Hi Dillinger 04,
I have also built a 55 cm tugboat and can tell you that being so small it can't carry much weight, so you will be restricted in the choice of steam plants. My steam plant weighed under 1 kg if I remember correctly.
Most copper boilers available on the market will be too heavy for such a small hull (accounting also for the weight of the engine and ancillaries). Ask Nigel @ Pendle boilers if he could build you a boiler not exceeding 500 g.
The Wilesco 305 boiler isn't such a bad idea for you, as it is built of thin brass and weights much less than a similar sized copper boiler. However, you should choose the engine you want to power with it carefully. It shouldn't be too big, because the boiler, being a simple centre flue with no water tubes design, doesn't produce a lot of steam. I would say a 2-3 cc engine should suffice.
The best advice I was given and which I happily give on to others is to build the steam plant first and the hull after, knowing the weight it must be able to carry.
That way you will be spared a lot of headaches. I know of several steamboat projects which were stopped due to the steam plant turning out too heavy.
