Author Topic: Chris' HMS TIGER (C20) - 1:72 SCALE  (Read 108198 times)
frogman3
Re: BOATMANS HMS TIGER C20 SCRATCHBUILD IN 1/72 SCALE
« Reply #725 on: January 15, 2021, 07:29:55 am »
HI ALL
ANOTHER small update as if i try an load to many linkpics at a time my pc crashes
so the first linkpic up today is an old pic showing that i built the ventilation grills with streakes plasticard to represent the vents but now i have decided to fit in the steam unit well the plasti card bottom right lower corner will have to be cut out so i can fit some real ventilation grills in
https://ibb.co/qgND9MS
frogman3
« Reply #726 on: January 15, 2021, 07:33:00 am »
HERE IN this pic is the foremast radar motor an gearbox fitted in its place
https://ibb.co/sCgxnnq
frogman3
« Reply #727 on: January 15, 2021, 07:38:17 am »
an here ive removed the radar motor gearbox so i can cut out the vent grills an yes they are now cut out ok :-))
https://ibb.co/sjx9M4D
frogman3
« Reply #728 on: January 15, 2021, 07:40:31 am »
frogman3
« Reply #729 on: January 15, 2021, 07:47:25 am »
now in the main S/S behind the vent grills there will be two x 40mm fans one will suck air in a downtake to the small fan in the steam unit to help blow out the steam as the pipe to an up the funnell will be about 7inches long an the other fan will be to cool the radar motor gearbox when in a model show as it may be running for a few hrs
https://ibb.co/nDpM6Hb
frogman3
« Reply #730 on: January 15, 2021, 07:48:53 am »
close up shot of fans an cutouts
https://ibb.co/7XrsL0c
frogman3
« Reply #731 on: January 15, 2021, 07:55:13 am »
Now here ive done some major surgery with the ole dremel an dimond cutter so i can fit in the steam pipe which will connect up with the steam unit an go to the front funnell an this all must be dead on fit as the main s/s will be needed to lift on an off to fit in the main drive batt
https://ibb.co/Pt8S2jS
frogman3
« Reply #732 on: January 15, 2021, 07:58:21 am »
here ive been trying to bend the steam pipe into an S bend so it will go from the steam unit to the front funnel an hopefully this idea will work ok
https://ibb.co/qmJHQb2
frogman3
« Reply #733 on: January 15, 2021, 08:06:11 am »
An now comes the hard part   which im doin today ive cut out the hole so i can get my hand in the main S/S to line up an cut the STEAM pipe to size so that when i fit on the S/S its should just drop right onto the the steam units steam pipe
an if you look inside the steam unit can be seen to nr line up but its not right yet an i think this is goin to be a right pig to get right but will see how it all goes
https://ibb.co/k97xHTs
frogman3
« Reply #734 on: January 15, 2021, 08:10:17 am »
close up shot of the steam unit an where its all fitting in the hull an boy will i be glad when ive got this all mastered an built (phew) %) ok2 :-))
https://ibb.co/p45yqtm
ATB ALL chris
Rob47
« Reply #735 on: January 15, 2021, 04:10:24 pm »
looking good Chris, been busy, just the hundreds of rivets to add to the funnels now {-) {-) {-) {-) {-)
I will finish this model
frogman3
« Reply #736 on: January 15, 2021, 05:58:37 pm »
 {-) {-) {-) {-) {-) {-) {-) {-) {-) {-) HI Bob very funny  {-) an it gave me a good gigle but im no rivet counter so no way the funnels will have all their big ladders an the other main things  but then im stoppin there but a question please can you tell me what are all them ring thingys at the funnels top ? is it for the painter to hang their ropes from  to paint the funnels ?
hope you both are well
ATB Chris an jen  :-))
Rob47
« Reply #737 on: January 16, 2021, 12:52:13 pm »
Glad it made you laugh, The RN model does not have them and I did not either, but there is  a 1/72 Tiger out there were the guy has put the rivets in, but in doing so has spoilt it, becaue scale wise they must be about a foot wide, if you work it out 1/72 scale rivets heads are not a very big.
T888
« Reply #738 on: January 17, 2021, 01:44:09 pm »
Chris does this answer your question???
Regards Dave
In Build ..... USS Roosevelt DDG-80
South Coast Modeller Event organiser
frogman3
« Reply #739 on: January 17, 2021, 09:03:44 pm »
HI Dave yes it does so they are painters ring tie rings so they  can paint the funnell cheers dave for the pic very nice of you
thanks
chris
« Reply #740 on: January 17, 2021, 11:21:31 pm »
It always amazes me how complicated funnels are! I put a link to a you tube video somewhere else on MBM showing them firing up a destroyer in ww2. This had great info on funnel details and actual uses for a few items.
Tiger continues to get better and betterer  :-))
frogman3
« Reply #741 on: January 18, 2021, 09:18:24 am »
HI Cheers for your comment on tiger an yes im tryin to build this model to my best ability as this is my last big model i'll ever build
chris
frogman3
« Reply #742 on: January 18, 2021, 07:26:57 pm »
WELL HI ALL
I JUST thought id finish off the steam unit build pics today so i can move onto something eles on the ship an here is the steam unit screwed down in the hull
https://ibb.co/RT6Bh6J
Chris Preston
« Reply #743 on: January 18, 2021, 07:31:08 pm »
Excellent progress Chris. I can't wait to see her on the water.
Cheers,
Chris - in Victoria, BC
frogman3
« Reply #744 on: January 18, 2021, 07:32:43 pm »
AN IT WAS A BATTLE to get the funnel pipe to match up to the steam unit pipe as it had to be dead on if not the S/S wont fit down how it should do but i managed in the end
  https://ibb.co/6ypZDzs
frogman3
« Reply #745 on: January 18, 2021, 07:42:25 pm »
Cheers,
HI Chris i wondered where you got too an you may have to wait a few yrs to see her on the wet stuff as this build is not even halfway yet but nice to hear from you Chris
ATB Chris
frogman3
« Reply #746 on: January 18, 2021, 07:45:07 pm »
A shot here of the funnel pipe S bend an it was a heck of a job to get this right
https://ibb.co/cbCM4tv
frogman3
« Reply #747 on: January 18, 2021, 07:52:21 pm »
But i mastered it in the end as it was so awkward as i when the S/S was on the hull i could not see what's what on the pipe postioning when my hand was in the way but here its done
https://ibb.co/7JqZFH0
frogman3
« Reply #748 on: January 18, 2021, 07:54:37 pm »
a shot here of the funnel removed so i could glue in the steam pipe with out gluein the funnell as well
https://ibb.co/3Sw7B7P
frogman3
« Reply #749 on: January 18, 2021, 08:09:56 pm »
AN now for the grand finenarlly it works ok so all that work is not in vain a few steamin pics an full steam ahead
https://ibb.co/gwRymx0
Pages: 1 ... 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 ... 51   Go Up
