Author Topic: Lipo Relacement  (Read 6123 times)
ojays
Lipo Relacement
« on: January 02, 2019, 08:47:23 pm »
Hoping for a little advice please.
I have only ever used NIHM's in my builds, however my latest build came out a lot heavier
than I anticipated with a NIHM on board.
The motors (x2) are basic 6-12v 360 brushed can motors, the ESC is a motroniks Viper Marine 15 plug & play.
First question. Are the motors ok to be used with lipo's?
Second Question.  Is the ESC ok to be used with the can motors and Lipo's
Lastly. What capacity Lipo is suitable if the above answers are positive.
Thanks in advance.
Gregg
Age is but a number!
Taranis
  • Balne Moor MBC
Re: Lipo Relacement
« Reply #1 on: January 02, 2019, 09:02:02 pm »
LiPo batteries are 3.7 volts nominal per cell
So a 2s Lipo is 7.4 volts
3s 11.1 volts  etc
Your ESC is only interested in voltage and not the type of battery so yes it is fine.
Capacity is explained as mah and this will dictate the weight also. More mah equals more weight! but much less than Nimh
You will need a suitable charger
Best get a feel of other peoples batteries or visit a model shop before buying
EDIT very nice model BTW  :-))
EDIT If you use for example a 3300 mah Nimh  then the corresponding size LiPo is your starting point and 2s is enough
ANDY
ojays
Re: Lipo Relacement
« Reply #2 on: January 02, 2019, 10:20:58 pm »
Many thanks for your prompt reply.
Already have a Turnigy multi charger from my flying thingy days.
Will have drive down to my local model shop and have a word.
Thanks again.
Taranis
  • Balne Moor MBC
Re: Lipo Relacement
« Reply #3 on: January 02, 2019, 10:22:55 pm »
If you have a kitchen scales I would weigh the battery you have and take the scales with you to compare
Look at these offerings
https://hobbyking.com/en_us/catalogsearch/result/?cat=&q=Turnigy+2S+LiPo
Cheap as chips  SAYS 204 grams
https://hobbyking.com/en_us/turnigy-3300mah-2s-30c-lipo-pack-xt-60.html
ANDY
ojays
Re: Lipo Relacement
« Reply #4 on: January 02, 2019, 10:25:38 pm »
Good idea, thank you.
Taranis
  • Balne Moor MBC
Re: Lipo Relacement
« Reply #5 on: January 02, 2019, 10:33:36 pm »
You will also need a voltage alarm so as not to over discharge the Lipo ( potentially fatal but there are recovery tips )
It's unlikely that your brushed ESC will have this function?
However an alarm that plugs into the balance plug is very cheap Circa £3
Typical example
https://www.amazon.co.uk/dp/B009LW48LK/ref=asc_df_B009LW48LK57822019/?tag=googshopuk-21&creative=22122&creativeASIN=B009LW48LK&linkCode=df0&hvadid=309816003291&hvpos=1o3&hvnetw=g&hvrand=2060042943773116456&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9046322&hvtargid=pla-561848290946
Notice edits to my previous post  :-))
ANDY
Terry
Re: Lipo Relacement
« Reply #6 on: January 02, 2019, 10:38:40 pm »
Your ESC is not Lipo safe, so stated on M-troniks website.
Taranis
  • Balne Moor MBC
Re: Lipo Relacement
« Reply #7 on: January 02, 2019, 10:48:03 pm »
I agree but for what reason? 2s fully charged will not exceed 12 volts so I can only assume it is due to no low voltage alarm?
ANDY
red181
Re: Lipo Relacement
« Reply #8 on: January 02, 2019, 10:50:32 pm »
I seem to remember the mtroniks esc needs to be a "tio" which can be changed from lipo to nimh. Hobby king sell very cheap lipo friendly esc's just remember, most art for planes, so no reverse function, you will need to look for that. They do have a range of boat specific escs that are water cooled
Given your model will not require speed, or rapid discharge, I would probably stay with the nimhs
Taranis
  • Balne Moor MBC
Re: Lipo Relacement
« Reply #9 on: January 02, 2019, 10:51:20 pm »
https://www.mtroniks.net/prod/Boat-Speed-Controls/tio-Marine-15.htm
This device has auto LiPo cut off which will protect the battery.
Using the alarm I posted earlier should overcome this with the other ESC
ANDY
Taranis
  • Balne Moor MBC
Re: Lipo Relacement
« Reply #10 on: January 02, 2019, 10:52:44 pm »
The OP issue is weight rather than performance
ANDY
coch y bonddu
Re: Lipo Relacement
« Reply #11 on: January 02, 2019, 10:57:03 pm »
Also have a look at  Component shop website for Lipo's Speed controller and motors and obviously chargers and a personal service as well
Andyn
Re: Lipo Relacement
« Reply #12 on: January 02, 2019, 10:58:33 pm »
A fully charged 3s lipo is 12.6 volts.
Taranis
  • Balne Moor MBC
Re: Lipo Relacement
« Reply #13 on: January 02, 2019, 10:59:51 pm »
A fully charged 12 volt lead acid is 14.4
The LiPo safe issue is the low voltage per cell cut off. One ESC has this the other does not.
Discharging a Lipo cell below 3 volts per cell will cause damage to the battery not the ESC
ANDY
Andyn
Re: Lipo Relacement
« Reply #14 on: January 02, 2019, 11:04:42 pm »
 %)  yes, but a fully charged 3s lipo is still over 12 volts
Another thing to factor in when considering your lipo purchase not mentioned previously is C rating - the multiplier of how much current a battery can give in relation to it's own capacity. An example being that a 1000mah lipo at 10C will give you a max discharge of 10 amps. Also, generally speaking a higher C rated battery will be larger that an equivalent capacity, lower c battery.
Taranis
  • Balne Moor MBC
Re: Lipo Relacement
« Reply #15 on: January 02, 2019, 11:09:05 pm »
That is still less than 14.4 and I recommended 2s to replace the 7.4volt Nimh
C rating is not really relevant with such a small brushed motor
ANDY
Andyn
Re: Lipo Relacement
« Reply #16 on: January 02, 2019, 11:16:20 pm »
Unsure how 14.4 came into this?
Like I say, higher C batteries are generally larger, so it may pay to look for a lower c battery to save weight whilst maintaining capacity, as long as max current draws are observed.
Taranis
  • Balne Moor MBC
Re: Lipo Relacement
« Reply #17 on: January 02, 2019, 11:18:39 pm »
Sorry but I thought you were implying that a fully charged 3s battery voltage was too high
The ESC is suitable for 12 volt lead acid that will be 14.4 end of charge so a 3s will be less
However the original battery is nowhere near 12 volts so not an issue
This was my recommendation
Specs:
Minimum Capacity: 3300mAhConfiguration: 2S1P / 7.4v / 2CellConstant Discharge: 30CPeak Discharge (10sec): 40CPack Weight: 204gPack Size: 134 x 43 x 15mmCharge Plug: JST-XHDischarge plug: XT60
ANDY
chas
Re: Lipo Relacement
« Reply #18 on: January 03, 2019, 12:04:56 am »
It's worth noting that 2 MFA 360 motors will only be drawing circa 1.5 amps. So a small ah lipo, which will also be very light will give a lot of time on the water. The standard viper is fine, with a low voltage warning to protect the batteries.
 In such a small craft I would use 2 s lipo. No need to worry about higher voltages, it's not a high performance model.
Lovely build, I would be proud of that.
cos918
Re: Lipo Relacement
« Reply #19 on: January 03, 2019, 07:04:52 am »
Hi
In my ferry I use both a 2s and a 3s lipo . I have standered mtronics esc and they are fine. It just the low voltage you need to watch out for. Like other have post get a cheap little low voltage alarm and plug that in to your lipo when you sail.
Best place for lipos with the best prices and selection by far is hobby king.There turnegy brand is very good Not when ordering from HK make SURE you select your goods only from the UK or EU warehouse . If you dont shipping is more and there could be import tax.
Finnal note. I know you said you have a charger. Just make sure its a good one and not a fake .
Re: Lipo Relacement
« Reply #20 on: January 03, 2019, 10:27:13 am »
While agreeing with everything that has been said about LiPo batteries, in a case like this a set of NiMH AAA cells of around 2000-2500 mAH of the wanted voltage will do a very adequate job.  Should weigh a lot less that the sub-C cells shown.  Just sayin'.
ojays
Re: Lipo Relacement
« Reply #21 on: January 03, 2019, 11:23:39 am »
WOW, never expected such a response.
Thanks for all the input, given me some food for thought.
I hadn't realised just how heavy it would end up, but as I hadn't followed the plans and
instructions I should have know it would end very low in the water. Too low for my liking.
I know it will be a fair weather sailer, but have others in the pipe line for normal
days.
Thanks for the positive comments on the build, it has been one of the most pleasant
projects I have done in a long time.
I have enjoyed it much more than just assembling/converting plastic kits, which is my norm.
ojays
Re: Lipo Relacement
« Reply #22 on: January 03, 2019, 03:32:47 pm »
I have been using this charger for years, and has been loaned to a friend for his lipo's with no problem.
Taranis
  • Balne Moor MBC
Re: Lipo Relacement
« Reply #23 on: January 03, 2019, 06:07:42 pm »
110 grams/ less than 4 ounce but less capacity
https://hobbyking.com/en_us/turnigy-1800mah-2s-20c-lipo-pack.html
ANDY
JimG
Re: Lipo Relacement
« Reply #24 on: January 03, 2019, 09:04:18 pm »
High capacity AAA NiMh cells are a poor choice to provide power to motors. They have a high internal resistance so are incapable of providing higher currents without a high voltage drop. They are designed to power electronics with a low current draw.
Jim
Dundee Model Boat club
