Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 ... 101   Go Down
Author Topic: Chris' HMS TIGER (C20) - 1:72 SCALE  (Read 841032 times)
frogman3
Re: BOATMANS HMS TIGER C20 SCRATCHBUILD IN 1/72 SCALE
« Reply #375 on: April 30, 2020, 07:53:30 am »
Coming along well
THANKS T888
chris
frogman3
« Reply #376 on: June 02, 2020, 08:07:03 am »
UPDATE
well ive built in the hanger front an built the hanger doors
https://ibb.co/Z1qFGqN
frogman3
« Reply #377 on: June 02, 2020, 08:12:44 am »
an here ive just fitted in the radar motorgear box as this must be done now an I will also fit the CPT unit as its a voltage reducer to cut down the power from 12v to 5.3v for said motor
https://ibb.co/vH0zB99
frogman3
« Reply #378 on: June 02, 2020, 08:17:07 am »
an back to the hanger doors to get them so they will  open an close by R/C an im gonna fit two servos under the hanger floor an so I can do it slowy ive bought this handy little gadget
too work the servos slowly
https://ibb.co/NxmyLnM
frogman3
« Reply #379 on: June 02, 2020, 08:19:10 am »
pic of what ive got so far
https://ibb.co/JzLvNVW
frogman3
« Reply #380 on: June 02, 2020, 08:22:45 am »
now getting the H-DOORS workin ive fitted in a pushrod that will pull the h -door up an down from a servo
https://ibb.co/vJs79Ct
IMG-5256
frogman3
« Reply #381 on: June 02, 2020, 08:24:45 am »
front view to show the push rod goin down to the servo on the underside
https://ibb.co/JKMfRwc
IMG-5257
frogman3
« Reply #382 on: June 02, 2020, 08:26:47 am »
servo mounted below ready to pull the pushrod up an down on the h -door
https://ibb.co/8zyhh5n  IMG-5258
frogman3
« Reply #383 on: June 02, 2020, 08:29:03 am »
an it works lovely up an down
https://ibb.co/tJWbjbn#
IMG-5259
frogman3
« Reply #384 on: June 02, 2020, 08:30:42 am »
door opens ok
https://ibb.co/8gxkk07
IMG-5260
frogman3
« Reply #385 on: June 02, 2020, 08:31:50 am »
an now halfway to closein
https://ibb.co/5cK36Zh
IMG-5261
frogman3
« Reply #386 on: June 02, 2020, 08:33:16 am »
and shut
https://ibb.co/NKnKD8J
IMG-5262
frogman3
« Reply #387 on: June 02, 2020, 08:35:29 am »
 I bought a servo morphough so that hopefully it will  open an close the doors slowly https://ibb.co/mNj1CBp
IMG-5272
frogman3
« Reply #388 on: June 02, 2020, 08:40:06 am »
Now back to that radar motor getting this going an whoever designed the main mast well its sitting
 half on the hanger an half off so that makes it awkward to get the main radar shaft up in the front wall
https://ibb.co/fdMLrZq
IMG-5273
frogman3
« Reply #389 on: June 02, 2020, 08:42:19 am »
but its done
https://ibb.co/718jBqr
 IMG-5274
frogman3
« Reply #390 on: June 02, 2020, 08:47:31 am »
an the radar shaft built an fitted with a square brass box section as the top mast will be able to lift off so a smaller bit of box section will be fitted to it an then able to drop in the motor shaft to turn said radars
https://ibb.co/mqS88Xy
IMG-5276
frogman3
« Reply #391 on: June 02, 2020, 08:49:34 am »
an fitted in the front wall
https://ibb.co/pfQSXsg
IMG-5284
frogman3
« Reply #392 on: June 02, 2020, 08:54:47 am »
Now back to that other H-DOOR an I've had to fit in a cross member to take the second  push-rod to hold it tight so that when the door is open it wont be seen
an the wire ties will be cut off when I get the other servo fitted
https://ibb.co/5KymXsH
IMG-5285
frogman3
« Reply #393 on: June 02, 2020, 08:56:35 am »
an it work ok
https://ibb.co/556Fv6V
IMG-5287
frogman3
« Reply #394 on: June 02, 2020, 09:01:52 am »
an just a tester pic of three Seakings fitted in the h -bay an to me to tight a fit so I will properly fit two in the h-bay an two out on the flight-deck but will see on that but that's as far as I've got on this build bye for now  :-))
chris
https://ibb.co/r47TmLG
IMG-5289
« Reply #395 on: June 02, 2020, 05:31:41 pm »
( Linked photos embedded into posts - Admin )   :-))
frogman3
« Reply #396 on: June 02, 2020, 06:05:51 pm »
OH MANY THANKS Martin its nice to see the pics cheers for doin this wish I could but my pc is  just not up to the job as I live in a very slow megabyte area  :-))
all best chris
« Reply #397 on: June 02, 2020, 08:50:09 pm »
No problem, we're loving your build.   :-))
frogman3
« Reply #398 on: June 02, 2020, 10:27:34 pm »
OH THANK YOU Martin  :-)) glad you likein the build i'll post more links when Ive built some more as this is gonna be a long build cheers all best to you
stay safe
chris
RST
« Reply #399 on: June 02, 2020, 10:44:07 pm »
I posted some instructions earlier in your build how to get pics showing on the forum from your hosting account.  It's just a tad different from what I thought was "normal" but once the first is done as I showed, just a copy and paste job.  If you can upload to imbb or whatever then it's no stress on mayhem account or your computer, actually it's better you have your own account as you have more control and it takes the heat off here as a forum rather then a pic hosting site which usually incurs more costs.  You can of course just post an "attachment" each post rather than a weblink?
Great build so far by the way.
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 ... 101   Go Up
Page created in 0.013 seconds with 20 queries.
