Author Topic: Chrome portholes  (Read 634 times)
frog32
Chrome portholes
« on: February 27, 2019, 08:03:12 PM »
Hi
Can anyone direct me to where I can obtain a few Chrome flange portholes approx 15-18mm outside diameter. They could be chrome on plastic as fitted, or chrome on brass.
I am restoring a 1960s Graupner Condor 1 boat and sadly damaged a couple of the bow portholes.
I have contacted most of the obvious suppliers but with no luck.
So would appreciate suggestions of any other places I could contact, or please look in your bits and pieces box to see if you have any lurking within.  Thanks.
Regards Roger.
slinger
Re: Chrome portholes
« Reply #1 on: February 28, 2019, 07:18:47 PM »
You could always use plastic or metal ones and spray them with chrome paint which you can get in rattle cans from I think Halfords. I have done this myself and got a good finish?
Graham
frog32
« Reply #2 on: February 28, 2019, 07:42:30 PM »
Hi Graham
I did think of that but my results just looked like silver paint. What make of chrome spray did you use?
Another thought is to buy some brass portholes and see if I can get them nickel plated.
Probably will be very expensive.
Regards Roger.
gerritv
  • Restoring G07 1:72 model
« Reply #3 on: February 28, 2019, 08:36:16 PM »
Other options are:
- Bare Metal Foil, see your local plastic kit supplier
- Alclad paints, this goes on very very nicely. Air brush works great with this paint.
I have used both of the above with good effect.
A possibly useful thread for info on attaching aluminum foil to plastic:  http://cs.finescale.com/fsm/tools_techniques_and_reference_materials/f/13/t/140415.aspx
Gerrit
HMCS Athabaskan G07 1:72
ray123
  • mary marie cygnus gm33
« Reply #4 on: February 28, 2019, 08:42:37 PM »
hi frog 32 i have used this chrome pen it does come in different size tips 1mm 2mm 4mm    it really is  shiny chrome finish!  so if you find plastic or brass port holes  this will give you the finish you need
https://www.ebay.co.uk/itm/Molotow-Liquid-Chrome-Pump-Marker-Pen-4mm-Nib/253600362094?epid=2020278634&hash=item3b0bc26e6e:g:2swAAO
ukmike
« Reply #5 on: February 28, 2019, 10:19:31 PM »
How many are you looking for?
plastic
  • Bobbing Along!
« Reply #6 on: March 01, 2019, 06:35:00 AM »
What about chrome sink overflows?
grendel
« Reply #7 on: March 01, 2019, 07:30:47 AM »
+1 on the chrome pens- really good chrome finish, and if it does wear, you can just go over it.
frog32
« Reply #8 on: March 01, 2019, 08:36:51 AM »
Hi All
Many thanks for all your suggestions.
UKmike. I need six portholes if I have to replace all of them, but I have managed to save three of the originals.
Gerrit. I will look into the foil laying process but I think it will be a bit fiddly on small portholes.
To the rest of you who have suggested the chrome pen, that looks the way forward if I canít find them already chromed.
Thanks again Roger.
