Author Topic: Andy’s, nothing like a Stevn's arctic build!  (Read 154015 times)
steve mahoney
Re: Andy’s, nothing like a Stevn's arctic build!
« Reply #650 on: March 18, 2021, 07:11:24 pm »
Famous last words.  ok2
Taranis
  • Balne Moor MBC
« Reply #651 on: March 20, 2021, 06:40:04 pm »
I finally bit the bullet and paid a small fortune for nav signal lights
ANDY
Mark T
« Reply #652 on: March 20, 2021, 07:19:02 pm »
You are a master of organisation and tidiness, its a pleasure to read your posts and pictures.
Your model boat club have struck gold with your membership Andy!
Thanks for the info you post.
N.
I agree its a real pleasure to watch this build!
Taranis
  • Balne Moor MBC
« Reply #653 on: March 20, 2021, 10:29:29 pm »
Cheers buddy. I hope you get more time for yours soon  :-)
ANDY
Taranis
  • Balne Moor MBC
« Reply #654 on: April 19, 2021, 06:14:46 pm »
I'm back on the build now the weather is more consistent and dry.
The distraction of the Hoga build was a welcome break and I saved "boat loads" of time by making the paint job simple  {-)
Hoga and out.
This is the finished deck colour applied only 10 mins ago. Red primer immediately followed with matt lacquer.
ANDY
Taranis
  • Balne Moor MBC
« Reply #655 on: April 20, 2021, 02:42:45 pm »
I thought about this right from the onset and felt it was beyond me but today I thought more about it.
The actual emblem stands off the funnel side so these parts in progress will be mounted on 1mm stainless steel rods.
First I will place the parts and drill the same holes through them into the funnel. Then the rods can be fitted to the parts and flushed off with the face before painting.
ANDY
Taranis
  • Balne Moor MBC
« Reply #656 on: April 20, 2021, 05:23:37 pm »
ANDY
« Reply #657 on: April 20, 2021, 05:35:00 pm »
That is really cool, will you be putting some small LED's behind the logo ?
Taranis
  • Balne Moor MBC
« Reply #658 on: April 20, 2021, 05:44:44 pm »
Thank you Phil but I dote do lites  {-)
ANDY
Taranis
  • Balne Moor MBC
« Reply #659 on: April 20, 2021, 06:22:54 pm »
I think the break did me good  :-)
ANDY
Taranis
  • Balne Moor MBC
« Reply #660 on: April 20, 2021, 07:54:50 pm »
Starboard done bar for paint.
A worthwhile day as I think the company logos make a huge difference. Hopefully if the weather keeps improving there'll be green on the hull when it arrives.
ANDY
« Reply #661 on: April 21, 2021, 01:57:54 am »
Cracking on with that Andy!   :-))
Taranis
  • Balne Moor MBC
« Reply #662 on: April 21, 2021, 08:47:01 am »
Yes full time job Martin  :-))
I'm thinking I do not want to glue these in place as if they are ever damaged it would be too difficult to make good.
All the stainless steel rods are much longer than needed deliberately. I have in stock some minute O rings so I'm going to put 3 or 4 on each pin as spacers and push them in evenly.
EDIT  Good idea Andy  :-))  that works .... pictures
ANDY
Taranis
  • Balne Moor MBC
« Reply #663 on: April 21, 2021, 02:46:44 pm »
It seems that no one is paying attention  %%  perhaps not glaringly obvious?
Spot the mistake
ANDY
tassie48
  • bikes birds and burnups
« Reply #664 on: April 21, 2021, 03:50:37 pm »
Stb side S is facing the wrong way ?????  Is it back to front I hate to criticize any model  but great work buddy tassie48
Taranis
  • Balne Moor MBC
« Reply #665 on: April 21, 2021, 03:57:17 pm »
Very cold there Tassie but I know what you mean about hurting peoples feelings  {-)  perhaps someone spotted it before I did and didn’t want to say  :kiss:
Thank you  :-))
ANDY
Howard
« Reply #666 on: April 21, 2021, 04:52:26 pm »
Andy no one is perfect but you as near as dam it.
              Regards Howard
Taranis
  • Balne Moor MBC
« Reply #667 on: April 21, 2021, 04:55:42 pm »
 {-)  Thank you Howard.
Here is the correction. Ignore the logo and compare the wheelhouse door before and after
ANDY
RST
« Reply #668 on: April 21, 2021, 06:10:44 pm »
That's what happens when you stay off the drink.
....you start noticing and worrying about your mistakes LoL!
Obvious now you say but didn't look too bad before.  Looks good. I'd probably break something on the mast or an exhaust stack than knock the logo.
Taranis
  • Balne Moor MBC
« Reply #669 on: April 22, 2021, 07:13:06 am »
 {-)  Day six, what will I spot today   :embarrassed:
That blue is Tamiya French Blue, the same I used on my Riva Aquarama that would not set fully even though on Tamiya primer.
ANDY
Nordlys
« Reply #670 on: April 22, 2021, 05:47:16 pm »
With that very even, smooth finish you've obtained on the Hull of this model, I'm wondering how you achieve this. Is it Milliput putty that you use and how many times do you go over the Hull painting and filling in blemishes?
I'm on my third fill and paint cycle but still seeing some unevenness. I am using P38. I'm not looking for perfection as my fibre glassing stage was far from smooth!
Just wondered how much time you spent on your Hull which did look very professional.
Thank you,
Nordlys
Taranis
  • Balne Moor MBC
« Reply #671 on: April 22, 2021, 05:49:17 pm »
I didn't do anything that was planned today, mother needed help which cancelled any possibility of sailing. So I've just got some fresh primer on to end the day. A bit more fettling and I can lacquer inboard surfaces and start working towards the green
ANDY
Taranis
  • Balne Moor MBC
« Reply #672 on: April 22, 2021, 05:51:39 pm »
Thank you,
Nordlys
If you see the early pages in the blog the hull is supplied very smooth to start with.
ANDY
Nordlys
« Reply #673 on: April 22, 2021, 06:04:48 pm »
OK, thanks . Explains it all. Do you use Millipt though for uneveness?
N
Taranis
  • Balne Moor MBC
« Reply #674 on: April 22, 2021, 06:06:15 pm »
No it's too hard, I use a car body filler.
ANDY
Pages: 1 ... 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31   Go Up
