As per the first photo in the previous post, had I not reshaped it I would have had a twisted or sloping deck (port to starboard) at this stage.
Moving on as I started doing the aft deck supports it became obvious that my drives were not precisely at 90 degrees to the keel. Fortunately my installation method of using Stixall made it a relatively painless affair to completely remove and elongate one of the holes through the hull just enough to correct the error.
That behind me I began fitting deck supports.
Fordeck is only dry fitted pending supports fitting at the front. I can't fit until my Anchors arrive and I can fit the chain tubes.
I should be able to easily access the bow thruster for any repairs. Fitting this deck section as one piece entails springing the hull sides outwards.
