Author Topic: Chris' HMS TIGER (C20) - 1:72 SCALE  (Read 611310 times)
Re: Chris' HMS TIGER (C20) - 1:72 SCALE
« Reply #1375 on: March 14, 2022, 09:36:30 pm »
AN HI COULD YOU you give me a link to her history
chris :-))
Hi matey, It is here in Wiki. I appreciate that Wiki gets a little stick about accuracy etc, but it does have a list of sources and does say when a statement has no source/proof, so if it smells fishy check the bottom as it might give you the original source.
Here: [size=78%]HMS Tiger (C20) - Wikipedia[/size]
« Reply #1376 on: March 14, 2022, 09:44:37 pm »
an side view an these seaking kits are very weak kits to fit in the gold eletric pickup pins as they are sprung loaded so a tight fit so i will have to strenghten the choppers outer undercart so they dont just snap off when pushing the eletric pins into the flightdeck gold sockets to give power to the lights an motors
https://ibb.co/2dKKShc :-))
Chris, you might want to ask Nick whether that tape is right for assembling fuselages. Some might not be correct  {-)
Your work is looking fab. I saw that copper tape being used by someone at my old club and it worked well. He was running all sorts of gizmos through his and so can say your system should be just as effective with the tape. I think he had some sort of pad arrangement to make sure the tape and contacts always touched.
frogman3
« Reply #1377 on: March 14, 2022, 11:10:03 pm »
HI MANY THANKS for the link to the tiger info a yes i had a good read an leanred a bit
cheers chris
frogman3
« Reply #1378 on: March 14, 2022, 11:14:23 pm »
AN HI again glad you like her an yes that copper foil tape is very good i put it under my nr 9ft flightdeck on my nimitz to light up all the leds an it worked great
chris  :-))
frogman3
« Reply #1379 on: March 16, 2022, 08:30:30 pm »
HI allanother  small update as done the flight deck lighting an ive treid to keep the wires as neat an tidy as possible
https://ibb.co/9TkFpqj
frogman3
« Reply #1380 on: March 16, 2022, 08:44:04 pm »
an here the flight deck lights an proberly not the correct lights but all i had
https://ibb.co/qBTkccV
frogman3
« Reply #1381 on: March 16, 2022, 08:45:41 pm »
an two halfs of the seaking fusalarge
https://ibb.co/MPQHTwt
frogman3
« Reply #1382 on: March 16, 2022, 08:48:31 pm »
Now here im goin to try an fit the top part of the rotar to the tiny motoran gearbox an it does about 20 rpm
https://ibb.co/87MSdPW
chris
frogman3
« Reply #1383 on: March 22, 2022, 07:49:47 am »
HI ALL well ive been working on that seaklng  chopper to get the motor fitted in an the main rotars to turn an here a shot of the main rotar head now fitted to the motor shaft by a mini collet with a allen screw into tighten on the motor shaft
https://ibb.co/HhKCVw6
frogman3
« Reply #1384 on: March 22, 2022, 07:52:50 am »
AN Here now ive just fitted in the rotar blades to see how they fit an they look ok
https://ibb.co/s5qfP8N
frogman3
« Reply #1385 on: March 22, 2022, 07:58:21 am »
HERE the motor is now fitted into the seaking's main fusalarge an just as well that this seaking kit comes with a seperate bottom so when i fitted the two havles of the fusalarge togeather i can go up through the bottom to work on it  :-))
https://ibb.co/4mynb4k
frogman3
« Reply #1386 on: March 22, 2022, 08:08:40 am »
AN HERE now ive fired up the motor an the rotars all goin fine an i ran it for 20 mins an it ran ok so im pleased an it ran at about 40 rpm
https://ibb.co/GW9xqW6
next ive to fit a tiny 3v motor in the tail to work the rear tail rotar an fit red flashing strobe lights but got to wait till these motors turn up as i oreded some off ebay
chris :-))
frogman3
« Reply #1387 on: March 22, 2022, 10:44:20 am »
AN HERE A SHOT of the chopper in static state after running for 20 mins so to let the motor cool down
https://ibb.co/0BJ804z
« Reply #1388 on: March 22, 2022, 12:01:26 pm »
That's looking good Chris and it's good to see that you've managed to sort out the image hosting again.
Hope them mini motors arrive soon and you can get the tail rotor running ok.
frogman3
« Reply #1389 on: March 22, 2022, 06:33:25 pm »
HI Ray yes im pleased with how things are progressin as this seaking is gonna be a difficult build as the plastic is not stronge so i'll have to strenthen it an yes i hope them mini  motors
arrive before to long as im hopeing to have it so that the tail section on the chopper will swing round LIKE THE REAL CHOPPER DOES if i fit it with a tiny hindge so the tail rotars wont get broke in transport an pc still playin up so got to hope i can still post pics
cheers Ray for stoppin an lookin at the build much appreacaited
ATB
CHRIS
Sealord
« Reply #1390 on: March 24, 2022, 05:24:52 pm »
Hi Mate, all looking good with the heli,,only 3 left to do.. :-)) enjoy....
frogman3
« Reply #1391 on: March 24, 2022, 06:17:34 pm »
HI MR SEALORD  yes only 3 more to build but as they wont be workins ones so they will build in a couple days so they easy each one  but this motorised one is gonna be difficult as im strivin to get a smaller motor as possible to fit in the tail to work the tail rotar so waiting for some comin off ebay an when will you be putting on your avenger thread ?
the ole m8
Rob47
« Reply #1392 on: March 24, 2022, 06:48:30 pm »
might be off help Chris
I will finish this model
frogman3
« Reply #1393 on: March 24, 2022, 07:16:56 pm »
HI Bob yes brilliant pic many thanks  as i hope to have my seaking rear tail rotoar swing round to proteck the rear rortars an i will use a tiny dolls  house hinge that i have used on my water tight doors an they work ok  just got to make it so that all six wires that go to the tail rotars will fold in an out ok
hope you both as well as can be  PS BOB have you any pics of the rear of the tail as i think there is a red A/C strobe on the tail top an on the rear a back faceing white light as thats what im gonna fit on my chopper  :-))
chris
Rob47
« Reply #1394 on: March 24, 2022, 10:42:02 pm »
frogman3
« Reply #1395 on: March 25, 2022, 07:17:37 am »
HI Bob cor what a fab pic of a seaking many thanks for you posting it just what i was looking for CHEERS all best to you an judi
Chris :-))
Rob47
« Reply #1396 on: March 25, 2022, 09:56:33 am »
Chris :-))
Glad to help Chris, we both were playing with Merlin and Wildcats on Tuesday, great day out with the FAA
frogman3
« Reply #1397 on: March 25, 2022, 10:57:28 am »
HI AGAIN Bob really glad you an judi had a good day out as thats why we are a bit depressed as around here where i live there is nothing as they have closed up RAF COLTISHALL >>:-( <*< <:( an now we dont even see an  military planes how we used to which is sad an to far for me to drive to yoeinton  sorry cant spell it
Chris
frogman3
« Reply #1398 on: March 28, 2022, 05:30:58 pm »
HI GUYS well here is a little more on the  working seaking helo
an i wanted to have the main door open an shut so i set about makin this work had to do a bit of filein down  but it all came up good an works ok an i fitted a bit of 2x 2mm channel runners to the fusealarge for the door to slide in an here its closed
https://ibb.co/BsJgLk8
frogman3
« Reply #1399 on: March 28, 2022, 05:33:24 pm »
an now open as im hopein to fit some crew figures in here with a 2mm weak white led to illulimnate the cabin
https://ibb.co/rH6dzkW
