Pages: [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 ... 101   Go Down
Author Topic: Chris' HMS TIGER (C20) - 1:72 SCALE  (Read 612531 times)
frogman3
« on: June 07, 2019, 10:20:05 am »
HI all im  a newbie with a new pc an a new image hosting site an im tryin to find out how to work all this as im not very good on computers.
An now I wil try an post some pics of my build im scratchbuilding  HMS TIGER C20 in 1/72 semi scale converted to a helicopter carrier an have only been building a few months so not a lot to see.IM at the stage so far havin built the hull with hull frames an qaudron fitted an now ready to start covering the hull a link maybe the only way to see the pics until I can find out how to post proper pics
chris
frogman3
Re: BOATMANS HMS TIGER C20 SCRATCHBUILD IN 1/72 SCALE
« Reply #1 on: June 07, 2019, 10:26:03 am »
https://ibb.co/HD5GFT8
A pic of the real ship as a test pic to see if it will show on site please click on link
chris
frogman3
« Reply #2 on: June 07, 2019, 10:43:00 am »
NOW starting the build by drawn from plans onto the marine plywood an cutting out the keel
https://ibb.co/Bf9nNCs   hopefully link will show as I have not got much confidence in my pc skill 's at the moment but im trying an I will have to load one link at a time as live in a low megabyt  eara
chris
frogman3
« Reply #3 on: June 07, 2019, 10:54:53 am »
An keel cutout  got to be carefull though as its very fragile to move around anyway more links soon as I got have a rest an then go outside into my garage as that's where the ship is bein built an not indoors due to its size  an build a bit more as I want to start covering her today
https://ibb.co/jJC49NY
chris
« Reply #4 on: June 07, 2019, 11:17:15 am »
Looking good Chris, and as you say, a bit fragile at the moment but it will stiffen up once you get the frames mounted.
Looking forward to seeing more as you progress.  :-))
Rob47
« Reply #5 on: June 07, 2019, 11:22:40 am »
chris
Pic showed up, its snakey Blakey though  {-) no matter nearly twins
I will finish this model
frogman3
« Reply #6 on: June 07, 2019, 05:58:45 pm »
Hi guys a few more links for pic's
Here im now cutting out the main hull joint as this ship will have to come in half for transport in car to pond
https://ibb.co/g9Q0Gyg
chris
frogman3
« Reply #7 on: June 07, 2019, 06:04:32 pm »
 the H/J are cut out an nxt job is drilling them out to fit brass slevses  an to fit the main bolts that will hold the ship togeather
chris
frogman3
« Reply #8 on: June 07, 2019, 06:15:25 pm »
An done on the H/J its now ready to fit into the keel section
https://ibb.co/0JCRHvM
chris
frogman3
« Reply #9 on: June 07, 2019, 06:22:01 pm »
Bolts 'washers'a butterfly nuts all fitted
https://ibb.co/XZn6n9V
frogman3
« Reply #10 on: June 07, 2019, 06:29:26 pm »
Got a bit ahead of my self there as I should have shown a pic  of the plasticard fitted in between the H/J to serve as a spacer so when the hull is is covered an lifted off baseboard an bolts removed the plasticard can be removed to make a space to fit in  for the hacksaw blade to cut hull
https://ibb.co/8m8hPHT
frogman3
« Reply #11 on: June 07, 2019, 06:31:30 pm »
AN now ready to fit in place to the keel
https://ibb.co/Pj6GBZ8
frogman3
« Reply #12 on: June 07, 2019, 06:36:36 pm »
Now fittin in hull frames
https://ibb.co/MBhGsnd
frogman3
« Reply #13 on: June 07, 2019, 06:39:35 pm »
More hull frames cut for the front of the vessel
https://ibb.co/5F1MTcQ
frogman3
« Reply #14 on: June 07, 2019, 06:43:18 pm »
AN fitted to keel
https://ibb.co/ysL8mNy
Taranis
  • Balne Moor MBC
« Reply #15 on: June 07, 2019, 06:46:47 pm »
Lovely job. You can post your images rather than just links  :-))
Just use the insert image tab and post the image address
ANDY
frogman3
« Reply #16 on: June 07, 2019, 06:50:50 pm »
Here nr as far as I have gotten on the build an all h frames are in an also the quadrons are fitted to give the hull strength
https://ibb.co/g664qD8
Taranis
  • Balne Moor MBC
« Reply #17 on: June 07, 2019, 06:53:53 pm »
ANDY
frogman3
frogman3
« Reply #19 on: June 07, 2019, 07:02:02 pm »
HI Andy if you can bring them all up like that I would be very pleased as im new to pc 's an not very good on them an what you said about image tabs an such I have not got a clue as on imgbb there are no intruckions to tell you what to do an ive only got this far by sheer luck sorry about that I have just two more pics to post an that's will be as far as I have got on the build but many thanks for your help on pics but I can only put the links im afraid
chris
Taranis
  • Balne Moor MBC
« Reply #20 on: June 07, 2019, 07:04:10 pm »
If I do it now they'll all end up out of order. Happy to do from now onwards  :-))
ANDY
frogman3
« Reply #21 on: June 07, 2019, 07:06:26 pm »
a shot from the stern
https://ibb.co/xqQWpND
frogman3
« Reply #22 on: June 07, 2019, 07:10:33 pm »
OH CHEERS Andy as its nice to see the pics isn't it I just wish I couild do it myself instead of bothering you sorry about that
chris
Taranis
  • Balne Moor MBC
ANDY
frogman3
« Reply #24 on: June 07, 2019, 07:20:32 pm »
AN LAST ONE for today I have now started to cover her in what I call a ply rap round this is as far as I have got on the build
https://ibb.co/ThqhP46
more links or pics when I get that far
chris
Pages: [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 ... 101   Go Up
