I would be interested to know how you boat builders finish your hull.
I have now applied 3 coats of Finishing Resin and while this dries hard and glossy there are still flaws in the overall finish appearance such as hollows and general uneveness.
What do you do at this stage to get the surface looking good enough to paint?
Filler?
Nordlys.
I use the following method
1. Give the bare hull a coat of finishing resin applied with a 1" roller - You can't clean the roller so its a consumable
2. After 48hrs wipe the surface over with IPA to remove the "fat" and lightly sand
3. Apply another coat of finishing resin using a very fine woven cloth like they use on RC aircraft. Apply using a 1" roller as before
4. After 48hrs wipe the surface over with IPA to remove the "fat" and lightly sand
5. Apply a final coat of finishing resin to fully fill the cloth again with a 1" roller
6. After 72hrs wipe the surface again with IPA and sand to the finish that you want.
I have achieved a glass like finish using this method and all sanding should be done dry. Don't be tempted to add water to the mix. The final sanding of my Fairmount Alpine to me a week on and off - its a long careful process as you do not want to break through the cloth. The results are well worth the effort.
Nordlys in your case I would just go for it and sand the whole thing down - it will take time. If you still need to fill any hollows then use a polyester filler but this should have really been done before any resin hits the hull. If you do need to use filler wipe the area over once roughed up with IPA as this will give you good adhesion.
Good luck mate
