Author Topic: Chris' HMS TIGER (C20) - 1:72 SCALE  (Read 612716 times)
frogman3
Re: BOATMANS HMS TIGER C20 SCRATCHBUILD IN 1/72 SCALE
« Reply #975 on: May 30, 2021, 08:19:11 pm »
frogman3
« Reply #976 on: May 30, 2021, 08:19:43 pm »
frogman3
« Reply #977 on: May 30, 2021, 08:21:06 pm »
an finally with her masts on
https://ibb.co/7jYLbqc
frogman3
« Reply #978 on: May 30, 2021, 08:21:39 pm »
frogman3
« Reply #979 on: May 30, 2021, 08:22:13 pm »
frogman3
« Reply #980 on: May 30, 2021, 08:22:49 pm »
frogman3
« Reply #981 on: May 30, 2021, 08:25:02 pm »
an fineally SWMBO gives the all good sign as she was helpin me on this
https://ibb.co/GcZP7hC :-))
chris
frogman3
« Reply #982 on: June 23, 2021, 10:36:36 pm »
HI ALL well since the water tests went well ive now been experimenting with the hull  strenght as the last thing i want to happen is the hull breakin in half due to a weak jiont when loaded with big batterys  up the pond so thats what been happening big batts in an my wife jen helped me to lift tiger loaded with big batts an im pleased to say she passed her lift test an no hull crackin an in the linkpic a shot of the batts against my hand for scale
https://ibb.co/3CzZL24
frogman3
« Reply #983 on: June 23, 2021, 10:49:43 pm »
BUT IM THINKING OF JUST USEING TWO 12 AMP HR BATTS RATHER THAN THE REALLY BIG 2O APM HR SO HERE IT IS
https://ibb.co/mvyGz5M
frogman3
« Reply #984 on: June 23, 2021, 10:56:18 pm »
AN IF NEEDED A KEEL WEIGHT TWO X HALF AN INCH BY HALF AN INCH STEEL BARS BOLTED TO THE HALF INCH KEEL AN A SHOT HERE AN SHE HAS GOT ABOUT 5 BOLT HOLES IN THE FRONT HALF AN THE SAME IN THE REAR SECTION  HULL
https://ibb.co/LzXGGRX
frogman3
« Reply #985 on: June 23, 2021, 10:58:33 pm »
CLOSE UP SHOT OF THE BOLT HOLES AN IVE FITTED IN THE HOLES PLASTIC TUBES SO THE WATER WONT GET INTO THE WOOD KEEL
https://ibb.co/Z6k6mLy
frogman3
« Reply #986 on: June 23, 2021, 11:03:27 pm »
AN HERE the shot of both steel keel wheight as she will have 4 two the front an two on the rear section hull
https://ibb.co/gWkwvbm
frogman3
« Reply #987 on: June 23, 2021, 11:06:14 pm »
close up shot of the keel wheights all drilled out an ready to take the nuts an blots to hold on the keel wheights
https://ibb.co/YTpq5cR
frogman3
« Reply #988 on: June 23, 2021, 11:09:40 pm »
an a over all shot of the front wheights just clamped on the main keel
an it wont be seen but may make a big difference
https://ibb.co/JnvPMWt :-))
chris
T888
« Reply #989 on: June 24, 2021, 05:00:44 pm »
Chris,
I assume you will put this keel on when you get to the lake ?
Regards David
frogman3
« Reply #990 on: June 24, 2021, 08:09:18 pm »
Chris,
HI Dave i will only put this keel wheight on if she needs it as this size of hull is like my nimitz carrier an i made up these keel wheights an she sailed ok an dint need it but tiger is so much different due to the fact that she has some big an fairly heavy S/S on her an for the wind to catch so this keel is a just in case job but i always like to think ahead as it easyily just bolts on so no problem an as its right under the hull an wont be seen  :-))
chris
Rob47
« Reply #991 on: July 22, 2021, 11:11:59 pm »
Chris
Thought you might like to see these.  1/96 scale built by a memebr of hMS Tiger group, built in 18 months.
I will finish this model
frogman3
« Reply #992 on: July 23, 2021, 08:37:39 am »
HI Bob oh cheers for them pics of tiger is this that admirillty model ? as it looks fantastic if mine comes up half as good as this i will be well pleased but at the moment im still stuck on my motors problem as ive got 3 motors running ok but for some reason no.3 motor was a bit stiff turning so i too all the motors out an regeased all 4 prop shafts an they turn quite easy an not stiff
an they seem ok so put it all back  in an that no. 3 motor was still stiff so  i dissconected  it from the BECC ESC  an wired it up to my 40 meg esc an usin the 40meg T/X let it on its own just run at about quarter throutle  to see if it needed to be run in  an after about 15 mins  it started to smoke so i stopped it quick an disscneoted the batt leads an took the motor out an yes it was burning out
So i oreded two more new motors an when they came i fitted a new motor in an ran all four motor on the BECC system  an i thuoght great im gettin somewhere but after a few mins that no' 3 motor was gettin very warm but yet all the other motors were hardly warm so ive taken out the motor an the motor mounts just in case its not lined up properly  SO today i'll try an find out why that no'3 motor is gettin hot an try fittin in a coolin fan on it when ive fitted new mounts in
chris
Rob47
« Reply #993 on: July 23, 2021, 09:10:10 am »
Chris
Nope just a home made model ike ours.  You know that freq has not affect on the esc as they only do what they re told by the rx.  It seems odd that one motor is burning up.  Wish I was nearer.  Did you try the seperate battery pack for the rx?
T888
« Reply #994 on: July 23, 2021, 12:43:42 pm »
Chris,
Sorry to hear your still having issues, it’s strange that motor 3 is alway the motor that’s giving issue. Keep with it , your get there. As Rob said sorry I’m not closer to help.
Regards David
frogman3
« Reply #995 on: July 23, 2021, 03:27:16 pm »
Chris
HI Bob well whoever built it can you please tell them very well done from me
an yes i cant understand why this no'3 motor is getting very hot either as thats why im gonna try changeing the angle of the motor in new mounts  an no ive not treid  a seperate batt pack yet on the R/X   im savin that if all eles fails
but will see how it goes an im gonna stick at it tell i get it right
ATB chris
frogman3
« Reply #996 on: July 23, 2021, 03:35:05 pm »
Chris,
YEA Dave that the probs is distance isnt it an yes i cant understand why that new motor is gettin hot  either while the other three are hardly warm after running a while  as ive never had this problem on all my builds but ive never had this BECC system before either but i dont think its that is the problem or all the motors would get hot crazy aint it but will stick at it untill i solve it will try fitting a cooling fan derectly onto the motor an see if that helps
ATB CHRIS
T888
« Reply #997 on: July 23, 2021, 03:54:46 pm »
Chris, what happens if you relocate the number 3 hot motor to one of the other motor location. Does the number 3 motor in the new location get or is the motor in to the number 3 location getting hot ????
[size=78%] [/size]
Regards David
frogman3
« Reply #998 on: July 23, 2021, 04:05:08 pm »
HI AGAIN Dave i'll just get me motor mounts fitted back in an then i'll give it a try out as i could take out no'4 motor an stick no'3 in its place an then try an if ok then i'll put no'4 in no3 place an see if it gets hot VERY GOOD IDEA DAVE 'll try it as ive moved this all in an out an around 5 time now an im gettin a bit frustrated i think now it i cant see the wood for the trees  angle if you see what i mean but thank you will try that
ATB Chris
T888
« Reply #999 on: July 23, 2021, 04:11:47 pm »
Chris,
I know what you mean, just take your time and make one change at a time, this will help you to see the trees not the forest. Best of luck  :-))
Regards David
