Pages: 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 ... 27   Go Down
Author Topic: 1/96 scale Arleigh Burke destroyer Build log  (Read 137876 times)
T888
Re: 1/96 scale Arleigh Burke destroyer Build log
« Reply #175 on: August 01, 2020, 12:33:09 pm »
Hi Joe,
Yes this method solve several issues.
Regards David
T888
« Reply #176 on: August 01, 2020, 12:34:32 pm »
Hi Warspite,
Yes the track can be move to the side when access to the rudder servo, linkage is required.
Regards David
frogman3
« Reply #177 on: August 01, 2020, 01:24:48 pm »
HI DAVE yes i see what you mean about the hangar door but lets face it its a workin model an what youre gettin to work so far is a mircale as far as im cocerned an as its a model why not have the hangar bay door workin like i have done as its fairly simple idea an i dont mind if you want to use that idea as i like to help you as much as possible as thats what this site is about  but up to you on that
chris :-))
« Reply #178 on: August 01, 2020, 04:01:55 pm »
I love those Phalanx systems Dave! Just like the real thing but squoze small.
Secondly, you have made great progress on the helicopter moving system  :-))  It looks very neat and efficient.
As for working doors, they will lack the weight of the real things to get them to lower smoothly unless you make the lower one heavy. Maybe make it out of brass plate? I reckon using a winch to raise the doors would be similar in scope to what you are ding with the helo thing using a winch and runners but without magnets.
T888
« Reply #179 on: August 01, 2020, 05:00:33 pm »
Hi Ian
Thanks for your comments, We’re thinking on the same lines with Regarding the hanger doors.
I have been playing with 6mm x .75mm brass strips. Issues are, hinges, how to trip the door section so they fold as the real doors seem to have a central pivot so they are 50% in the hanger and the operating method.
Will have a play and see what come of it. {:-{
Regards David
T888
« Reply #180 on: August 01, 2020, 05:05:30 pm »
Chris,
Yes there is always people ready to help others on MBM.
However your method would not work on this set up as I don’t have the space.
Regards David
frogman3
« Reply #181 on: August 01, 2020, 06:19:24 pm »
OK DAVE  :-))  go with your idea then i hope it works out for you on the hangar doors
chris
« Reply #182 on: August 02, 2020, 10:15:08 am »
Was trying to figure out this problem - if it was a roller shutter it would be easier.
Could I ask how big the opening is on your hanger, each door is as you say 6 mm deep, I would assume like a Venetian blind as the bottom one is lifted it pulls it closed against the next one up and then this couple pushes up the next one that pushes up the next and so on.
T888
« Reply #183 on: August 02, 2020, 04:34:04 pm »
Hi Warspite,
The hangar door H=47mm W= 46 there is 5 1/2 sections to the door So 5 off section is 8.5mm + 1 x 4.5  (Not 6mm as post before)
Regards David
« Reply #184 on: August 02, 2020, 07:07:55 pm »
Thanks Chris,
This working function has been a real pain, I have been looking at what I’d need to do to have working hanger doors. But on these ships the door fold up in four sections, not got my head around how to make this work.
Am I right in that it is 6 doors, in the photo it looks like 3 sets of hinges ?
T888
« Reply #185 on: August 02, 2020, 07:15:50 pm »
Warspite does this help
Regards David
« Reply #186 on: August 03, 2020, 10:55:03 am »
 :-))  is see where the half door is now
T888
« Reply #187 on: August 07, 2020, 10:36:05 am »
Well it works, just fitted the PE tracks. Now I can get on with the detailing of the hangar and flight deck.
If Martin wouldn’t mind I’ll send him a short video of the helo travelling in and Out of the Hangar. If he would be so kind as to upload it the this thread. Thanks
Regards David
« Reply #188 on: August 07, 2020, 04:03:42 pm »
« Reply #189 on: August 07, 2020, 04:04:05 pm »
Does video work now?
T888
« Reply #190 on: August 07, 2020, 04:05:30 pm »
 :-)) :-)) :-)) Thanks Martin,
Gents just need to add a third runner wheel to the tractor skid to smooth the movement
Regards David
frogman3
« Reply #191 on: August 07, 2020, 08:15:37 pm »
HI Dave that is just brilliant to see the chopper traveling out an in the hangar i take my hat off to you sir just brilliant
Chris :-))
T888
« Reply #192 on: August 07, 2020, 08:37:07 pm »
Hi Chris,
Thanks, just need to finish off the helicopter and smooth out it’s movement.
Regards David
« Reply #193 on: August 08, 2020, 02:57:45 pm »
« Reply #194 on: August 08, 2020, 09:03:11 pm »
T888
Awesome  work, wish I had your patience ,will be following.... :-))
T888
« Reply #195 on: August 09, 2020, 11:02:28 am »
Thanks SteamboatPhil,
Joys of modeling %%
Regards David
T888
« Reply #196 on: August 11, 2020, 02:29:18 pm »
Some more work on hangar.
Regards David
frogman3
« Reply #197 on: August 11, 2020, 02:38:55 pm »
HI DAVE very inspirein work just love the helo goin in an out this is a premier build
chris :-))
« Reply #198 on: August 11, 2020, 03:15:06 pm »
Given that you have seen the issue and have a solution to it, that looks amazing Dave! I can envisage that performing whilst under power on the lake  :-))
For your concertina doors, if you have counterweights on arms that pull the relevant sections of door inwards then that will force the set of doors to conform to the concertina as they rise. If the cable system pulls both ways then the counterweights can be pulled down with assistance from the brass sections weight.
I would make the arms slanted backwards to improve the action of the weights.
You will need weights that don't touch when the door is folded!
T888
« Reply #199 on: August 11, 2020, 07:06:07 pm »
Thanks Chris,
Happy that I got it sorted in the end. I’ve added a third roller which has smoothed the movement out.
Now I’m  working on the doors and in side detailing.
Regards David
Pages: 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 ... 27   Go Up
Page created in 0.032 seconds with 21 queries.
