Author Topic: Taranis Qx7 Receiver  (Read 5796 times)
Corposant
« on: February 05, 2019, 07:21:22 pm »
I have purchased a Taranis Qx7 Tx (EU version) and now find myself looking for a receiver to suit my needs (without costing the earth!). I had not anticipated an array of 44 to sort through!. I need 8 PWM channels. Extra bells and whistles are no problem but obviously they push the price up.
Can anyone recommend a modestly priced Rx for a model boat that is compatible with the EU version of the Qx7?
timg
Re: Taranis Qx7 Receiver
« Reply #1 on: February 05, 2019, 07:36:33 pm »
Hi Mike
Have a look on here
https://www.t9hobbysport.com
Maybe give them a call if your not sure ,
No connection just a happy customer
Spud
timg
« Reply #2 on: February 05, 2019, 07:38:17 pm »
timg
« Reply #3 on: February 05, 2019, 07:39:12 pm »
Corposant
« Reply #4 on: February 05, 2019, 08:15:24 pm »
Many thanks Spud!
The X8R was the one that looked promising to me. I couldn't be sure it was compatible with the QX7 (although the Tx manual implied that it was). T9hobbysport make it clear!
I'll contact them Thursday (I'm out all day tomorrow).
Taranis
  • Balne Moor MBC
« Reply #5 on: February 05, 2019, 09:02:06 pm »
They are local to me and their prices are cheaper than eBay china
First class service :-))
I'm using 2 with my 9XE
I made a little structure to support the antenna. No idea if its of benefit but works so far
ANDY
Corposant
« Reply #6 on: February 05, 2019, 09:34:09 pm »
Hi Andy,
That provides goodly cofirmatory evidence! Thanks too for the picture of your handiwork - most impressive!
Taranis
  • Balne Moor MBC
« Reply #7 on: February 05, 2019, 09:45:33 pm »
Thank you Mike
Frsky is such great kit and cheaper than spektrum as well as punching well above it’s price point
ANDY
JimG
« Reply #8 on: February 05, 2019, 10:06:26 pm »
To be most effective the aerials should be at 90 degrees to each other. One from each receiver vertical and one horizontal. You could set them at 45 degrees to give a V with 90 degrees between the arms.
Jim
Dundee Model Boat club
Taranis
  • Balne Moor MBC
« Reply #9 on: February 05, 2019, 10:17:31 pm »
Jim
I’ve been there too Jim  :-))  but after lots of reading and advice from others I concluded that for boats as opposed to aircraft the set up I have is most beneficial
A whole subject in itself but mine works fine vertical/vertical  at 90 degrees to each other
Abandoned
ANDY
timg
« Reply #10 on: February 05, 2019, 10:21:57 pm »
Very impressive Andy ,
Have you been to the shop ? , do they have the transmitters out on display?, I've only used their mail order service.
Spud
Taranis
  • Balne Moor MBC
« Reply #11 on: February 05, 2019, 11:28:31 pm »
Hi Spud
Yes I’ve been to their sales counter but only a few on display as they are predominantly mail order
I bought my transmitter from hobby king a little cheaper before I discovered T9 otherwise I would have bought there
ANDY
Andyn
« Reply #12 on: February 06, 2019, 01:44:30 am »
Be careful now as you have a EU version when buying receivers, try to buy those marked EU LBT, or aternatively re flash your tx to global. My Taranis is running 2.1 opentx in global, and I found out about the EU flash when I bought an EU receiver and couldn't bind it...
Don't know about the QX7, but flashing an Rx on the Taranis is a pain in the backside
Corposant
« Reply #13 on: February 06, 2019, 10:52:15 pm »
Thanks guys, for all your very helpful replies.  :-)
Taranis
  • Balne Moor MBC
« Reply #14 on: February 06, 2019, 10:56:54 pm »
Just seen the text in my last post  %%  don't know why that happened  :embarrassed:  HUGE
ANDY
rd
« Reply #15 on: February 23, 2019, 03:47:37 pm »
I am currently looking at buying 1 of these units. Im building my 1st rc beam trawler, i wasm hoping to have 4 separately controlled winches, would the 4 3-way switches at the top be able to perform this? Totally new to RC and am struggling a bit with the electronic side of things.
Thanks, Ryan.
Andyn
« Reply #16 on: February 23, 2019, 08:04:26 pm »
Thanks, Ryan.
Yes they would, though you'd need a way of controlling the end stops of your winches.
rd
« Reply #17 on: February 24, 2019, 05:51:43 am »
Sorry I might be being dumb here, will it not just be a case of flicking the switches back to the central position to stop the winches? Am totally new to this and all help is greatly appreciated.
JimG
« Reply #18 on: February 24, 2019, 09:26:27 am »
You can use the three position switches to control a servo with two microswitches to give forward and reverse on the winch motor. However when the winch reaches the end point it will continue to turn until you notice and switch it off. If you are winching in this could lead to the line breaking or damage to where it is connected to. The winch needs an endstop which can be a microswitch to stop the motor. Ideally two switches are needed, one for each end of the winch travel. The complication is to wire the switches up so that they only stop the motor turning in one direction.
Jim
rd
« Reply #19 on: February 24, 2019, 10:36:30 am »
Ok, thanks for your reply, I think I understand what you mean. I was going to use rc crawler winches as they will all be hidden away below decks most ofwhich come with controllers, so would I ditch those? Thanks again for helping.
Andyn
« Reply #20 on: February 24, 2019, 06:17:07 pm »
If you use a crawler winch with an rc programmer that's all you need. Bear in mind there may still be a small amount of setup left to do to get the winch to stop where you want it to.
rd
« Reply #21 on: February 25, 2019, 09:39:24 pm »
Excellent, thanks for everyone's help and sorry for unintentionally hijacking another post.  i will go ahead and purchase the tx now I'm confident it's suitable.
