Author Topic: What is this material, discription only  (Read 2445 times)
Gazzalene
« on: April 10, 2019, 12:00:47 am »
I have been watching youtube clips of boat builds.
Several have been skeleton framed and then skinned.
The material used was a white sheet about 3mm thick. it looked some kind of plastic.
looked easy to cut and trim with knife. no foam present.
looked to be same density through sheet,not skinned .
the guy sanded it ok.
it cut far to easy tha 3mm stryrene sheet or abs
any ideas and I can look that up
thanks
grasshopper
    • A1 Hobbies Ltd.
Re: What is this material, discription only
« Reply #1 on: April 10, 2019, 12:30:48 am »
Could be foamboard or depron?
tsenecal
« Reply #2 on: April 10, 2019, 02:01:06 am »
sintra
Gazzalene
« Reply #3 on: April 10, 2019, 09:23:23 am »
Not foam board for sure,i have seen that stuff.
Depron and Sintra I have never heard of and will look uop
thanks
Gazzalene
« Reply #4 on: April 10, 2019, 09:36:44 am »
Just looked up Depron and sintra.
it was not depron , this was cut far to easily and foam like
Sintra, this looks to be the one!
Sintra is a brand name ,its closed cell pvc foam.
the youtube clip on its use says comes in various thicknesses sands like wood and can be hand cut at under 3mm
I am now going to see if available in the UK,all the clips I have just seen are from overseas
thanks for pointers
gerritv
« Reply #5 on: April 10, 2019, 12:49:53 pm »
Sintra is used for making signs, that might be an avenue to pursue
