Author Topic: MFA large motor?  (Read 8934 times)
Rob47
MFA large motor?
« on: December 15, 2018, 09:33:48 pm »
Does anyone recall the above? I had two years ago looking for one now
They resemble fan motors all black body, about 3” dis and same for length. Three hole mounting plate. Last ones I bought cost around £20
I will finish this model
tugmad
Re: MFA large motor?
« Reply #1 on: December 15, 2018, 10:02:17 pm »
That would be a Smiths fan motor, they made them with a 1/4” or a 5/16th” shaft.
« Reply #2 on: December 15, 2018, 10:24:50 pm »
Yes Rob.....obviously an automotive heater/cooler dash type fan motor.......constant rating ...silent & super low current draw
In these days of OH&S...most Auto wreckers don't allow customers self removal....so the $ has increased ......
tony52
« Reply #3 on: December 15, 2018, 10:39:08 pm »
MFA Barracuda 12-24v. Used one to power my 46" Crash Tender after removing the i.c. power plant.
Tony
Rob47
« Reply #4 on: December 16, 2018, 04:32:27 pm »
Tony not barracuda, to small and wrong shape
Rob47
« Reply #5 on: December 16, 2018, 04:48:33 pm »
gingyer
« Reply #6 on: December 16, 2018, 05:11:37 pm »
24v smiths fan motor
Treble
« Reply #7 on: December 16, 2018, 05:15:46 pm »
Bob , Sure I have a couple in stock . Will check and let you know . If I do have them will take pics and either post ( never done it so don't know how ) , or email you . Trevor .
unbuiltnautilus
« Reply #8 on: December 16, 2018, 05:25:08 pm »
Tony
I tend to agree. We are going back before MFA Torpedo motors and Marlins, probably twenty years ago, but I think it was a Barracuda.
Rob47
« Reply #9 on: December 16, 2018, 07:11:52 pm »
Treble
« Reply #10 on: December 31, 2018, 12:56:02 pm »
Bob , Have checked stocks ans found I have 1 black motor 74mm dia x90mm long wi 6 mm dia shaft and 3 silver ones 76 mm dia x 95 mm long wi 8 mm dia shft . Have taken pic , so if you could let me know your email address, I will send it to you . Trevor  .
morley bill 1
« Reply #11 on: December 31, 2018, 03:43:03 pm »
Hi I always knew the as barracuda motors powered a large tug with one over 30 years ago brilliant motors  Bill...
Dave_S.
  • Member of Oxford Model Boat Club
« Reply #12 on: December 31, 2018, 07:18:03 pm »
I had a Veron Fast Patrol Boat powered by a Barracuda and a couple of 12v SLAs 25 or more years ago, looked good on the water.
Ruining perfectly good kits since 1969.
phillnjack3
« Reply #13 on: May 11, 2021, 12:37:36 am »
Just been messing about getting one of my boats out and then see this pop up.
My boat has a MFA Barracuda and just trying to work out best battery for it
mudway
  • Model Boat Mayhem is Great
« Reply #14 on: May 11, 2021, 03:29:58 am »
Specs are attached. I still have a couple of them.
mudway
« Reply #15 on: May 11, 2021, 03:34:19 am »
A spec sheet I received from MFA some time back.
nemesis
« Reply #16 on: May 11, 2021, 03:01:20 pm »
I have ran these motors for years, 3000rpm on 12 v, about an amp on the bench. I had two in my Arun running on 12 to 18 volts. An excellent motor. I also used them in my Ice breaker and the Northsider with a three to one reduction drive. nemesis
nemesis
« Reply #17 on: May 11, 2021, 03:05:44 pm »
Sorry I missed out the Barracuda has the little tube sticking up at one end, it has always been a speculation as to what it was for, nemesis
phillnjack3
« Reply #18 on: May 11, 2021, 03:25:54 pm »
Yes that tube is a funny thing to have on it.
what I was thinking is if this was originally a wiper motor in a car or heater fan motor it could been a water drain and a tube fitted to exit any water/damp out of the vehicle .
I might be miles out but cant see any other reason.. I am now about to look at it incase its for oiling a bearing ? (doubt it).
nemesis
« Reply #19 on: May 11, 2021, 03:39:11 pm »
The only way to Lub the bearings is to strip the motor, give you access to the felt that surrounds the sintered bush. it is surprising just how much oil it takes. You can, if you wish, drill a little hole in the dome that carries the aft bearing. nemesis
RST
« Reply #20 on: May 11, 2021, 03:45:19 pm »
It reminds me much of a car blower motor I had perhaps with a "Smith's" label I think. I think many years ago I got mine from mobile marine models.  Do t have it any more and not been able to find one since.  I've never thought for a minute MFA made their own motors but happy to be wrong.
RST
« Reply #21 on: May 11, 2021, 04:31:43 pm »
Ps that "tube" might be one of the serviceable brushes the text mentions, if so that definitely fits the description of my old blower motor. Ran nice and quiet if I recall. A good chunk of ballast also -it was pretty solid.
phillnjack3
« Reply #22 on: May 11, 2021, 06:48:51 pm »
this is what is directly in line with the tube.
just took it apart to see exactly where it lines up with.
so all I can think of is it lets you see if brushes are ok ?
it does say provision for air cooling so maybe if you want to fit a hose and a small fan to blow cold air directly intothe brush area top keep cool if running hard for long periods ?
Rob47
« Reply #23 on: May 11, 2021, 09:36:23 pm »
Wow, in answer to my question all that time ago, yes that the one
phillnjack3
« Reply #24 on: May 14, 2021, 02:26:54 pm »
what sort of speed controller would the mfa Barracuda motor need for 12 volt or for 24 volt operation.
im not realy into electric stuff, but have seen a load of cheap esc on ebay and wondering if these realy would do the job
I know the specs of the motor show 4 amp on load at 12 volt and 6 amp on load at 24 volt.
but when simply running this motor through a battery charger I find you realy have to put a lot on this motor to get to 4 and 6 amps.
I know boat props do like  a bit of power , the model will not be a heavy weight monster by a long way. say a max all up weight of around
14 to 18 pounds depending if I go 12 or 24 volts. I will probably just run something like x 50 to x55 prop so only about 2.5 to 3 inch pitch.
I am not after it being mega fast , just 10mph ish so its quick enough to get out and tow back in a broken down boat.
ive seen these and wondering if they would be ok or if these are gimics and I would be better off fitting the old manual type
speed controller from a 7.2 volt Tamiya car ?
I like the idea of the electric speed controller but only ever had one once and blew it up 20 odd years ago.
https://www.ebay.co.uk/itm/124260779562?epid=27004439599&hash=item1cee85062a:g:EG4AAOSwUjhfDqLo
https://www.ebay.co.uk/itm/153263230580?epid=12008784758&hash=item23af334e74:g:JLEAAOSwXAxb7rD7.
if these are no good for my sort of purpose is there anything recommended on the cheap
Page created in 0.621 seconds with 21 queries.
