Pages: 1 [2] 3 4 5   Go Down
Author Topic: Pilgrim's Pride 1620 Mayflower Static Build  (Read 35246 times)
dlancast
Re: Pilgrim's Pride 1620 Mayflower Static Build
« Reply #25 on: May 18, 2019, 04:45:13 am »
Forecastle waterways, bulwarks and stanchions installed and stained.  Maindeck in progress same.  Dennis
dlancast
« Reply #26 on: May 18, 2019, 04:45:45 am »
more.
dlancast
« Reply #27 on: May 18, 2019, 04:51:09 am »
Stern windows glazed and installed.  Dennis
Mark T
« Reply #28 on: May 18, 2019, 09:29:30 am »
Thats looking really nice and there's some pretty tricky woodwork going on too  :-))
dlancast
« Reply #29 on: May 20, 2019, 05:51:05 pm »
Bluwark stanchions are installed and to be stained.  Ready for second layer of upper hull planking.  Dennis
dlancast
« Reply #30 on: May 29, 2019, 02:40:49 am »
Second layer of hull planking from the water line up.  Drilled out hundreds of tiny holes to simulate tree nails on planks.  Stained all topside a light oak.  Varnished with satin poly, one coat to seal.  Installed Wales and painted black.  Painted waterline and below, white (they used Tallow, which was a yellow/white.  I like the contrast of white/white flat.  Next will come various moldings on hull above cannon ports. Color will be brought into those moldings with red, green, white and black.  She is coming along well.  Dennis
dlancast
« Reply #31 on: May 29, 2019, 02:41:16 am »
more.
dlancast
« Reply #32 on: May 29, 2019, 02:41:42 am »
more.
dlancast
« Reply #33 on: May 29, 2019, 02:42:05 am »
more.
« Reply #34 on: May 29, 2019, 10:51:52 am »
absolute beauty O0
dlancast
« Reply #35 on: May 29, 2019, 04:27:13 pm »
thank you sir,  your HMS Victory Tug, is that a paper model?  I have a battleship model that is paper, I just started before this model I'm working on. That paper model looks very daunting, what have been your experiences? Can you give any advice?  Tks, Dennis
« Reply #36 on: May 29, 2019, 05:54:00 pm »
EEERRR, sorry  - you missed the comma  {-) , its HMS Victory and a vacuum hull of a tug, Victory is partially built using all the parts of the Airfix Kit but until I get sufficient mojo to carry on she is currently in dry dock - no internal decks fitted but the main gun deck is set with crew and guns ready to go in.
dlancast
« Reply #37 on: May 31, 2019, 04:06:19 am »
Color is coming on with various hull moldings, rather striking.. though I trust the color accuracy, probably was not that bright.  I will be toning it down some with a overcoat of satin varnish to seal.  Dennis
dlancast
« Reply #38 on: June 09, 2019, 05:56:28 am »
The Beakhead has been completed and installed.  Moving on to quarter deck area.  Dennis
dlancast
« Reply #39 on: June 09, 2019, 05:56:54 am »
more.
« Reply #40 on: June 09, 2019, 07:46:44 am »
Looking great. As for colors, the white could have been that white, but the red possible not. After a year or two at sea (not uncommon journey lengths), I wonder how bad the paintwork would have been.
dlancast
« Reply #41 on: June 09, 2019, 04:07:20 pm »
Great question and one that I have asked.  The kit manuf. states that the colors may appear too bright and that I need to tone them down with washes, etc.  My intent was to seal with a statin varnish overbrush, which seems to tone things down a bit. But, will also lock in that intial brightness.  A thin "grey" wash may be the trick.  Yes, red is notorious for fading quickly in the elements and yes, the white on the hull is waaay too bright for the tallow that was used... would be more like a yellow and only clean at the waterline while underway due to friction rub..... still thinking on this matter and I always welcome the good inputs from you dear folks.  Dennis
dlancast
« Reply #42 on: June 13, 2019, 10:30:52 pm »
Rudder installed.  Pintles and Gudgeons made from copper tape, wire for pin shaft. Dennis
dlancast
« Reply #43 on: June 13, 2019, 10:31:23 pm »
more.
dlancast
« Reply #44 on: June 19, 2019, 01:33:21 am »
Howdy folks,  well... time has been spent on internal and outside details. Such as: completing the Knights, Belfry, Pumps, Ladders, Catheads, Chesstrees, Channels and Pinrails.  I softened the bright colors with a over-wash of thinned down light sea grey.  I think she looks better now.  Painted the Rudder as well.  Next will be the ships boat.  That should prove a challenge at this scale.  I will be using the "lift" method, shaping and hollowing out the inside, then installing ribs, etc.  At least, that is how its supposed to go. Then its on to "Masting and Rigging"... the fun part.  Dennis
dlancast
« Reply #45 on: June 19, 2019, 01:33:51 am »
more.
dlancast
« Reply #46 on: June 19, 2019, 01:34:25 am »
more.
dlancast
« Reply #47 on: June 19, 2019, 01:34:50 am »
more.
dlancast
« Reply #48 on: June 19, 2019, 01:35:16 am »
more.
dlancast
« Reply #49 on: June 19, 2019, 01:35:54 am »
more.
Pages: 1 [2] 3 4 5   Go Up
