Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 ... 101   Go Down
Author Topic: Chris' HMS TIGER (C20) - 1:72 SCALE  (Read 627922 times)
frogman3
Re: BOATMANS HMS TIGER C20 SCRATCHBUILD IN 1/72 SCALE
« Reply #325 on: March 15, 2020, 12:32:44 pm »
Chris
Hope this image help, its very straightforward, if you go onto the warship R&D there is a drawing of similar set up and a link for the transistor.
HI Bob could you show me where in r/d as Ive looked an cannot find it can you give me a link to it ? please
chris
Rob47
« Reply #326 on: March 15, 2020, 04:42:01 pm »
Chris
got to warship r&d, look for title "anyone recognise this component", scroll down and there is a circuit plan
I will finish this model
frogman3
« Reply #327 on: March 15, 2020, 07:39:28 pm »
Chris
CHEERS Bob yes ive now found it many thanks
chis
RST
« Reply #328 on: March 15, 2020, 08:36:28 pm »
Does that work in fresh water please?
frogman3
« Reply #329 on: March 15, 2020, 11:03:09 pm »
yes I think it does as far as I know
chris
« Reply #330 on: March 16, 2020, 03:45:27 am »
If you needed to increase the salinity/conductivity of any bilge water whilst running in a fresh water river, creek or inland dam etc, you could always sprinkle a teaspoon of fine or ground Table Salt into the lower bilge area where any water could collect
The fresh water on contact with the fine salt powder would near immediately alter the di-electric potential of this water & so activate the water level switch function
A little light reading........courtesy of Google
https://www.researchgate.net/post/Why_dielectric_constant_both_real_img_increases_with_salt_concentration_in_aqueous_solution_in_THz_frequency_region
frogman3
« Reply #331 on: March 24, 2020, 10:30:55 am »
HI ALL update time on the build well I was thinkin I will fit some W/T doors on her with small hinges so I can open them as I want to fit in lights an some detail in the compartments
https://ibb.co/q0sKMXv
frogman3
« Reply #332 on: March 24, 2020, 10:34:35 am »
an doors fitted on ok
https://ibb.co/hZ0XPW1
frogman3
« Reply #333 on: March 24, 2020, 10:35:52 am »
an in the open postion
https://ibb.co/KctTVv3
frogman3
« Reply #334 on: March 24, 2020, 10:41:15 am »
here back to the bridges electric power plugs ive fitted tiny modualar connecters to take power up to the bridges for lights an such but first them main wires to take the power from the main wirein they are thw small  white wires
https://ibb.co/c1yjZQH
frogman3
« Reply #335 on: March 24, 2020, 10:44:41 am »
an a pic of the mainpower  uptake plug 4 pin fitted in S/S for the bridges to plug into
https://ibb.co/cgQNFfR
frogman3
« Reply #336 on: March 24, 2020, 10:48:37 am »
next the  plug fitted to the bottom bridge this has two lots of wires conneted one lot for the btidge lightgs an the other goin up to another female plug to take power to the top bridge
https://ibb.co/xG3x09w
frogman3
« Reply #337 on: March 24, 2020, 10:59:59 am »
here a shot of the bottom bridge fitted with the power uptake plug goin to the top bridge I have made them like this so I can remove both bridges from the 02 S/S to fit in the glass an lights an such after paint sprayin in the comin months when warmer wheather
https://ibb.co/ftTTLJn
frogman3
« Reply #338 on: March 24, 2020, 11:01:48 am »
an the top bridge fitted with its power plug
https://ibb.co/59nyDK0
frogman3
« Reply #339 on: March 24, 2020, 11:03:49 am »
underside shot of 02 deck an bridge fitted to it
https://ibb.co/wC3hcQn
frogman3
« Reply #340 on: March 24, 2020, 11:10:02 am »
an all the wires in the 02 DECK will work say things like radar motors an floodlights an anti collishion lights an steamin lights on the mast an intertior lights  in S/S as I want to fit again opening doors with small corridors with a sailor or two standin in there
chris
frogman3
« Reply #341 on: March 24, 2020, 11:13:28 am »
carryin on with the power plugs shot of the main bottom bridge fitted with all its wirein
to the S/S
https://ibb.co/09kGgyJ
frogman3
« Reply #342 on: March 24, 2020, 11:15:19 am »
TOP bridge fitted on now as well
https://ibb.co/71myw2g
frogman3
« Reply #343 on: March 24, 2020, 11:18:58 am »
an last shot for today of the bottom an top bridges all fitted on with all the wirein in an ive tested it all with a circuit tester an all power wires work fine  :-))
https://ibb.co/4ZZDm32
Weaver
« Reply #344 on: April 17, 2020, 05:16:58 pm »
Hi There! Sorry to butt in: I found this thread while I was researching the Tiger class to improve a Shipbucket profile and Google Images took me to some of the gorgeous model shots herein. This is great project! I can't even begin to imagine building a 1/72nd warship: I can barely avoid losing motivation in the middle of a 1/72nd tank!
Anyway, I wanted to chip in my twopenn'th on the Type 278 height-finding radar controversy. I agree that it makes sense that it wouldn't just rotate all the time and would be specifically pointed at targets, however, there's film that proves otherwise. If you look at this Pathé News video on Youtube of HMS Glamorgan, you can quite clearly see the 278 rotating continuously through 360 degrees. Now whether it did that all the time, or whether it sometimes stopped to height-find a target I couldn't say.
The video is here: https://www.youtube.com/watch?v=H7sv9ODO-YU
If the link doesn't work for some reason, the exact title is: HMS Glamorgan - Computer Ship Of The Future (1967)
The 278 bits start at about the 4 minute mark, but the whole thing's only 7 minutes long and hilariously dated so watch the whole thing for a laugh!
Good luck with the Tiger build!  :-))
frogman3
« Reply #345 on: April 17, 2020, 08:04:05 pm »
Anyway, I wanted to chip in my twopenn'th on the Type 278 height-finding radar controversy. I agree that it makes sense that it wouldn't just rotate all the time and would be specifically pointed at targets, however, there's film that proves otherwise. If you look at this Pathé News video on Youtube of HMS Glamorgan, you can quite clearly see the 278 rotating continuously through 360. Now whether it did that all the time, or whether it sometimes stopped to height-find a target I couldn't say.
HI
Weaver MANY  THANKS for your post an don't worry about butt in  an yes ive seen this vid before when I was talkin to Bob about it as a friend who lives in portsmoth  sent me the same vid an yes again it does show the 278 radar rotatein through 360  degrees an I think you are right it proberly does that an when it finds a target then it stops an does height findin but at the moment im a long way from getting that built so i'll sort that when I come to it  but thanks for droppin in on my thread an hope to see you on here again an I will soon post some more piclinks in a day or so as they are all in the camera just got to resize them an load them onto imgbb then i'll load onto site if you want t see the latest pics an many thanks for your kind comments an glad you like the build  :-))
ATB STAY SAFE chris
stay safe
ATB chris
Rob47
« Reply #346 on: April 17, 2020, 08:19:11 pm »
Same radar different mounts for two totally different ships, the data and info I have passed on comes from the guys who served on Tiger
frogman3
« Reply #347 on: April 17, 2020, 08:33:59 pm »
HI Bob well ok how do you think I should model it ?  no disrespect to you intended as you know more about the ship  than me remember im just the modeler an I was postin my build on another forum an an bloke comes onto my tiger thread sayin ive got all my bridge S/S to far forward an I told him that its right by the plans an he also said that ive got the armour plate wrong as well so from what ive been told tiger was in the ship yard a long time bein built so maybe they made changes to the ship over the time of the build  an nice to see you Bob ATB STAY SAFE  Chris
frogman3
« Reply #348 on: April 18, 2020, 09:29:34 am »
HI all a small update on where the model is now an whats happening on her
AS we have had good warm wheather I have took her out to the garage an sprayed her overall grey primer to show up all the  little holes an cracks where I have joined the deck to the hull
a couple of shots at different angles
https://ibb.co/XbmrGwH
IMG-5163
frogman3
« Reply #349 on: April 18, 2020, 09:31:12 am »
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 ... 101   Go Up
Page created in 0.049 seconds with 21 queries.
