Pages: [1] 2 3   Go Down
Author Topic: Tug Fiede Peba kits - the summer project  (Read 17270 times)
Moller62
« on: July 08, 2019, 09:07:13 pm »
I've always wanted to make a mini/micro rc boat. So far my builds have been limited by 'standard rc equipment and suitable kits.
Accidentally I stumped over the Peba kits available on the German hobby-lobby site. I actually bought two kits: the Mooring tug I in 1:32 and the harbour tug Fiede in 1:50.
I've always wanted to make a mini/micro rc boat. So far my builds have been limited by 'standard rc equipment and suitable kits. Accidentally I stumpled over the Peba kits available on the German hobby-lobby site. I actually bought two kits: the Mooring tug I in 1:32 and the harbour tug Feide in 1:50.
http://www.hobby-lobby-modellbau.com/onlineshop/product_info.php/language/en/info/p6325_Schlepper-FIEDE---1-50---Baukasten---38-90350.html
The webshop is not modern, and you have to make a money transfer using your bank account, but the staff is very friendly and relyable. By mistake I transferred 1 € to much. Hence this the package included a handwritten note concerning the extra euro and a 1 € coin. Both kits include 3D printed hulls in very good quality. The kits include 'everything' except paint, glue and rc equipment. The only disappointment was the motor supplied with the Fiede kit. The motor is a standard no-name 130 sized motor where as the motor in the mooring tug kit seems to be of good quality.]http://www.hobby-lobby-modellbau.com/onlineshop/product_info.php/info/p6325_Tug-FIEDE---1-50---Kit---38-90355.html[/url]
Both kits has 3D printed hulls in very good quality.
Content of the 'Fiede box', some parts has been sprayed with primer.
Moller62
Re: Tug Fiede Peba kits - the summer project
« Reply #1 on: July 08, 2019, 09:08:45 pm »
A main concern regarding micro models has been the needed rc gear. You can easily source micro rx units using google, but finding corresponding transmitters seems like a mystery when you are a newbie like me in this area of modelboating.
To be on the safe side I found another German website offering:
'Complete set BASIC PLUS, 2.4 GHz for 1:87 trucks'. This set has a rx/tx with esc meant to fit a small 1:87 truck. I asume it will also fit in the tug Fiede.
https://www.sol-expert-group.de/1zu87modellbau/Komplettsets-fuer-1-87-Modelle/Komplettsets-fuer-1-87-LKW-2-4-GH/Komplettset-BASIC-PLUS-2-4-GHz-fuer-1-87-LKW::871.html
Moller62
« Reply #2 on: July 08, 2019, 09:10:21 pm »
The driveline
Moller62
« Reply #3 on: July 08, 2019, 09:11:45 pm »
Driveline assembly
Moller62
« Reply #4 on: July 08, 2019, 09:12:22 pm »
Railings
SJG001
« Reply #5 on: July 09, 2019, 07:46:56 am »
Nice - Have my eye on the "Tug HEIN" - just waiting for it to come in stock.
Taranis
  • Balne Moor MBC
« Reply #6 on: July 09, 2019, 11:56:40 am »
Thanks for sharing these kits  :-)
ANDY
Tug Fanatic
« Reply #7 on: July 09, 2019, 12:08:31 pm »
The link in poet 1 doesn't work for me. Try this one:
This is small. Watching
Moller62
« Reply #8 on: July 14, 2019, 01:00:04 pm »
Thx. for correcting the link, I dont know what went wrong. Hope the next one's are better. With regards to the HEIN tug it appears to be available for orders as of now. I actually ordered one myself although 3 tugs in a row has a very low WAF factor. Seems like an interesting kit that might call for a V-tail mixer.
http://www.hobby-lobby-modellbau.com/onlineshop/product_info.php/language/en/info/p6326_Schlepper-HEIN---1-50---Baukasten---38-90355.html
Moller62
« Reply #9 on: July 14, 2019, 01:02:29 pm »
The sterntube
The sterntube ø3mm is a tight fit in the tunnel in the  printed hull.
However a tight fit is of course to be preferred for a loose fit.
The tunnel had to be expanded with a 3 mm drill.
Moller62
« Reply #10 on: July 14, 2019, 01:03:48 pm »
As stated before the motor is a noname 130 size motor.
[/size]The rpm of this motor could be anything from 5000 to 18000 rpm. [/color]
[/size]Your guess is as good as mine.[/color]
Moller62
Moller62
« Reply #12 on: July 14, 2019, 01:07:06 pm »
This 130 motor is rated at 6v 3000 rpm which should be suitable.
Moller62
« Reply #13 on: July 14, 2019, 01:08:48 pm »
The kit also come with a small steering servo with a standard Futaba plug. The 'rc kit Basic Plus' that I aquired, comes with an even smaller servo, that has a plug that fits with the supplied micro rx. I expect to use the Basic Plus servo - 'Rohs'.
Moller62
« Reply #14 on: July 14, 2019, 01:11:54 pm »
Temporary mounting of the steering cabin with railings and ladder.
Moller62
« Reply #15 on: July 17, 2019, 09:11:36 pm »
The motor connection to the drive shaft is a very tight fit, and I removed a small part of the motor support to avoid stress in the driveline.
Moller62
« Reply #16 on: July 17, 2019, 09:12:51 pm »
The propeller blades were soft soldered to the propeller bushing. There is a tiny umbraco 'bolt' fastening the propeller unit to the driveline shaft.
Moller62
« Reply #17 on: July 17, 2019, 09:15:40 pm »
The rudder shaft did not have the correct angle to 'hit the hole' in the rudder support. To fix this I made the hole for the rudder bushing a little bigger and glued the bushing while the rudder shaft was is the correct position in the rudder support.
Moller62
« Reply #18 on: July 17, 2019, 09:17:38 pm »
Paintwork in progress and the rudder alignment seems fine.
SJG001
« Reply #19 on: July 17, 2019, 09:41:04 pm »
My "Tug HEIN" is now en-route so looking forward to starting - Trip to the Sports and Model Shop Dingwall planned for the weekend - just for the essentials ;)
Quick question - what type of paints did you use.
Moller62
« Reply #20 on: July 18, 2019, 09:59:07 am »
ALL 3D printed parts was sprayed with an acrylic filler/primer from Motip.
https://www.thansen.dk/bil/olie-og-kemi/spraymaling/grundmaling/filler-primer-400-ml.-spray-acryl/n1226681274/pn1226681406/?gclsrc=aw.ds&&gclid=CjwKCAjwscDpBRBnEiwAnQ0HQP9ongcWPXhMqpAvDPK8GO8IBXeQwDimAOncA3QZhPhMzi4RdTsWTxoCx1kQAvD_BwE
After the primer I used an acrylic spray from the same company for the blue parts. The rest was brush painted with acrylic paint from Revell and LifeColor.
Good luck with Hein, hope to see some pictures.
raflaunches
  • The Penguins are coming!!!
« Reply #21 on: July 18, 2019, 10:41:15 am »
Looks like it’s to be a brilliantly finished model :-))
Edit:
Was going to ask about the propeller blades not being shaped but can now see in your last picture they have been made into aerofoil profiles. :-))
Nick B
Illegitimi non carborundum!
Tug Fanatic
« Reply #22 on: July 18, 2019, 11:12:38 am »
...............................Was going to ask about the propeller blades not being shaped but can now see in your last picture they have been made into aerofoil profiles. :-))
Have they? Look pretty straight to me just given pitch to throw the water as the prop turns. At this size does it make a difference if the blades are not aerofoil shaped or that the pitch increases the further you go from the hub? I suspect not.
I love it that they give you a kit to make the prop. That is really old school.
Enjoying the build. Looks great.  :-)) O0 :-))
raflaunches
« Reply #23 on: July 18, 2019, 11:26:14 am »
I’m in sleepy mode at the moment- it was the closest thing to say other than bent blades! :D
Nick B
Moller62
« Reply #24 on: August 01, 2019, 10:54:45 am »
First floating with motor but no rc.
Hope to do some soldering on the rx later today.
Pages: [1] 2 3   Go Up
Page created in 0.29 seconds with 17 queries.
