Author Topic: Morse Code Simulator?  (Read 1592 times)
plastic
  • Bobbing Along!
« on: January 28, 2019, 06:59:59 pm »
I'm building a destroyer and I'm looking at adding sound to it.
I can get an ASDIC and klaxon sound generators but is there such a thing as a Morse Code simulator that can give bursts of Morse-like sounds that I can link to a signal LED on the bridge too?
I'm thinking of maybe using one of those birthday card sound effects PCBs with a fake Morse signal recorded into it or maybe a couple of 555 chips into a mixer to give a semi-random bit stream into a Peizo sounder.
Low cost and simple is good.
Any ideas?
C-3PO
Re: Morse Code Simulator?
« Reply #1 on: January 28, 2019, 07:27:24 pm »
Yes is the simple answer...
https://www.youtube.com/watch?v=8_SiZkciRsA&feature=youtu.be
Forget the size of the board in the video - it can be made to work on a much smaller board for the grand cost of about £3-£5
The message being sent in the video is the emergency message sent by the Titanic – CQD CQD CQD CQD CQD CQD DE MGY MGY MGY MGY MGY MGY position 41.44 N. 50.24 W
Can be made to do what you want as well as the speed / tone amended - the video is approx 12wpm
C-3PO
plastic
  • Bobbing Along!
« Reply #2 on: January 28, 2019, 07:32:19 pm »
That might be useful - I've never used one of these - how much does it cost to get up & going? (leads, software, pcb etc)
C-3PO
« Reply #3 on: January 28, 2019, 07:38:02 pm »
Not a lot (£3-£7 including peizo sounder) - I'll post details asap - keeping the chancellor happy right now doing my VAT return!
C-3PO
Hellboy Paul
« Reply #4 on: January 28, 2019, 07:38:27 pm »
If morse code could be heard that far away from the ship, I don't think I would want to be in that radio room when sending or receiving a message.... It would be louder than a Motorhead concert... %% %% %%
plastic
  • Bobbing Along!
« Reply #5 on: January 28, 2019, 07:41:13 pm »
I know - it's just for novelty value. I think the ASDIC would kill the sub with sonic shock-waves too.
DaveM
  • Why on earth do I do this?
plastic
  • Bobbing Along!
« Reply #8 on: January 29, 2019, 10:14:39 am »
An advantage of the card module is that you can build an actual message to record using something like Audacity.  Cut and paste generated tones into a stream, record the result to the card.
plastic
  • Bobbing Along!
« Reply #9 on: January 29, 2019, 10:22:59 am »
The card modules are about 60p each in quantities of 10 or more and can record between 10 and 120 seconds each. I was thinking about just ripping chunks from The Cruel Sea or similar on Youtube and recording them into the chips. I can have sirens, klaxons, ASDIC and morse all selectable then. I've got a 5-channel radio set for it so there's 3 spare channels muck about with.
I could trigger them from a receiver switch or like the old days with a servo triggering microswitches. Cheap and bodgy but probably effective.
ivorthediver
  • Ivor the Diver
  • What ever Floats YOUR boat
« Reply #10 on: November 25, 2019, 07:26:47 pm »
Any ideas?
Simple answer there , buy the Noisything11 with the Warship suite downloaded or speak nicely to component -shop and ask them what they can add to that .....I have one with the Destroyer Whoop , asdic , morse Guns , and eight others , and works brilliantly on a 3" speaker up front in HMS MANXMAN  %)
grasshopper
    • A1 Hobbies Ltd.
« Reply #11 on: November 25, 2019, 08:48:36 pm »
I supposr you could get a Bluetooth speaker like I was just bought.....good sound and reasonable volume.
https://shopora.co.uk/hi-fi/264-bluetooth-speaker-anker-soundcore-mini-super-portable-speaker-with-15-hour-playtime-20-meter-bluetooth-range.html
Connect it to your smart  phone and control it from the bank..
« Reply #12 on: November 25, 2019, 10:34:29 pm »
So Malcolm says......"Cut and paste generated tones into a stream" .....
.....[and they say the English language is logical] %) .......I am sorry Malcolm, didn't realise tones could swim [after being cut & pasted]
« Reply #13 on: November 27, 2019, 09:23:17 am »
With a sound file editor like the free audacity, you can do cutting and pasting of selected bits of what is on screen such as bursts of tones and silent bits.  These can then be pasted into your new file and exported as an MP3 file to be played as required.  Handily, audacity (free) has, amongst its other bits n pieces, a tone generator, which allows creation of dots, dashes and spaces which can be assembled into a message.  The avantage is that you get to pck the tone and, depending on how persistent you are, the actual content of the message.  Anf if you get it wrong, it can be edited.
C-3PO
« Reply #14 on: November 27, 2019, 09:30:54 am »
Tone for morse is normally around the 600 mark but is down to personal preferrence - the link below gives are very elegant solution and downloaded .wav file
Check out this link  - http://www.meridianoutpost.com/resources/etools/calculators/calculator-morse-code.php
C-3PO
