Pages: 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 ... 21   Go Down
Author Topic: Midwest Boothbay Lobster boat 30" build  (Read 53701 times)
Stan
Re: Midwest Boothbay Lobster boat 30" build
« Reply #75 on: May 14, 2019, 06:56:02 pm »
https://www.modelboatmayhem.co.uk/forum/index.php/topic,62785.0.html
Hi Mark T not sure if you have seen my major refit of this model see above link. Hope to see  on the 14 of July. Looking good Andy  Check out Macs moulding at Hooton Park for some items to give that extra detail.
Stan.
Taranis
  • Balne Moor MBC
« Reply #76 on: May 15, 2019, 09:03:38 am »
Thanks Stan
Absolutely no need to glue everything together, certainly not to plan but will be much easier painting etc.
ANDY
Mayhem is the name model boats is our game
Taranis
  • Balne Moor MBC
« Reply #77 on: May 15, 2019, 12:29:37 pm »
FYI I have now used a whole 1oz bottle of slow CA  %%
I'm thinking of lining the four cabin windows with brass strip like I did on Portgarth
ANDY
Mark T
« Reply #78 on: May 15, 2019, 04:11:23 pm »
Stan.
Hi Stan - yep I’ve seen the rebuild and it’s looking great. In fact I think we have a bit of competition between you and Andy here  O0
We can’t make the July meet mate as we will be in Zante - sorry  :((
Taranis
  • Balne Moor MBC
« Reply #79 on: May 15, 2019, 05:55:54 pm »
Stan’s is unique I can only steal ideas  :-))
No idea how mine will turn out but the key is to avoid the picture on the box for me
RNLI colours are out !
Svitzer colours are out !
I like Man City blue but so many options
ANDY
« Reply #80 on: May 15, 2019, 06:20:06 pm »
Hard to make such a pristine model as Stans!
Taranis
  • Balne Moor MBC
« Reply #81 on: May 16, 2019, 08:21:53 pm »
It's occurred to me today that when both are finished they'll make a great double act  O0  both 1/12
Spent all day getting ready for road trip leading to Wicksteed eventually so no work on Lobby today.
ANDY
Taranis
  • Balne Moor MBC
« Reply #82 on: May 16, 2019, 10:22:35 pm »
Advance warning!
The drawing for assembling the windscreen is wrong. If you make it to the plan it will be up to 3mm short.
Regarding the rudder note that only one piece of wood is to be used and the other discarded
ANDY
Stan
« Reply #83 on: May 16, 2019, 10:50:04 pm »
Hi Andy things must have changed over the years since I built mine. The rudder was much thicker and had no problems with the windscreen. Just posted some pictures on my old fishing boat thread showing rudder supplied in the kit years ago
Stan.
Taranis
  • Balne Moor MBC
« Reply #84 on: May 16, 2019, 10:59:06 pm »
Original instructions Stan, I don’t thing they’re updated. Two pieces of wood die cut but one to chuck away
http://rktman.com/rlh/boothbay/steps/step131.html
Roger's Notes: You will only need one of the die-cut rudder parts from the die-cut sheets.
ANDY
Stan
« Reply #85 on: May 16, 2019, 11:06:34 pm »
Hi Andy my rudder is much thicker but we are looking at 29 years ago since my build. But either way they work fine. I hope to have mine back at Wilton in about four weeks time.
Stan.
Taranis
  • Balne Moor MBC
« Reply #86 on: May 16, 2019, 11:48:36 pm »
In four weeks time I hope to be well on the way down the Mosel in Germany Stan  :-) Going with advice from DaveM I bought two motor mounts today on a whim, both similar but huge price difference. The dearer orange Graupner does seem more Stout and probably use it.
ANDY
Taranis
  • Balne Moor MBC
« Reply #87 on: May 17, 2019, 12:24:32 pm »
Here a picture of the alignment tool and micro flex coupling from Modelboatbits .
Essential for success of minimal or no vibration
ANDY
Taranis
  • Balne Moor MBC
« Reply #88 on: May 18, 2019, 03:22:05 pm »
I must have spent near £50 today at macmouldings in 1:12 scale  :-)
ANDY
Stan
« Reply #89 on: May 18, 2019, 05:49:37 pm »
Good stuff from Macs.
Stan
Taranis
  • Balne Moor MBC
« Reply #90 on: May 18, 2019, 06:14:32 pm »
Today’s shopping
ANDY
clockworks
« Reply #91 on: May 18, 2019, 07:37:37 pm »
£50 for that lot is pretty good. I think I'll be buying some bits from there soon...
Taranis
  • Balne Moor MBC
« Reply #92 on: May 18, 2019, 07:48:36 pm »
That’s only for the resin bits not the component shop products
Also not including the seated figure from mount fleet £15
ANDY
Stan
« Reply #93 on: May 18, 2019, 08:12:33 pm »
Hi Andy hull repainting well under way. Thought you might like these pictures.
Stan. :-)) :-)) :-)) :-))
Taranis
  • Balne Moor MBC
« Reply #94 on: May 18, 2019, 08:47:35 pm »
Looking fresh  :-)
ANDY
Taranis
  • Balne Moor MBC
« Reply #95 on: May 23, 2019, 04:59:33 pm »
I’ve now ordered the 750kv Turnigy motor with 4mm shaft and a new alignment tool and coupling for delivery next week.
I don’t like plastic propellers while I can afford brass and I’m wondering if downsizing the 50mm to 45 might be advantageous? Comments invited
ANDY
DaveM
  • Why on earth do I do this?
« Reply #96 on: May 23, 2019, 05:10:43 pm »
The 50mm plastic prop on the model I made has a very fine pitch - possibly too fine, because I had to use 12 NiMH cells to get anything like a reasonable performance from the boat. Most of the bronze/brass props I've had are of a coarser pitch, so maybe you should start with a 45mm cast one. I can recommend Protean Design's range, specifically the General Scale pattern. PM me if you would like Simon's contact details.
Hope to see you on Saturday at StickyWeed when we can have a good old natter.
DaveM
clockworks
« Reply #97 on: May 23, 2019, 05:18:37 pm »
I've just bought a Turnigy 2836/11 750kv for my Aeronaut springer. I'll be using it with a parallel pair of 5000mAH 2s LiPos, running a 40mm 3 blade Raboesch brass prop. Should be good for about 200watts.
Taranis
  • Balne Moor MBC
« Reply #98 on: May 23, 2019, 05:50:46 pm »
Cheers Dave
I have a few props from Simon already  :-))
See you soon
Sounds good clockworks
ANDY
Stan
« Reply #99 on: May 23, 2019, 06:50:00 pm »
Hi Andy my models runs a 30 or 35 prop never had a large prop but I have no wish to influence your choice  for info only.
Stan.
Pages: 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 ... 21   Go Up
