Author Topic: Chris' HMS TIGER (C20) - 1:72 SCALE  (Read 627982 times)
frogman3
Re: BOATMANS HMS TIGER C20 SCRATCHBUILD IN 1/72 SCALE
« Reply #900 on: May 04, 2021, 06:53:36 am »
MANY THANKS Bob these pics will do nicely cheers
chris :-))
« Reply #901 on: May 04, 2021, 11:21:19 pm »
First rate references :-)) :-))
« Reply #902 on: May 05, 2021, 03:09:18 am »
Just a little difficult to understand how this form of pollution could have been left un-cleaned  >>:-( on a Vessel whilst in a Commissioned role
So can only assume the image is of the Vessel in a de-Commissioned state?...
Having said this, I do not understand the source or type of contamination/polution [fluid?] over the vertical structure siding below??
frogman3
« Reply #903 on: May 05, 2021, 08:20:17 am »
HI Derek i think by the looks of it in the pics she's  bein scrapped  so you are right she is [size=78%] [/size][/size][size=78%]de-Commissioned state?.. pity but im gonna make sure my tiger does'nt get to this state lol[/size]
[/size][size=78%]chris[/size]
« Reply #904 on: May 05, 2021, 10:01:33 am »
Obviously hydraulic fluid leakage when they removed the lattice crane and other issues when not being in use i.e. awaiting to be scrapped  :embarrassed:
frogman3
« Reply #905 on: May 05, 2021, 11:52:12 am »
HI Warspite yea i think you are right as that would happen when scrapping things pity as she was a nice looking ship
chris
Rob47
« Reply #906 on: May 05, 2021, 02:13:02 pm »
Just looking at the image shows it is not in commission and the marks are from cutters torches, this/was HMS Blake being cut for scrap.
I will finish this model
frogman3
« Reply #907 on: May 06, 2021, 06:50:57 pm »
HI ALL ANOTHER SMALL UPDATE ON HER
AN now ive been fitting on her draught markinds an penant N/O.s
https://ibb.co/qkYWrcf
frogman3
« Reply #908 on: May 06, 2021, 06:54:08 pm »
an to make sure the markins are straight an upright i used a set sqaure on them
https://ibb.co/b6mpq25
frogman3
« Reply #909 on: May 06, 2021, 06:54:49 pm »
frogman3
« Reply #910 on: May 06, 2021, 06:55:57 pm »
midway markins
https://ibb.co/YWRgFBp
frogman3
« Reply #911 on: May 06, 2021, 06:57:18 pm »
an bow draught markins
https://ibb.co/wWZTwC2
frogman3
« Reply #912 on: May 06, 2021, 06:58:15 pm »
port side penant no.s
https://ibb.co/BLYDbfV
frogman3
« Reply #913 on: May 06, 2021, 07:01:24 pm »
an again on straboad side fitting  penant no.s
with a set sqaure an maskin tape to make sure they are level
https://ibb.co/jb1XBkr
frogman3
« Reply #914 on: May 06, 2021, 07:03:57 pm »
an they are on ok
https://ibb.co/BfH31VK
next up is sprayin her in hher clear gloss lauqer 4 coats to help with the water proffin
frogman3
« Reply #915 on: May 06, 2021, 07:08:12 pm »
AN NOW ive started tryin to build this big crane jib an i know its not entirely arccrute but im useing up spare brass P/E an brass angle
https://ibb.co/sKVGBm1
frogman3
« Reply #916 on: May 06, 2021, 07:13:09 pm »
an here more spare BRASS P/E  to use on the jib if i can i may get the crane workin but will see on that as more top wheight i dont really want
https://ibb.co/pWSDt1m
frogman3
« Reply #917 on: May 06, 2021, 07:14:26 pm »
here the crane jib nr built
https://ibb.co/BwdfJb2
frogman3
« Reply #918 on: May 06, 2021, 07:18:18 pm »
AN IVE HAD to put the wire rope roller wheels inside the jib as i have make it to fold up so it dont get damadged in transport
https://ibb.co/CQDc5yd
frogman3
« Reply #919 on: May 06, 2021, 07:28:01 pm »
an i fitted lights on as well
https://ibb.co/5TDZ8cP
AN NEXT I'LL try an make up the cranes mounting but i first gonna give it a bit of thought to see if i can get the crane to work
chris
« Reply #920 on: May 08, 2021, 02:45:27 pm »
Steady wins the race! That looks a fine piece of work, and I like the planning you have done for transport. One less thing to get stuck in the roof of the car/low hanging branch at the lake side/floppy jumper sleeve!!!
I know you have done the decals now so by all means ignore me, but if you spray the areas you are applying decals with gloss varnish, it prevents silvering caused by the decal backing trapping squillions of air bubbles as found in the gaps between the matt paint particles.
The Pennant numbers won't suffer as there's no backing :)
frogman3
« Reply #921 on: May 08, 2021, 06:16:19 pm »
HI ballastanksian
JUST to be sure on them decals im gonna fit some on a scrap bit of wood an the spray lauqer them an see if ok thanks for the heads up
chris
T888
« Reply #922 on: May 08, 2021, 07:59:28 pm »
She coming along Chris, will be nice to see her on the water in time  :-))
Regards David
frogman3
« Reply #923 on: May 08, 2021, 08:46:14 pm »
THANKS  Dave an im lookin forward to it but still a lot to do on her before that happens an your burke looks great an she will also look great on the water
chris
« Reply #924 on: May 09, 2021, 12:12:52 am »
mmmmmmmmmm... >>:-( difficiult to find the correct adjective for the word 'fine'........ 'fineness' would not pass the Pub Test'
....filigree is not applicable for such light & fragile brass lattice type work *&(*&*^^%%^ ...as the elements lose their fragility when assembled
Excellent result :-)) .....will need just the lightest whisper of paint :P to maintain the delicate structure :-))   [or is it delicateness?]
Page created in 0.043 seconds with 21 queries.
