Pages: 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 ... 27   Go Down
Author Topic: 1/96 scale Arleigh Burke destroyer Build log  (Read 183621 times)
T888
Re: 1/96 scale Arleigh Burke destroyer Build log
« Reply #125 on: June 26, 2020, 01:02:17 pm »
Been off line for a while, during this time I have remade the vents and start to mould them.
Regards David
frogman3
« Reply #126 on: June 26, 2020, 02:22:38 pm »
HI Dave your model is comin on great an its great to see yo make your own mouldings wish i could do that but im not clever enough im afraid an im gettin on well with my tiger
ATB chris
T888
« Reply #127 on: June 26, 2020, 03:53:41 pm »
Thanks Chris, your build has come a long way and it’s looking very good. I’ve not read all the post as yet, may take a few days.
Regards David
T888
« Reply #128 on: June 27, 2020, 06:38:11 am »
Whilst we had the warm weather took the opportunity to paint he hull, just need to put on the the depth markings, pendant numbers I’ll do this once the paint has had time to harden fully.
For the Bow and stern pendant numbers I’ll be using scale-warships paint mask’s. The small stern one Will be fun!
Regards David
T888
« Reply #129 on: June 28, 2020, 12:36:07 pm »
Some small fittings made.
Regards David
« Reply #130 on: June 28, 2020, 06:44:45 pm »
Top work! I love the bandstands, they are fun to scratch build, but these look great with the effect of the dodgers well defined.
Lovely progress  :-))
T888
« Reply #131 on: June 29, 2020, 08:46:36 am »
Some more small fitting progress, I plan to have the bridge internals detailed. This is the first of the bridge consoles
Regards David
T888
« Reply #132 on: June 29, 2020, 07:49:42 pm »
Machined up out of nylon a master SCOT dome this afternoon.
Regards David
T888
« Reply #133 on: July 02, 2020, 06:46:46 am »
Cast off the Scot a domes, also put some bridge detailing in before the roof is put on. Now I’ve done this it will be time to cleanup and prepare the forward superstructure for painting.
Regards David
T888
« Reply #134 on: July 02, 2020, 11:46:19 am »
Aft deck and superstructure painted, marked the anti slip areas by using 0.5mm Micro masking tape.
Regards David
frogman3
« Reply #135 on: July 02, 2020, 10:57:52 pm »
HI DAVE really like your bridge with the lights an red battle lights thats what i fit in my ships bridges an i dont know if they still sell a weird kind of LED 3MM an by weird i mean when you wire the led up one way they show white then if you revese the currant then they show red id love some for my tiger but cant find any but your build is comin on great an its nice to see things workin great build
ATB Chris :-))
T888
« Reply #136 on: July 03, 2020, 08:59:21 am »
Thanks Chris, the lights will be switched via a eight way switch unit. The plan is to have white lights and red lights switchable in the following areas Hanger,Bridge and some superstructure areas.
Must say your Tiger is coming along, will be nice to see it on the water once she complete.
Regards David
T888
« Reply #137 on: July 03, 2020, 09:14:42 am »
Over the last few days I’ve also attempted to make a fittings kit for the Phalanx, this is what I’ve done to date.
The radar dome is made from 10mm plastic tube filled with good old Isopon, then this was machined down to a 9mm OD and rounded off the dome head.
Next was to make the sides, I did think about making the base and sides all in one peace. But decided too make the side first the make the base plate, these were made up to one base unit that could be cast in one.
The area below the radar dome is were the Gatling gun working are. This was made in four parts.
I still need the make the Gatling gun and the Amon feed rails and the base plate jacking mounts.
Regards David
« Reply #138 on: July 03, 2020, 11:04:12 am »
Very tight :-)) ... I have worked [supervised] electro-hydraulic work on these same Raytheon weapons..........Derek
T888
« Reply #139 on: July 03, 2020, 02:06:38 pm »
Thanks Derek :-)
Regards David
radiojoe
« Reply #140 on: July 03, 2020, 07:13:03 pm »
Well up to your usual standard I see Dave, fits together very nicely.  :-))
Joe.
« Reply #141 on: July 03, 2020, 10:30:47 pm »
Ooh, I like a Gatling gun  :-)  That is a nice looking kit and one that has loads of potential in the model warship market. It must be installed on numerous nation's larger warships and over a number of classes as well.
T888
« Reply #142 on: July 04, 2020, 11:23:56 am »
Thanks Joe and Ian,
Looking at how to make the Ammo feed belt at the moment, will post some pictures once there done.
Regards David
frogman3
« Reply #143 on: July 04, 2020, 01:10:44 pm »
YEA Dave im also enjoyin your build keep it comin  :-))
chris
T888
« Reply #144 on: July 04, 2020, 03:59:40 pm »
Two Phalanx made, Just need to paint them.
Regards David
T888
« Reply #145 on: July 07, 2020, 10:12:42 am »
Slow but steady, forward superstructure so far
Regards David
T888
« Reply #146 on: July 18, 2020, 09:16:44 am »
First of the two RAS fuel Bunker Pipe.
Regards David
T888
« Reply #147 on: July 18, 2020, 10:21:46 am »
Photos of parts for the second one
Regards David
frogman3
« Reply #148 on: July 18, 2020, 12:17:46 pm »
HI Dave she's comin on well should look nice on the wet stuff  :-))
chris
T888
« Reply #149 on: July 18, 2020, 01:10:42 pm »
Hi, Chris,
Thanks for your reply. I’m please with her at this time but there still massive still to do.
In the next few weeks I’ll be doing a first ballast and trim tests.
Still enjoying your build, keep up the good work
Regards David
Pages: 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 ... 27   Go Up
