Thanks for that. Being a bit gormless about motors I'd need the name and model number of a geared down 5 pole 545 low drain motor. I don't even know what numbers like 540 and 545 refer to! An earlier post from a bloke in Tasmania (what a forum!) suggested a Rock Crawler 55.
There was a thread on here a while back about motors and their numbers, but -
540 - a 3 pole motor with a can 54mm long, good for fairly fast boats weighing a few pounds.
545 - 54mm long can but with 5 poles, good for larger, slower hulls needing to turn a larger prop more slowly, but with more torque.
While NiMH are perfectly good in this application, SLA are also worthy contenders, low current and heavy weight being what they are about.
Some 540 motors come with a suffix number denoting that they are wound to give different results.
Motors with cans this size also appear as "600" series motors because some manufacturers like to change things. Things like number of poles and the arrangement of the wire wound on them, determine what they are good for. A fast revving 3 pole motor driving a prop that is too big will be forced into an almost stalled condition, where it will not produce much drive, but will pull way too much current and make a lot of heat. I have seen an ill-chosen motor melt the solder off its tags, I don't know what the motor actually was, it had also burnt the label.
