelhouse companionways
ANDY
Taranis
  • Balne Moor MBC
« Reply #378 on: December 12, 2020, 01:16:03 pm »
Billings stanchions arrived from CMB  :-))  and parts for building winches
Gallery updated, starboard complete
ANDY
Mark T
« Reply #379 on: December 12, 2020, 02:05:53 pm »
That looks superb - is the final colour white?
Taranis
  • Balne Moor MBC
« Reply #380 on: December 12, 2020, 02:26:05 pm »
Thanks yes
ANDY
marco
« Reply #381 on: December 12, 2020, 03:22:10 pm »
Bonjour ,
Very nice work andy. I like .
marco
Taranis
  • Balne Moor MBC
« Reply #382 on: December 12, 2020, 05:03:41 pm »
Thank you Marco  :-)
Port side now complete. I just need flat bar to finish the ladders.
ANDY
Taranis
  • Balne Moor MBC
« Reply #383 on: December 12, 2020, 05:20:18 pm »
Only the deck cabin front railings remaining to do.
I have used 60 Billings stanchions so far and have just received another 20 which might just be enough.
ANDY
Taranis
  • Balne Moor MBC
« Reply #384 on: December 13, 2020, 09:48:40 pm »
One of those occasional days where I was short on inspiration so didn't do much.
Started looking at more fixtures to make but kept being drawn to the davit. It is without success that I find suitable pictures to work from but I have since this photo started making it up.
EDIT I tried reading the name on the Davit to Google it but not a single picture has enough definition.
The motor and drum pictured are the uppy downy bit. I'm doing the roundy roundy bit now.
ANDY
chipchase
« Reply #385 on: December 13, 2020, 11:23:30 pm »
This is the only photo I have Andy it It might be of some help
Taranis
  • Balne Moor MBC
« Reply #386 on: December 13, 2020, 11:37:01 pm »
Thanks Brian I have that also along with many others but it's what we cannot see that evades me.
That is aboard Ocean I believe
ANDY
chipchase
« Reply #387 on: December 14, 2020, 07:45:24 am »
Yes its one from the Ocean Andy, that's the problem when the only photos you have are off the internet. I was very fortunate when I built the Maltby a friend off mine was her skipper when she was on the Tyne, I took about 300 detailed photos  :-))
Brian
Taranis
  • Balne Moor MBC
« Reply #388 on: December 14, 2020, 10:15:55 am »
Some of the pictures I have seen were confusing but I've worked out in my mind that the strange objects are counterweights on the remote cable operated control switches. So I will not be going into that level of detail.
ANDY
Taranis
  • Balne Moor MBC
« Reply #389 on: December 14, 2020, 03:06:23 pm »
I totally rebuilt the base so as to relocate the davit.
All fits suitably now
ANDY
Taranis
  • Balne Moor MBC
« Reply #390 on: December 14, 2020, 09:35:48 pm »
The davit nearing completion demanded I have a go at the RIB
ANDY
Taranis
  • Balne Moor MBC
« Reply #391 on: December 14, 2020, 10:47:18 pm »
Gallery updated.
ANDY
Taranis
  • Balne Moor MBC
« Reply #392 on: December 15, 2020, 05:44:39 pm »
Today I continued with the RIB by first turning a couple of tail ends on the lathe. Then I found a picture of a generic boat to copy the internals. Seats etc will be made and fitted after painting.
Gallery is updated. https://techno.smugmug.com/Stevns-Arctic/i-fDQ6zXM
ANDY
Taranis
  • Balne Moor MBC
« Reply #393 on: December 16, 2020, 06:23:09 pm »
Some more work on the RIB plus I'm having a go at the towage storage drum.
ANDY
Taranis
  • Balne Moor MBC
« Reply #394 on: December 17, 2020, 05:38:23 pm »
Towline storage drum winch completed bar paint.
ANDY
Taranis
  • Balne Moor MBC
« Reply #395 on: December 17, 2020, 05:41:38 pm »
Ensemble. Gallery is updated. :-))
ANDY
Taranis
  • Balne Moor MBC
« Reply #396 on: December 17, 2020, 06:12:40 pm »
More ensembles added to gallery
pic 1,129
ANDY
Howard
« Reply #397 on: December 17, 2020, 09:11:04 pm »
That's neat modelling Andy love that winch.
           Regards Howard.
Taranis
  • Balne Moor MBC
« Reply #398 on: December 17, 2020, 10:41:04 pm »
Thank you Howard. I found if you google Tug boat winches it brings up hundreds of variations. I guess making it from the minds eye is much easier than from a tech drawing.
Anyhow that is my first so I'll regard it as my apprenticeship for the mega ones yet to create.
All the winches are electric and I started with motors from cornwall models but again suffering stock shortages  :((
My friend Steve in Ireland has come to the rescue by 3D printing me some to scale and far more realistic  8)
I've just remade and finally fitted the deck cabin rear wall. The original was not good enough but I could not be bothered tearing straight into doing another so some weeks have passed and I'm happy with it this time.
I wanted to make the ventilation grilles removable to make painting easier and that has now been done satisfactorily
So this wall now has a recess that the grille fits in with a single screw
ANDY
RST
« Reply #399 on: December 17, 2020, 10:57:39 pm »
If it helps you with your davit:
Not sure what the pole at the end is but it could be an anti-two block device but looks a bit exposed
The small wire looks like to lead back to a counterweight on the winch drum, so a person in the RIB can launch without power to the davit motor, as usually required for lifeboats
The stainless block on the bridle looks like a release block. Can't release under load. So the RIB needs to be floating or stowed
...at the risk of forgetting details again (can't remember whether it's class or flag state) but depends whether that RIB is classed as a MOB boat, FRC or tender what the rules on launching are.
Anyway, looks good so far.
