Its time to get a bit more up to date with my power source, I am making the leap from lead acid to li-ion power. My lead acid power pack is 36v 12ah, now I am building a new pack of 36v 50ah, more than 4 times the capacity of my well used(probably 2000 miles on it so far) lead acid pack, and 2/3 of the weight. My friend is building a 48v 50ah pack, so we had to build a spot welder for connecting the cells, as soldering apparently heats the cells too much. It took a bit of refining but now works perfectly. It is made from a large car battery, a motorbike solenoid and some jump lead cables. A couple of solid copper wire electrodes and it was time to practice on some dead nicads. The photos show progress so far, first photois the basic layout of the pack, second photo is fully welded pack with battery management system wired in. Still to encase the pack but not decided how I am going to do this yet. I have had a problem soldering plugs onto the heavy wires from the battery management system. My biggest soldering iron is not up to the job. I will get more photos on once the pack is finished.
