Hi all,
I see you are discussing variable speed with constant motor speed.
I have a couple of commercial items that explain things rather well.
The first is a variable pitch prop, made by Marx many moons ago. They say it can handle a 10cc glow motor, but I doubt whether the coupling they suggested would handle much above a standard 540. The pitch is controlled by a servo that allows fwd and reverse (difficult on an ic engine). It is fully ballraced up the tube, and is a well made item.
The second item is a thing I picked up many years ago and have still to find a good use for it. It is an infinitely variable gearbox, from 0 to 1 to 1, the first pic shows it next to a 380 sized motor. The ratio is adjusted on the move by turning the little gearwheel on the side.
I have never had the guts to strip it down and see how it works, I would most probably and up with a bag of leftover bits. Something like this this must have been very expensive in its day, and even more expensive now.
