May I propose something a bit controversial controversial and a very po-poo'd old fashioned approach these days but I did it twice myself last week as I don't really build kits or stick to plans much myself...
...So you know what the recommended set-up is. If you have no batteries at the moment, you can still grab some AA sized dry cells which will be close-enough to NiMH cells. Cellotape them together into a configuration and try placing them about the hull. If ou want to go LiPo, then google the specs, dimensions and weights and find something the same and try fitting.
Have you put the hull in the bath yet to see how it floats? I'm working away from home, realised I only have a 1/2" deep shower cubicle (crazy -never seen that outside the UK, no wonder I mop the floor each time!) so I went and bought a cheap plastic box as a test tank. I had some batteries, some other bits to represent other weights so I could move things around and see how my model floated. I think I found a glass jar of herbs which was close enough for something -you get the idea!!!
I do not think you can do everything by prescription from the internet. If you ask 10 people you will get 10 different answers, and almost no answers which suit you in particular, unless you want the security of doing what someone else always does, in which case there's minimal learning curve.
By the way, looks a fantastic job on the hull so far! Very envious!!!!! Particularly varnishing which I detest.
