Author Topic: Suitable glue/resin for securing drive to a hull  (Read 2972 times)
Leaky
« on: February 11, 2019, 06:55:19 am »
I have to mount 2 jet drives into a bad formed styrene hull and need to pour an amount of glue or resin around its base to secure it into the hull.
I've made a frame around its mounting area it's only about 5 mm deep can you recommend a suitable resin i can mix which can be poured in but won't attack the styrene hull.
I've got a few tubes of stabilit if that's suitable?
badly raised and ill mannered.
gingyer
Re: Suitable glue/resin for securing drive to a hull
« Reply #1 on: February 11, 2019, 08:05:03 am »
I used z poxy to fix mine into a abs hull
Leaky
« Reply #2 on: February 13, 2019, 06:56:23 am »
I'm having trouble with my auto correct i meant vac formed its a bit thin in places does Z poxy generate heat?
Page created in 0.288 seconds with 17 queries.
