Hi
At a point on my Tamar Lifeboat to glue the rubber Fendering around the hull.
I have tried a sample lenght using Evostik Impact, but the flat side of the D section has a slight convex radius on it and ends up lifting on edges. I was only applying glue to the rubber. The can of glue l brought last summer and doesn't seem to spread well. Also tried super glue and wasn't impressed with the result. Has anyone had good results from a particular glue as the Evostik tends to pull away from the rubber surface as l try to spread it. Thanks for any replies.
Alan
