Author Topic: Chris' HMS TIGER (C20) - 1:72 SCALE  (Read 627893 times)
T888
Re: BOATMANS HMS TIGER C20 SCRATCHBUILD IN 1/72 SCALE
« Reply #1175 on: November 21, 2021, 12:26:30 pm »
That’s fine Chris :-))
Regards David
Re: Chris' HMS TIGER (C20) - 1:72 SCALE
« Reply #1176 on: November 21, 2021, 12:33:38 pm »
    Topic renamed:   Chris'   HMS TIGER (C20) - 1:72 SCALE
frogman3
« Reply #1177 on: November 21, 2021, 12:58:51 pm »
OK Martin thanks  :-))
chris
Rob47
« Reply #1178 on: November 21, 2021, 01:44:35 pm »
AN HI Bob yes i have consiidered an multi switcher unit but the one i was looking at you had to work the switcher from the R/C sticks back an fourth an as you switched on one unit it swiched another off an that i dont want as i want everyhing on if i want not just some thats why ive gone for my cam switcher idea as with this idea i can have just a few thing goin or all an i dont have to touch my R/C sticks at all as its done through the knobs on the R/C T/X
hope you both as best as can be
ATB chris
Chris easy to run from your set, you just use one of the several 3 way switches and you can have as many things running at same time as you like or not as these units can be latching or non latching.
I will finish this model
frogman3
« Reply #1179 on: November 21, 2021, 02:59:08 pm »
HI Bob WHAT them 4 switches on the right hand side as im already useing one of those switches to open an close my hanger bay doors so would i need to use all the switches on one o those multi switcher units ?
chris
Rob47
« Reply #1180 on: November 21, 2021, 03:04:45 pm »
No Chris, a three way switch will control an 8 or 16 multi switcher easily, had it on mine before now and will be using it on Victorious, all you do is set the latches on the items you want, then flick the switch the appropriate number of times till that item comes on, so if you wanted say a water pump to run continuiously and it was item 5, all you do is flick switch 5 times and it will run, turn off flick switch 5 times and off it goes.
frogman3
« Reply #1181 on: November 21, 2021, 03:14:48 pm »
OK Bob thanks for the info but from what i see id be continuasly switchin switches an forget what im doin lol an wont it wear the switch out ?
chris
Rob47
« Reply #1182 on: November 21, 2021, 04:49:03 pm »
not sure why you would constantly be switching switches though, I use it to turn something on, say nav lights unit is electronic so not much danger of failure the ammout of times it would be used,  horde for courses though, I love em as they are relaible but better still tiny which is a bonus.
T888
« Reply #1183 on: November 21, 2021, 05:32:07 pm »
Hi Chris,
I know your not keen on using a stick to operate the SW unit , I use the units to turn  on, Radar, nav lights , helo, lighting in several areas and they can be Swtch on or off as required. As the units work on a quick movement of the stick, I still can use the same channel for another standard operation. As Rob said the electronic there is not much danger of failure as they are reliable. Yes as Rob also said “but better still tiny which is a bonus”.
Regards David
frogman3
« Reply #1184 on: November 21, 2021, 05:32:51 pm »
HI AGAIN Bob is this switcher the same one as dave t888 has got in his ship ?
chris
Rob47
« Reply #1185 on: November 21, 2021, 10:02:07 pm »
chris
mine is from a different maker BUT they are all the same and virtually use the same chip, I also have a 5 ways sound effect switcher which works same way except obviously you only use one sound at a time
frogman3
« Reply #1186 on: November 21, 2021, 10:09:03 pm »
OK BOB CHEERS AN THANKS for the info dosh is tight at the moment but i'll think about it an got a lot on my mind as some numpty >>:-(  has hit my car an cause a fair amount of damage >>:-( <*<  so got to think to get that sorted firstly  O0
chris
frogman3
« Reply #1187 on: November 28, 2021, 06:28:47 am »
HI ALL well im back on my tiger build since bein ill
an the next steps in the build is to build the what i call them  cam switches an as my T/X has two knobs so ive built two lots of cam switches an there is 5 switches on each cam X2 so i can work up to 10 things on tiger seperately one at a time as the cam turns so they all will be on togeather or i can then back up an turn things off as i go
so a linkpic of the cam board an here ive already built one an its all working ok an now im working on cam no.2
https://ibb.co/bJbJKqk
frogman3
« Reply #1188 on: November 28, 2021, 06:35:03 am »
AN the cam is just a plastic gear that has been ground down with my dremel ginder so there is a low point on the cam where the switches will be in off postion an then as i turn the  micro servo the cams high point closes the switches so power can flow through them to what ever i want to work an here im now about to drill the hole in the base to allow the micro servo to sit down propebrly an be screwed in place
https://ibb.co/Jj40C78
frogman3
« Reply #1189 on: November 28, 2021, 06:36:20 am »
frogman3
« Reply #1190 on: November 28, 2021, 06:40:05 am »
an here ive just now fitting the switches mounting to be glued in place next to the servos an ive found this is a very good idea an never had any probs with it
https://ibb.co/SQB8hsV
T888
« Reply #1191 on: November 28, 2021, 06:43:53 am »
Hi Chris,
Good to see your felling better  :-))
Regards David
frogman3
« Reply #1192 on: November 28, 2021, 06:45:42 am »
an both cams switches built an ive also fitted the front servo to work the front set of stabillizers an they work perfectly  in tandem with the rudder an 4  rear stabilzers :-))
 https://ibb.co/2YW7nMb
frogman3
« Reply #1193 on: November 28, 2021, 06:51:49 am »
Hi Chris,
HI Dave cheers yes its great to feel better as i had my booster  C   jab an a flu jab both at the same time an talk about feel ill thought i was goin to die an i lost a stone in wheight in just a week never want to go through that again
an hope you are well
chris
frogman3
« Reply #1194 on: November 28, 2021, 06:58:54 am »
HERE a shot of what i have now in the bow section an its a bow thruster an esc an then the stabs servo an then the twin cam unit an then the main eletrics board an then the steam unit an then the main power batt  but cant do any more wireing now till i wait for my   mini choc block connecters to arrive in post from ebay
https://ibb.co/K7tDjxP
frogman3
« Reply #1195 on: November 28, 2021, 07:04:10 am »
AN Here ive made up a glass cover to keep out any dampness from the steam unit that could get into the eletrics an now the fun bit starts an thats wirein it all up so no more pics for a few months till its all goin as i dont want to bore you all with just pics of all the wirein so till then bye for now
chris
https://ibb.co/McGY5Gz
T888
« Reply #1196 on: November 28, 2021, 07:53:48 am »
Chris,
We had the flue jab about a month ago and the booster last week, I was fine but the wife had a few days of felling rough. But all good now.
Regards David
frogman3
« Reply #1197 on: November 28, 2021, 09:56:00 am »
Chris,
HI Dave glad you both ok  :-)) [size=78%]now but why i was ill i think anyhow was i had both jabs at the same time an was proberly to much for my ststem as my wife jen jen had the flu jab an then the  C/ booster a couple of wks later an she had no probs [/size]
[size=78%]an Dave a qeustion please on that power distrobuion board as im not useing the BECC can i still use that U-BEK unit to feed something that reqiures just 5v ? or will it damage the PDB board ?[/size]
[size=78%]chris[/size]
T888
« Reply #1198 on: November 28, 2021, 10:07:42 am »
Yes Chris I use the UBEc to power the lighting and the Helicopter on Roosevelt. BUT Don’t over load it by running high amp items.
Regards David
frogman3
« Reply #1199 on: November 28, 2021, 10:14:48 am »
NO Dave there will be no high amps units in the bow section they are in the back section on the motors so on that 3 pin sockect i just use the postitive an neg ? yea ?
chris
Page created in 0.04 seconds with 21 queries.
