Pages: 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 ... 101   Go Down
Author Topic: Chris' HMS TIGER (C20) - 1:72 SCALE  (Read 613845 times)
Taranis
  • Balne Moor MBC
Re: BOATMANS HMS TIGER C20 SCRATCHBUILD IN 1/72 SCALE
« Reply #225 on: September 23, 2019, 03:01:15 pm »
AN for a change I thought id get the quarter deck cut out an just fitted in to see how it looks but  its got to come out again so I can fit the rudder an stabilizer's push rods  in whenever that will be
 https://ibb.co/p0dvMtk
ANDY
frogman3
« Reply #226 on: October 12, 2019, 07:32:23 pm »
HI all well time for a small update on the build
an I have spent a bit of dosh on her for a few things that she's gonna need
https://ibb.co/rH6CpvR
frogman3
« Reply #227 on: October 12, 2019, 07:35:52 pm »
HERE I have made an fitted all 8 bilge keels
https://ibb.co/YbfSpKn
frogman3
« Reply #228 on: October 12, 2019, 07:37:33 pm »
Doin a test fit of the prop sharfts
https://ibb.co/m6xV3LG
frogman3
« Reply #229 on: October 12, 2019, 07:40:16 pm »
A angle shot of the sharfts an the bilgle keel can also be seen
https://ibb.co/sVcXfC5
frogman3
« Reply #230 on: October 12, 2019, 07:43:00 pm »
here I have just laid the johnsons motors in side the hull to see if the fit in between the hull frames ok an they do
https://ibb.co/dcdgzVn
frogman3
« Reply #231 on: October 12, 2019, 07:45:55 pm »
An a test of the rudder come stabilizer as these will be cut down an made into stabs later on in the build
https://ibb.co/yyJGRZ3
frogman3
« Reply #232 on: October 12, 2019, 07:47:47 pm »
A shot from the bottom
https://ibb.co/MsVgJsK
frogman3
« Reply #233 on: October 12, 2019, 07:50:35 pm »
an inside the hull shot of the mountings as later on they will be cut down to the correct size to make sure there is enough room for the main drive batt
https://ibb.co/m9wS2ZC
Rob47
« Reply #234 on: October 12, 2019, 10:35:00 pm »
coming on nicely, I notice you have a large exposed keel, why is that ?
I will finish this model
frogman3
« Reply #235 on: October 13, 2019, 09:21:39 am »
HI Bob yes im pleased with how the build is comin so far without any major problems an regards the large exsposed keel well. When I scartchbuild a ship hull I always think when finshed she maybe top heavy no matter how light the materials used to build S/S an such so the large keel is a half an inch deep an I can fit a half x a half inch  metal counter balance wheight at its furthest point on the hull to counter any anti rolling of the ship.An it looks ok nice an neat not a big ugly blob of lead  as in my time ive seen several people make that mistake on new ships an seen them roll right over an sink.Plus as this hull is not a F/G hull as they are stronger as you well know the bigger keel is more stronger to take the wheight of the big batts an such  how' that for an esplaination ?
chris
frogman3
« Reply #236 on: October 25, 2019, 06:57:08 pm »
HI GUYS time for an update on whats happening on her
an I have been busy makin up the 6 stabilizer's  from small rudders
piclink
https://ibb.co/2MypXmC
frogman3
« Reply #237 on: October 25, 2019, 07:02:46 pm »
A shot of two fitted into hull to see if they will move ok an they do
https://ibb.co/59NgT07
frogman3
« Reply #238 on: October 25, 2019, 07:05:34 pm »
both sections done all 6 stabs fitted
https://ibb.co/WFH9rD4
frogman3
« Reply #239 on: October 25, 2019, 07:09:08 pm »
HERE the stabs are fitted but they all will have to come out again so I can fill them with resin for strength an then to be sandin sealed an then sanded down so they look nice
https://ibb.co/5v6gzDR
chris
frogman3
« Reply #240 on: October 25, 2019, 07:11:30 pm »
Next job makein up 4 A FRAMES  for the prop sharfts
Chris
frogman3
« Reply #241 on: October 26, 2019, 11:58:47 am »
HI Bob when you built your 1/96 tiger did you have much trouble fitting in the A FRAMES ? as my plans are miles out the top elevation an the side elevation an the rear are all up to 6mm out of alinement an its givin me a bloomin headacke  >>:-( as nothin lines up. <*< So I suppose i'll have to split the difference ? yea  id apprecait a reply if you can please  an its the curveature of the hull also givin problems tryin to get the mearsuments
right but I will do it as I like a challenge but if you give me any advice it would be most helpful
chris
Rob47
« Reply #242 on: October 26, 2019, 04:21:43 pm »
No problems at all Chris, apart from the normal making sure all alignment is correct, I have attached couple images showing mine, remember that the prop shaft length if to short will make the exit angle to steep, hence CVA-01 has shaft two foot long to sit right, and they run really quiet.
Hope the shots help if not shout out.
frogman3
« Reply #243 on: October 26, 2019, 06:34:11 pm »
Cheers for the reply Bob an I know your tiger is 1/96 scale an I see you have very short sharfts  as on my plans I have had to  fit 16" inner sharfts an 15" outer sharfts to keep the props level an not pointing down  an on my plans it show the sharft length that comes out of the hull at 6" but what im havin probs with is the angle of the A FRAME on one sheet it shows the frames are angled nearly flat to the hull an then on another it shows the frame nr upright nr like yours so I think I will follow your design an cheers for posting the pics  :-))
chris
frogman3
« Reply #244 on: October 26, 2019, 06:53:44 pm »
HI again Bob my main concern is wheather the outer props stick out further than the hull itself so do they ? a pic from the rear would be most helpful cheers
chris
Rob47
« Reply #245 on: October 27, 2019, 11:09:22 am »
Chris hope these clarify it for you, the drawing if I recall shows stern view and the amount of splay out of props.
frogman3
« Reply #246 on: October 27, 2019, 02:33:23 pm »
Cor Cheers Bob just the pics  that I wanted to help me  with fittin in my prop sharfts
these pics will be of imence help you have made me a happy bunny . As now I can now ignore my plans as they show 3 different layouts regards the angle of the A -FRAMES  as it was sendin me round the bend with frustration  >>:-( <*< tryin to fit them an they just dint look right  many thanks much appreciated an is it ok if I download them ?
chris
Rob47
« Reply #247 on: October 27, 2019, 02:59:26 pm »
glad they helped, feel free to download
frogman3
« Reply #248 on: October 27, 2019, 04:46:34 pm »
Cheers Bob  :-))
chris
frogman3
« Reply #249 on: November 01, 2019, 09:38:47 am »
Small update on whats happenining on her
have made up the 4 A-FRAMES to hold her sharfts in place
https://ibb.co/SKjgr1F
Pages: 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 ... 101   Go Up
