Author Topic: Antislip paint for decks  (Read 1049 times)
markrider
« on: January 09, 2019, 04:54:34 PM »
Hello all.
So how do people make antislip paint
For decks ?
Mark
nemesis
Re: Antislip paint for decks
« Reply #1 on: January 09, 2019, 05:10:08 PM »
I used sparking plug cleaner grit, sprinkled onto the wet paint. nemesis
boat captain
« Reply #2 on: January 09, 2019, 05:21:14 PM »
Spray deck with Valspar texture paint B&Q then thin you colour down a bit and give two coats of it.
Joe
Liverpool MBC Committee Member
Chairman the Model Boat Convention
Chairman Merseyside Model Boat Association
markrider
« Reply #3 on: January 09, 2019, 05:24:55 PM »
Great thanks very much for quick replies I'll give it a go
john44
« Reply #4 on: January 09, 2019, 09:02:20 PM »
Hi ,I use a product called rustolium textured paint also from B&Q.
swiftdoc
« Reply #5 on: January 09, 2019, 09:05:59 PM »
Halfords sell textured paint in grey as well. I use that adding a layer of varnish later. I was adviced to do so by 17-09 and it works great. :-))
https://www.halfords.com/motoring/paints-body-repair/specialist-decorative-paints/halfords-textured-paint-grey-300ml?_br_psugg_q=textured+paint
markrider
« Reply #6 on: January 09, 2019, 09:19:53 PM »
Thanks all.lots of ideas to try
Much appreciated
Mark
Taranis
  • Kirklees MBC/ Balne Moor MBC
« Reply #7 on: January 09, 2019, 11:45:16 PM »
Another +1 for Halfords texture paint. I used grey but overpainted with my own finish colour
I'll be using the same on the deck
Umi_Ryuzuki
    • Models and Miniatures
« Reply #8 on: January 10, 2019, 03:21:52 AM »
Rustoleum, if it is available, Fine textured spray paint.
stuart22
« Reply #9 on: January 10, 2019, 05:18:28 PM »
Hi it depends on what scale you want, the spray paints are good if big scale I used aluminium Oxide powder mixed in paint and dabbed it on to the service on my 1/16th Severn worked a treat.
RST
« Reply #10 on: January 10, 2019, 09:41:11 PM »
Not sure if this idea helps but I used to do an awful lot of modifying on cars (was a bit of a boy racer) but I used to do it tastefully and make it look like an OEM type finish.  When I wanted to mimic mottled dashboard plastics I used to use stone chip aerosols for the texture.  In actual fact (spefically) Hammerite stone chip aerosols used to produce a wonderful fine texture which might do very well as anti-slip texture for decks.  I also used to use this as a lazy surface filler primer because when you cut it back it worked much better than proprietary filler primers!  The Hammerite cans work great on polystyrene sheets (not EPS obviously!), GRP, wood, metals etc.  Might be worth considering?  Alternatively, for models I've seen me cut wet and dry paper into the required size and bond it down before painting over.
gerard
« Reply #11 on: January 10, 2019, 10:37:47 PM »
I agree with John44. Used Rustolium on my 1/16 Severn on the anti slip areas. Worked a treat. Gerard
markrider
« Reply #12 on: January 10, 2019, 10:51:57 PM »
Thanks for the replys chaps
What rustolium is it you use
Umi_Ryuzuki
« Reply #13 on: January 11, 2019, 06:12:56 AM »
