Author Topic: Yellow Duck  (Read 3212 times)
Skimmer Fan
Yellow Duck
« on: July 01, 2019, 09:59:01 am »
I have been asked by one of our club members if it is possible to convert the duck in the picture to remote control.
I have not got a clue where to cut it to gain access to the inside or what glues to use to seal a prop shaft in.
I would be grateful for any help and information. I can only find information on Mayhem relating to decoy ducks.
Skimmer Fan
Fred Ellis
Re: Yellow Duck
« Reply #1 on: July 01, 2019, 10:25:18 am »
H about fixing a water tight box under the duck?
Tug Fanatic
Re: Yellow Duck
« Reply #2 on: July 01, 2019, 11:00:33 am »
Is this of any help:
https://www.rcgroups.com/forums/showthread.php?1161019-R-C-Duck
If you follow the method from post 26 on you don't cut the top of the duck & you don't need to glue an unknown plastic.
If you just fix a sealed box (IP65?)  to the bottom of the duck remember that a 2.4Ghz aerial needs to be above water level.
TheLongBuild
  • Build em, and play hard..
Re: Yellow Duck
« Reply #3 on: July 01, 2019, 01:11:22 pm »
Totally quackers.. %)
Re: Yellow Duck
« Reply #4 on: July 01, 2019, 04:20:06 pm »
The rubber ducky duck should have the same problems and solutions as the decoy, just a different colour.
Playmobil (I think) did a pirate ship with the underwater box arrangement which is reported to have worked OK.  Mostly a matter of keeping the water out of the box while being able to have access and ensuring that the aerial is above the water surface.
Depending on the plastic used, the much reviled hot glue gun glue could do a good job, forming an actual weld.  A trial on the underside, out of sight, would be advisable.
klz
Re: Yellow Duck
« Reply #5 on: July 01, 2019, 08:49:13 pm »
I coverted this decoy https://www.facebook.com/146538089240896/photos/pcb.166215227273182/166215027273202/?type=3&theater followed the wing line with a sharp knife to get access drilled an hole for the propshaft and rudder left the decoy weight inplace then hot glued it all in, MTroniks m400 motor on 7.2 and it works took about 2 hours.  I would say the yellow duck would be the same you would just need to ballast it I had that problem solved as the decoy came with its own ballast.
big_bri
Re: Yellow Duck
« Reply #6 on: July 01, 2019, 09:23:40 pm »
This is how I did mine, pretty simple really.
It will need a bit of ballast towards the rear to stop it nose diving. :-))
I glued plasticard to the bottom to make it more rigid before installing the propshaft and rudder.
Brian
RST
Re: Yellow Duck
« Reply #7 on: July 01, 2019, 10:01:54 pm »
Couldn't quite believe how many folk did RC ducks till I saw this and did. A quack Google search. So many builds out there!
Tug Fanatic
Re: Yellow Duck
« Reply #8 on: July 02, 2019, 07:16:51 am »
Klz & big_bri
I understand some of the decoys are made of Polypropelene which is very difficult to glue anything to. I couldn't even guess about the yellow duck.
What adhesives are you using & trust?
Skimmer Fan
Re: Yellow Duck
« Reply #9 on: July 02, 2019, 08:26:46 am »
Big_Bri
Thanks for the pictures I have printed your post off and will give it to our club member. Do you remember what glue you used to seal the rudder post and prop shaft in with.
Thanks to all for your advice
Skimmer Fan
klz
Re: Yellow Duck
« Reply #10 on: July 02, 2019, 08:50:20 am »
Hi Tug Fanatic, I glued everything in with hot glue, Servo, Motor mount, Prop and Rudder I will try and take a a few photos.  The only thing I will say is when you glue the prop in don't have your hand under the hole it went through, I was holding the prop in line then glued the hot glue ran straight through and was burning me I refused to let go trying to keep the prop in line but WoW I suffered for weeks afterwards.
Tug Fanatic
Re: Yellow Duck
« Reply #11 on: July 02, 2019, 09:19:52 am »
Skimmer Fan
I know that it is more work but if you can make the head turn it adds an enormous amount. Lots of the internet ducks have them. You might care to watch this:
 https://www.youtube.com/watch?v=ZX7Rc8lctUY
Klz
Thank you. Have you remembered that Hot Glue becomes very brittle when cold? Probably doesn't matter in this case.
Taranis
  • Balne Moor MBC
Re: Yellow Duck
« Reply #12 on: July 02, 2019, 10:04:15 am »
That is one very clever man  :-))  just needs a sound unit  {-)
ANDY
Plastic - RIP
  • Inactive
  • Bobbing Along!
Re: Yellow Duck
« Reply #13 on: July 02, 2019, 10:05:18 am »
I did one with the Playmobil unit - works ok - gets through batteries fairly quickly.
Tug Fanatic
Re: Yellow Duck
« Reply #14 on: July 02, 2019, 10:58:38 am »
A 14in duck decoy is available for £4.08 delivered.
https://www.ebay.co.uk/itm/Outdoors-Life-Size-Floating-Duck-Decoys-Fishing-Hunting-Male-Decoy-2-Colors/302111113182?hash=item465739bfde:m:mcqa6wWlRoRbBPC_v55soIw
Giant yellow ducks are more expensive! £14 delivered but as this included UK postage in a big box I guess that they might be cheaper locally:
https://www.amazon.co.uk/Tobar-5038728038253-Giant-Duck-Toy/dp/B000H6W47Y/ref=sr_1_9?keywords=toy+duck&qid=1562060565&s=gateway&sr=8-9
Don't forget the 5 ducklings to tow £93 for 5 delivered:
https://www.ebay.co.uk/itm/5x-Floating-Duck-Ducklings-Fish-Pond-Ornament-Plastic-Decoy-Mallard-Lifesize/312222050851?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D1%26asc%3D20140122125356%26meid%3D41668845d039407db448d2ced40cb48b%26pid%3D100005%26rk%3D1%26rkt%3D12%26sd%3D283117071680%26itm%3D312222050851&_trksid=p2047675.c100005.m1851
A swan £10.75 delivered:
https://www.ebay.co.uk/itm/1Pc-Plastic-Floating-Swan-Decoy-for-Hunting-Fishing-Garden-Scarer-Scarecrow/202693908295?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D1%26asc%3D20140122125356%26meid%3Dd4226ef072f342a99fa9849dbc4e43db%26pid%3D100005%26rk%3D3%26rkt%3D12%26sd%3D302819094134%26itm%3D202693908295&_trksid=p2047675.c100005.m1851
An alligator head for £15.39 delivered sounds like fun:
https://www.ebay.co.uk/itm/13-Floating-Alligator-Gator-Head-Artificial-Foam-Decoy-For-pond-water-pool-New/223559676174?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D1%26asc%3D20140122125356%26meid%3Ddf7c5e0d2529425192530cf035c8d1ad%26pid%3D100005%26rk%3D1%26rkt%3D4%26sd%3D273062587220%26itm%3D223559676174&_trksid=p2047675.c100005.m1851
or how about a Hippo for £14.99? (Looks like a small pusher tug to me!)
https://www.ebay.co.uk/itm/Floating-Hippo-Head-Garden-Pond-Animal-Ornament/362665844859?_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D2%26asc%3D20160323102634%26meid%3D07f3f4316f0d4a80ad0f6bbf3867eb8c%26pid%3D100623%26rk%3D5%26rkt%3D6%26sd%3D223559676174%26itm%3D362665844859&_trksid=p2047675.c100623.m-1
Sounds great for a group sail.  :-)) :} :-))
big_bri
Re: Yellow Duck
« Reply #15 on: July 02, 2019, 05:35:09 pm »
Big_Bri
I used epoxy for the rudder and shaft tubes and then reinforced around it with some P38 just in case there was any flex in the plastic, its still solid after 3 years.
Brian
