Author Topic: Chris' HMS TIGER (C20) - 1:72 SCALE  (Read 614123 times)
frogman3
Re: BOATMANS HMS TIGER C20 SCRATCHBUILD IN 1/72 SCALE
« Reply #575 on: October 01, 2020, 12:43:21 pm »
Chris I was refering to the sound unit, it looks very big, or is it the camera perspective?
HI Bob its just how big the picture has made it as its a new sound unit from components shop an its only about 3inches by 2inches so not big at all an it sounds great hope you are gettin on ok with your carrier ?
chris
frogman3
« Reply #576 on: October 01, 2020, 01:00:29 pm »
Hi Chris
Coming along , looking good. Question the water intakes look like your planning on cooling some big heat load ?
HI Dave yea the water intakes are for the ESC  FUSHION power AN it goes up to 280 amps  as i will be running four motors to drive tiger  so it  might get hot hence the water intakes but now i dont know if i will use this type of ESC as im still confused about this BEC on a ESC
an  in my R/C INSTRUCTIONS it says the R/X has a BEC CONFIGERATION fitted in it but one german gent says the R/X  FROM THE GERMAN  TRANSLATION has not got a BEC   in so at the moment im still confused about all this all the guys on here treid to help me BLESS THEM but im now waiting till my freind comes over an we can talk it through on whitch way to go
all best
chris
Rob47
« Reply #577 on: October 01, 2020, 08:27:23 pm »
chris
Ah ok, see my email, Victorious has keel cut and frame cut, waiting for new router cutter to cut the slots then assembly can start
I will finish this model
colin-d
    • my hobby
« Reply #578 on: October 02, 2020, 07:19:49 am »
all best
chris
Hi Chris,
Your receiver, definitely DOES NOT have a BEC fitted...
On the lighter side of life... it's nice of you to think I'm a German Gent...  but spent close on 20 years working for the British government, and for the past 20 years for the German government...
Still have my British passport, just been renewed  ok2
frogman3
« Reply #579 on: October 02, 2020, 11:06:25 am »
Hi Chris,
HI Colin many thanks for that bit of info i know you said it before but in the english instrucktions it says battery eliminator is installed in the receiver circutry so are they sayin this is a BEC  in the R/X  an they have made a mistake THOUGH  ?
CHEERS
chris
 PS ive built over the last 30 yrs several big warships an used them on 40 meg an hardly no probs but this is the first time ive had to use this BEC system an boy have i a headacke lol
Rob47
« Reply #580 on: October 02, 2020, 12:10:34 pm »
Chris so how did you power the rx? then, using the old style batt pack I assume,  BEC is not a new thing, been around for younks
Rob47
« Reply #581 on: October 02, 2020, 12:18:59 pm »
Chris it says in the germa instructions basically, the rx has no power and recives it from the electronic of the bec system from esc, to prove it I disconnected my esc and guess what no power to rx.
frogman3
« Reply #582 on: October 02, 2020, 07:04:18 pm »
HI Bob lookin forward to seein it bein built
chris
frogman3
« Reply #583 on: October 02, 2020, 07:07:26 pm »
Hi Chris,
HI Colin an many thanks to you as well about this BEC subject  :-))
chris
frogman3
« Reply #584 on: October 02, 2020, 07:12:49 pm »
Bob you assume right
chris
frogman3
« Reply #585 on: October 02, 2020, 07:16:09 pm »
AN THANK YOU as well Bob for solvein this BEC matter cheers now all i have got to do is find the right ESC with a f/s an a BEC
Chris
chris
T888
« Reply #586 on: October 03, 2020, 10:43:32 am »
Hi Chris,
Knock this up this morning
Just need to see how it can be moulded and how it come out of the mould
I’ll email you better photos shortly
Regards David
frogman3
« Reply #587 on: October 03, 2020, 11:42:42 am »
OK Dave cheers i'll wait to hear from you
chris :-))
frogman3
« Reply #588 on: October 15, 2020, 06:29:36 pm »
HI ALL well a bit more done on her an i have been busy fitting portholes an handrails in an on the S/S an the first pic up is one of these little blighters as they are only about 3mm an a heck of a job to hold as they ping from my tweezers an i have lost about 10 to the carpet monster but my wife jen said no way an she got down on her hands an knees an felt all over the carpet with her finger tips an found up about 8 of them well done her an ive found that quite a few did not have a predrilled hole in them so i had to try an fit them in my mini vice an re-drill them out >>:-( <*<
https://ibb.co/v31zxdF
frogman3
« Reply #589 on: October 15, 2020, 06:35:27 pm »
AN here fitting in a hand rail an them little blighters were  >>:-( beggers to thread through but after doin a few i found the rod fitted better when the hole was opened up with a neddle
https://ibb.co/Jn42xKL
frogman3
« Reply #590 on: October 15, 2020, 06:39:24 pm »
HERE the hand rail fitted to the bridges an they are apart as it was easier to work on one an then the other
https://ibb.co/sKCpRPB
frogman3
« Reply #591 on: October 15, 2020, 06:40:27 pm »
an bridges fitted together i;ll just be glad when i can spray them grey
https://ibb.co/2W4Ybxs
frogman3
« Reply #592 on: October 15, 2020, 06:45:37 pm »
front S/S where the small 3" twin gun turret will fit on when i get that far an h/r an p/h fitted an a w/t door that opens
https://ibb.co/0mBxy5L
frogman3
« Reply #593 on: October 15, 2020, 06:47:10 pm »
other side an there is only one p/h fitted here as other fitments have to go on
https://ibb.co/XzXtBmz
frogman3
« Reply #594 on: October 15, 2020, 06:50:19 pm »
NOW here the rear end of the main S/S an all the doors
https://ibb.co/8sBxt7g
frogman3
« Reply #595 on: October 15, 2020, 06:52:07 pm »
an to show why all the w/t doors here on the plans is what ive got to fit on the S/S
https://ibb.co/xGgMZqN
frogman3
« Reply #596 on: October 15, 2020, 06:53:11 pm »
DECK shot with a w/t door open
https://ibb.co/prmntTx
frogman3
« Reply #597 on: October 15, 2020, 06:55:39 pm »
port side of the S/S an port holes galore
https://ibb.co/kMcYbjJ
frogman3
« Reply #598 on: October 15, 2020, 06:56:35 pm »
frogman3
« Reply #599 on: October 15, 2020, 06:57:30 pm »
Pages: 1 ... 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 ... 101   Go Up
Page created in 0.035 seconds with 18 queries.
