Author Topic: Wanted ideas for door handles  (Read 501 times)
Gardener
  • Ribble Model Boat Club
    • The Wildlife Friendly Gardener
« on: May 13, 2019, 02:19:16 PM »
what can I use for 1:32 scale door handles on wheel house etc ?
thanks
Klunk
Re: Wanted ideas for door handles
« Reply #1 on: May 13, 2019, 02:28:54 PM »
0.5mm brass rod cut to length then bent to L shape. 0.6mm hole drilled and brass superglue in
full time penguin
Gardener
« Reply #2 on: May 13, 2019, 02:30:40 PM »
Taranis
  • Kirklees MBC/ Balne Moor MBC
« Reply #3 on: May 13, 2019, 02:36:02 PM »
Agreed  :-))
Gardener
« Reply #4 on: May 13, 2019, 03:10:16 PM »
CGAux26
« Reply #5 on: May 13, 2019, 03:53:17 PM »
A similar question:  At 1/32 scale I have doors with made-in hinges that must open for access to switches.  What do I do for a door handle that will hold the door closed?
RST
« Reply #6 on: May 13, 2019, 07:15:54 PM »
With a bit of imagination: Use a small magnet to hold it shut, leave the porthole empty so you can use a finger to pull it open. Use bent wire, bent both sides of the door or only on the outside with a bit of wood cyano'd or epoxied on the back.  If you've no brass wire, staples or paperclips can always be recycled. Etc etc.
CGAux26
« Reply #7 on: May 16, 2019, 07:06:22 PM »
Thanks, RST you got my thinking cap on straight.  I have some " rare earth magnets and steel washers to fit them, from Lee Valley.  I mounted a washer on the door and a magnet on a piece of styrene with CA.  I will use the door's handwheel to grab and open the door.
Works great!   :-))
