Pages: [1] 2 3 4 5 6   Go Down
Author Topic: Repairing my old Midwest Lobster Boat  (Read 16710 times)
Stan
« on: April 07, 2019, 09:08:31 pm »
After 29 years  Susie B now needs some urgent attention. After running for over 1 hour today I noticed water dripping from the hull on close inspection the ply  hull sheets had sprung from the keel. I now intend to let the hull dry out then rub down the hull  and re glass fibre the outside  and inside the hull. Work on the inside of the hull will mean a lot of planking will have to be removed to allow glass fibre to be fitted. Pictures to follow.
Stan. :(( :(( :(( :(( :(( :((
Re: Repairing my old Midwest Lobster Boat
« Reply #1 on: April 07, 2019, 09:23:44 pm »
Fully sympathise with you Stan. I just had the same problem with my warship. The area concerned is totally inaccessible so I'm having to cut a couple of panels in the foredeck to get at the inside.
Good luck with the repairs  :-)
Ray
Footski
« Reply #2 on: April 08, 2019, 07:00:39 am »
She is still a stunning model Stan....
« Reply #3 on: April 08, 2019, 07:45:21 am »
As Capt Podge says ..
"I'm having to cut a couple of panels in the foredeck" ...... well Ray as you well know, a Warship entering Drydock may well have a few plates removed........all part of the refit :-))
unbuiltnautilus
« Reply #4 on: April 08, 2019, 08:12:27 am »
My heart goes out to you chap. My Orca is now laid up on dry land,due to leaks I was finally unable to cure without some fairly brutal repair work. I even considered a new lower hull as an option, instead, I am holding out for 'a bigger boat'!
Fred Ellis
« Reply #5 on: April 08, 2019, 08:18:39 am »
Ray
When I was working one of the lad's was on the Ark Royal (the old one) and he said that when she went in for an engine refit they had to cut out a section from the flight deck down into the engine deck, as that was the only way they could get the old engine out.
Stan
« Reply #6 on: April 08, 2019, 09:33:21 pm »
HI Guys called at my local car shop this morning bought some resin  then on to my local model shop. Spent a fortune buying resin brushes timber, saw blades, and wood glue. I then called at my local timber yard and bought some paint stripper. Hopefully some pictures this week his week when sections are cut out.
Stan.
« Reply #7 on: April 08, 2019, 09:43:52 pm »
You're spot on there Derek - never thought I'd be doing that with a model boat though  %%
Ray
« Reply #8 on: April 08, 2019, 09:52:40 pm »
Stan.
It'll be interesting to follow your approach to the repairs Stan, hopefully pick up some tips along the way  :-)
Ray
Stan
« Reply #9 on: April 09, 2019, 05:33:27 pm »
Four pictures showing surgery needed to allow glass fibre to be installed inside the hull. Once this is complete a new ply deck will be fitted then re planked  and weathered. The hull outside will need attention not sure what action will be needed then a total repaint job. More pictures to follow.
tugboyben
  • Kirkleesmodelboatclub
  • WARRIOR TUG BOAT
« Reply #10 on: April 09, 2019, 05:52:43 pm »
Hi Stan
It as served you well
I did this video 10 years ago & your boat is happy sailing around
You will see at 24 seconds in & again at 1 minute 18 seconds
It will be sailing again very soon
https://www.youtube.com/watch?v=NVjlpNM1Z8w
Jason
Stan
« Reply #11 on: April 10, 2019, 05:09:41 pm »
Stripping off the hull paint now to allow the glass fibre to adhere to the wood better. I am going to make a new rudder also the last one has done 29 years  and its looking a little tatty.
Stan
« Reply #12 on: April 12, 2019, 10:20:47 am »
Just three  pictures showing paint been removed from the hull I hope to have this complete by the end of the day.
Stan
« Reply #13 on: April 13, 2019, 11:28:03 am »
Hi Guys now fitting the glass fibre to  the inside of the hull what a job. Next week rub down the hull fit the glass fibre then paint.
Stan. :-)) :-)) :-)) :-)) :-))
mike_victoriabc
« Reply #14 on: April 13, 2019, 03:57:48 pm »
Nice work!
Paint stripper rather than sanding?
Certainly lifted the original paint.
Stan
« Reply #15 on: April 13, 2019, 04:13:43 pm »
Yes all the paint is off glass fibre fitted to internal hull parts. Motor cleaned tested and refitted new voltage regulator installed  for lighting. Next week hull will be sanded and glass fibre matting applied  then a new paint job. More pictures this evening.
Stan
« Reply #16 on: April 13, 2019, 06:47:58 pm »
Just a few pictures showing hull with paint removed and glass fibre in inner hull.
Mark T
« Reply #17 on: April 13, 2019, 07:06:25 pm »
Lovely job so far Stan and it must be very tricky working around all of the detail thats already there  :-))
Taranis
  • Balne Moor MBC
« Reply #18 on: April 13, 2019, 07:59:48 pm »
Nice Stan :-))
I've found a seller of the 30" like yours. I thought it was discontinued however I will visit the shop while on holiday in London and check it in person.
ANDY
Mayhem is the name model boats is our game
Stan
« Reply #19 on: April 14, 2019, 08:45:24 pm »
After a day off at our clubs Steam Open day  I hope to be back in full swing this week. It must be up and running for Doncaster show in May.
Stan
« Reply #20 on: April 15, 2019, 08:32:53 pm »
Monday final filling of the hull done and rubbed down hope to glass fibre on Tuesday.
Stan.
Stan
« Reply #21 on: April 16, 2019, 09:43:16 am »
Started to fit the glass fibre today what a messy job. still has to be done.
Taranis
  • Balne Moor MBC
« Reply #22 on: April 16, 2019, 11:12:43 am »
Was it covered in glass when you first built it Stan ?
The last incarnation by Midwest included glass cloth in the kit
ANDY
DaveM
  • Why on earth do I do this?
« Reply #23 on: April 16, 2019, 11:25:08 am »
Two layers, if I remember correctly. What a superb kit that was - in all respects. Eat your heart out, Dumas!
DM
Stan
« Reply #24 on: April 16, 2019, 01:23:12 pm »
Hi Andy yes 30 years ago it came with glass matting not sure about two layers.
Stan.
Pages: [1] 2 3 4 5 6   Go Up
