Author Topic: Wiring  (Read 3803 times)
jaffy012
Wiring
« on: March 22, 2019, 12:54:46 am »
hi everyone can i please ask for help, i am building jonny harbour tug by aeronaut and would like to know how to wire the twin  720 navy motors into my 860 quick run esc it does not show in instuctions but does say it can do 2 motors, any help would be fine, also tamiya whit putty is this ok to use in filling gaps etc as its mainly plastic and fibre glass kit,  colin :-)
canabus
Re: Wiring
« Reply #1 on: March 22, 2019, 08:32:17 am »
HI jaffy012
The two motor leads from the ESC go straight to one(get that one running in the right direction).
Depower the setup.
Add two wires across to the other motor but cross over the leads to get the motor turning in the right direction.
Repower the setup and test.
Canabus
RST
Re: Wiring
« Reply #2 on: March 22, 2019, 09:20:30 am »
Is that right canabus? I think I bought one of these esc's last month because it can drive two motors on separate outputs provided (though there's no mixer). I'm not home to check but from memory fiddling with mine the other night the black and red leads need to be fitted with your own battery connector. There is a pair of yellow and pair of blue mototor leads and usual female bullets with silicone shrouds. One yellow and one blue go to each motor. I don't know if they're paired or if it makes any difference. Remember to set the dip switches to "boat" and Li-Po or Ni-Mh also.
I'm assuming normal good practice of fitting a fuse on each motor rather than (or in addition) on the battery side, but not sure if the ESC already has dual protection already in there.
Is that right? Otherwise for a normal single motor ESC it's as cannabus depicts.
Re: Wiring
« Reply #3 on: March 22, 2019, 10:16:01 am »
Assuming that it is one of these - http://www.hobbywing.com/goods.php?id=357 - what RST said.
A sort of wiring drawing for it appears at http://www.hobbywing.com/goods.php?id=357 toward the bottom of the page.
jaffy012
Re: Wiring
« Reply #4 on: March 22, 2019, 11:29:21 pm »
hi everyone many thanks for help, now i understand,
RST
Re: Wiring
« Reply #5 on: March 23, 2019, 07:22:16 pm »
Yea, no problem.  I just looked at the end of mine and thankfully, all the power cables are labeled so M1 Blue and M1 yellow got to one motor, etc.  Let us know how you get on with it.  I only grabbed one when I was in the local model shop last time because I thought it was neat having the 2 outputs, and at £30 it was well worth a try at some point.  I've never run mine yet though.
Richard
jaffy012
Re: Wiring
« Reply #6 on: March 23, 2019, 11:35:29 pm »
many thanks richard :-))   colin
jaffy012
Re: Wiring
« Reply #7 on: March 26, 2019, 08:26:42 am »
hi me again does anyone know where i can get 1 3/2 winches ffrom with out spending a fortune :-))
Re: Wiring
« Reply #8 on: March 26, 2019, 10:09:36 am »
Not too sure what that means.  There are quite a few winch options  - turns, drum diameter, size and pull power on the internet.
Re: Wiring
« Reply #9 on: March 26, 2019, 10:10:16 am »
Mobile Marine Models do a selection of 1/32 Tug winches and windlasses.
Onetenor
Re: Wiring
« Reply #10 on: March 30, 2019, 05:29:37 am »
Instead of crossed wires turn the motor bodily 180 degs this changes contact position a keeps things tidy. Simples.
jaffy012
Re: Wiring
« Reply #11 on: April 17, 2019, 04:25:45 am »
can anyone please point me in the right direction for winch ropes,  colin
tonyH
Re: Wiring
« Reply #12 on: April 17, 2019, 04:47:31 pm »
Wire winch rope can be anything from motorcycle brake cable to stranded jewellery wire plus added grease :-))
Page created in 0.039 seconds with 21 queries.
