Thank you for that excellent description and the photo. You do make it sound easy.
I am not RC car-familiar and I baulk at matters requiring electricity and electronics. The best I have managed so far is an Andrew Cook (
http://www.gospectre.com/go_spectre_2012_003.htm) R65 yacht, but only because I purchased the very one - his own specially built one - with the red spotted hull that appears on that site. In other words, I just switch it on and occasionally change batteries.
I need to get on with this project and will start gluing if and when my ebay-purchased corvette arrives from England.
Could I ask your views on some initial thoughts I have about the construction?
Are normal batteries a viable alternative to the rechargeable type?
I was thinking of using lead sinkers to ballast the vessel and after a bathtub test, secure the whole lot with Araldite.
I was then thinking of a liberal application of Araldite over the joints
inside the hull, up to and above the waterline, to further waterproof the hull.
I was planning on using more Araldite around the prop shaft and stern post to give them a solid fix.
Thanks again, especially for the photos,
Michael
