Author Topic: Chris' HMS TIGER (C20) - 1:72 SCALE  (Read 608075 times)
frogman3
Re: Chris' HMS TIGER (C20) - 1:72 SCALE
« Reply #1400 on: March 28, 2022, 05:35:32 pm »
an next up i want to have the chopper lit up so ive fitted in the white 2mm led for landing lights
https://ibb.co/9gBNY3Y
frogman3
« Reply #1401 on: March 28, 2022, 05:41:40 pm »
AN then i thought hang on a minute as id better paint the interior a dark matt green so thats what  have done
https://ibb.co/qJdGprj
an when i get the tiny eletric motors i will hope to fit in the tail to make the rear tail rotars spin round an anouther indea ive got is to fit a tiny hinge in tail so that the tail plane will swing round like the real one so that the rotars wont get broke in transport to an back from the pond
chris :-))
« Reply #1402 on: March 28, 2022, 06:36:27 pm »
Hi Chris, ref the hinged tail section - is that because it hangs over the stern when it's extended?
You've got some brilliant ideas for this model and it all adds to the realism.
This is one fantastic build to follow - lovely job.  :-))
frogman3
« Reply #1403 on: March 28, 2022, 07:30:33 pm »
HI RAY  well regards the hinged tail section no it wont be over hanging on tiger as it will be in the flight take off postion its just that as the real chopper does that i thought well i would like to add that to my model an another reason i want the tail section to swing back is it will proteck the tail rortars in tranport
an yes ive goin to try out my ideas as i like the realism with lights as it brings the model to life rather than just a static  as i lit an have my melin goin on my norfolk an here it is but it runs both rotars will go lovley
https://ibb.co/qmLMXg7
AN Ray im glad you are likeing the build so far but still a lot to do on her
ATB Chris
« Reply #1404 on: March 28, 2022, 08:10:13 pm »
Crikey Chris! Motorising the Sea king is enough and then you go another two levels illuminating and adding a hinge to the tail!
This model will be amazing (well it already is) when completed. A real labour of love.
frogman3
« Reply #1405 on: March 28, 2022, 08:38:32 pm »
AuthorTopic: Chris' HMS TIGER (C20) - 1:72 SCALE  (Read 120951 times)
[/size]
ballastanksian  hi well its not built  yet as still a lot can go wrong but yes hopefully my ideas will work out on this seaking as they did on my merlin
an yes im really enjoying building this whole ship an the chopper
thanks for lookin in on the build  :-))
chris [/size]
[/font][/size][/color]
frogman3
« Reply #1406 on: April 05, 2022, 07:12:20 pm »
HI All well still working on the seaking helo to get it all working an for a dragon kit not a good fit an i think its goin to be a devil to fit togeather but will see when i come to it an here fit some of the insides
https://ibb.co/ggm17N0
frogman3
« Reply #1407 on: April 05, 2022, 07:14:16 pm »
next up ive painted an fitted in the pilots hopefully right colours
https://ibb.co/hHpFLLq
frogman3
« Reply #1408 on: April 05, 2022, 07:23:29 pm »
An i wanted to fit weak white lights in side to light up the pilots an so did so
https://ibb.co/BBjB3C9
frogman3
« Reply #1409 on: April 05, 2022, 07:30:08 pm »
here ive also fitted a light inside the main fualarge so it will light some crew figures that im goin to fit in the chopper next job is fitting
 in he gold pickup pins an thats goin to be ver awkward an trying to get all the wires soldered but can make up the tail rotar section yet till the tiny 3 v motors come an im goin to try an make it hinge around like the real chopper an ive made the ront door hinge down with the steps on
chris
https://ibb.co/b5mvTKZ
Dan
« Reply #1410 on: April 05, 2022, 10:02:09 pm »
Hi Chris, just managed to catch up on your build! Fantastic work! Your Heli has more working parts than my campbeltown! I'm looking forward to seeing how you construct the folding tail. Will your tail blades rotate too?
frogman3
« Reply #1411 on: April 05, 2022, 10:45:16 pm »
HI Dan  yes helo is comin on an yes the tail rotar should work like my merlin helo does all im waiting for is the small 3v motors with a 3'2 mm thick motor an then i will drill out the tail an fit the motor in an the red flashing  2 mm  led on the tail top an a white led in the rear of the tail i think it is an then a hinge fitted an by rights it should swing round like its folded up for storage in hanger but also to stop the rotor blades getting bustered  when in transport an any more work done on your ship ? as i keep looking or has work got in the way ?
ATB Dan
chris  :-))
Backerther
« Reply #1412 on: April 06, 2022, 09:49:49 am »
Hi Chris;
I also used to adopt mini-motor seen in the pics for my two Seafire fighters for 1/96 Fencer.
I bought them at Akihabara, Tokyo at around ¥200 each. :-))
Kiyo
frogman3
« Reply #1413 on: April 06, 2022, 12:18:55 pm »
Hi Chris;
Kiyo
YES Kiyo thats the motors i have sent for but i see yours are 4 mm in diameter but the ones i have sent for are smaller still at 3'2 mm  dimameter so the smaller they are the easyier they are to fit in the tail as a seakings tail is very thin so even with these smaller motors i'll stilll have to use filler to fair them in so not to look to lumpy but will see when they come
ATB to you Sir an keep on boating an we are havin a gala day up at norwich pond on aprill 24th so im praying for nice wheather as there normally quite a few nice big models up there
chris
Dan
« Reply #1414 on: April 06, 2022, 06:40:04 pm »
ATB Dan
chris  :-))
That'll look great Chris! Are they powered from batteries inside the hull of the ship or will you fit a small battery somewhere inside the Heli?
Campbeltown is coming on very slowly. Work and family life have slowed progress, I'm still working my way through the stanchions but I'm lucky if I spend a hour a week on it at the moment unfortunately.
frogman3
« Reply #1415 on: April 06, 2022, 07:48:26 pm »
HI DAN yes the helis motors are powered from inside the ships big 12 amp hr batt that drives the main motors but there is a voltage reducer fittied in the circut to the heli motors to reduce the power from 12 v down to 3v  an they pick up the power from gold pick up pins fitted into the flight deck an the helicopter can still be lifted off for transport i'll show how small the motor is for the tail rotor when i can take some pics of them as they only arrived today an sorry to hear you dont get time to work on your ship but a little is better than none
atb
chris
frogman3
« Reply #1416 on: April 09, 2022, 06:16:12 am »
HI ALL well a bit more on the helo as ive got a dragon helo kit but its a terrible fit so had to do a bit of filling with plasticard an plenty of fileing down an sandaing  but have now got the two float outriggers fitted togeather an red an green 2mm leds lights for nav lights fitted in
https://ibb.co/02Fj8wM
frogman3
« Reply #1417 on: April 09, 2022, 06:18:42 am »
next up is the gold an brass 2mm eletric  pickup pins an sockets
https://ibb.co/bmw2q8t
frogman3
« Reply #1418 on: April 09, 2022, 06:20:51 am »
an here they are fitted with their wires to take power to the motors  and lights
https://ibb.co/PwfbNVY
frogman3
« Reply #1419 on: April 09, 2022, 06:21:39 am »
frogman3
« Reply #1420 on: April 09, 2022, 06:24:31 am »
an ive now drilled the holes in the fusalage to take the wireing an its now bein pushed into postion to be gluded to the fusalarge
https://ibb.co/Dfsp1jn
frogman3
« Reply #1421 on: April 09, 2022, 06:26:20 am »
an fitted but got to make sure they are fairly straight regards fusalarge
https://ibb.co/5jZ0Zhc
frogman3
« Reply #1422 on: April 09, 2022, 06:30:28 am »
an last pic for today till i can do more an the outriggers look fairly good so can press on on the other side as these eletric pickup pins are for the lights the other side will be for motors
chris
https://ibb.co/d2MLNDW
Backerther
« Reply #1423 on: April 09, 2022, 11:31:02 am »
Hi Chris;
Your onboard heli is well-craftsmanship and looks complicated from the structure of heli like to install neatly the wiring work in the fuselage.!! :-))
While mine was rather simple to work in the 1/100(not 1/96) Super-marine Sea fire fighter. :embarrassed:
1;Only set a mini-motor to spin the props directly
2/3;And modified the landing gears to get them a switch for spinning the props
4; Push-down is ON while a pull-up a bit like this is OFF position and could be removed if necessary.
5;The plane was pushed down to the deck for taking-off with spinning the props and the flaps were fully down as well. {-)
 And wheels were just off the deck and afloat !! {-) {-)
I have set 2 prop-spinning fighters,the other one is waiting for take-off with spinning the props at the rear deck. :D
Looking forward to your refined lighting and rotor-spinning helicopter on the deck.!! :-))
Kiyo
« Reply #1424 on: April 09, 2022, 11:46:57 am »
Great ideas from both of you for hiding things like power and support structures! Not easy on diddy models even with minute motors etc.
