Author Topic: tvr1a servo connection  (Read 2544 times)
Bernhard
« on: March 29, 2019, 05:09:25 pm »
hi when im wenting for a bear set from usa i try to do this setup,,works real well
rhavrane
  • Steam passionate collector
Re: tvr1a servo connection
« Reply #1 on: March 29, 2019, 06:10:31 pm »
Bonjour Bernhard,
My TVR1A, not yet installed in a hull, has the standard reverse rod and the course needed to go forward and reverse is very long.
I think you lready planned to check if your solution, with about 90° of servo latitude offers the appropriate long movement before finalizing your istallation  ok2
Raphaël
ooyah/2
« Reply #2 on: March 29, 2019, 08:37:08 pm »
Bonjour Bernhard,
Raphael,
What you are not seeing is that Bernhard has taken the reverse bar thro' the square block and added another post to carry the reversing fork.
Yes the Bar as standard moves a great distance
 let us say the arc is 90deg  with an arm about 40 mm Bernhard's reverse lever is only about 15 mm long so it has less distance to travel and it does work.
Here is another example of removing the long reverse lever arm and making a short one on the other side, this does work as I have made it and I can assure that all is O.K. for forward and reverse. I have made a shorter bar and dispensed with the original bar as shown on the pics.
Pic No1 the original F/R lever is gone.
`George.
Jerry C
« Reply #3 on: March 29, 2019, 11:14:34 pm »
These two screenshots show another approach to the problem. Still working perfectly after 7 years use. Same mini servo too.
Jerry.
Bernhard
« Reply #4 on: June 25, 2019, 03:20:05 pm »
https://youtu.be/2-CyH3Ua7Fs         in work
Page created in 0.312 seconds with 17 queries.
