Author Topic: 1/96 scale Arleigh Burke destroyer Build log  (Read 137445 times)
frogman3
Re: 1/96 scale Arleigh Burke destroyer Build log
« Reply #250 on: November 06, 2020, 07:24:21 pm »
COR some nice work on the mast Dave this ship is goin to look a cracker
chris :-))
T888
« Reply #251 on: November 07, 2020, 03:39:01 pm »
Hi Chris,
Thanks, for your feed back,
But I run out of 0.5mm square section so have had to put working on the mast on hold until I get some more.
But did get in the post today some FO cable and LEDs so moving on to the lights above the hanger. I’ll post some pictures when I’ve done one side
Regards David
frogman3
« Reply #252 on: November 07, 2020, 08:16:19 pm »
OH good Dave look forward to seein  this
chris
T888
« Reply #253 on: November 08, 2020, 10:17:01 am »
Hi Gents,
I’ve still one more fibre to put in, I’ll post night timer photos later.
Regards David
frogman3
« Reply #254 on: November 08, 2020, 12:10:43 pm »
Very nicely done  on the F/O Dave be nice to see the flood lites lit up  :-))
chris
T888
« Reply #255 on: November 08, 2020, 03:21:57 pm »
FO fitted just need to finish off fine detail like the power cables
Regards David
frogman3
« Reply #256 on: November 08, 2020, 06:23:08 pm »
LOOK great dave it will really set the modell off if you go night sailing as its like my norfolk i have lit it up with white 3mm led's with a merlin helo on the flight deck an all rotors  goin an like yours looks great
chris :-))
T888
« Reply #257 on: November 09, 2020, 01:55:40 pm »
Thanks Chris,
Back in the late 80s was the first time used LEDs, this was on my 1/96 Ark Royal. I installed them on the flight deck runway, quarter deck, along the island and the hanger. (Approx 25 LEDs)
I did sail it at local model boat club night sailing event, It was great fun.
Regards David
frogman3
« Reply #258 on: November 09, 2020, 04:50:31 pm »
Thanks Chris,
that what i found on night sails all good fun an you can get some exsellent pics
chris
T888
« Reply #259 on: November 16, 2020, 11:56:57 am »
Worked on the support legs for the main mast over the week end.
After a few days worth of surfacing the net to understand the shape of the supports, I Based them on some actual photos of USS Roosevelt mast, that showed the mast supports are triangular (7mm at the base to 4mm at the top) So I cut from 15 thou plaster card the three sides. once the leg was built up, I filled it with resin. This was to give it strength, after this part was cleaned up and used for a master.
The base was next and also made from 15 thou card, again the finished part was used as a master.
Both parts when casted are glued together.
Regards David
T888
« Reply #260 on: November 18, 2020, 03:28:45 pm »
Main mast fitted, just need to run the Fibre optic cables and fit one mor platform.
Regards David
T888
« Reply #261 on: November 23, 2020, 09:19:13 am »
AN SPY-6 Radar panels
Regards David
T888
« Reply #262 on: November 23, 2020, 12:03:10 pm »
Panels fitted
Regards David
frogman3
« Reply #263 on: November 23, 2020, 12:13:24 pm »
LOOKS spot on Dave really nice work she is lookin the bussiness :-))
chris
T888
« Reply #264 on: November 23, 2020, 12:20:28 pm »
Thanks Chris, how’s your build coming along ?
Regards David
frogman3
« Reply #265 on: November 23, 2020, 02:06:20 pm »
SLOW Dave
chris
T888
« Reply #266 on: November 23, 2020, 03:07:48 pm »
OK,  :-))
I’m having issues with MBM / BT as I’m not getting any notifications of postings >>:-(
Regards David
midori gaoka
  • Location: On the french coast , in front of channel island
« Reply #267 on: November 23, 2020, 09:31:22 pm »
Hello,
Your model looks very real. You have made the best choice , the choice of the quality.
T888
« Reply #268 on: November 23, 2020, 10:00:08 pm »
Midori gaoka, Thank you for your feed back :-)) :-))  I’m always trying to improve my modelling skills and get as much detailing in to my builds as I can.
What’s your current build ? Is it a warship ?
Regards David
midori gaoka
« Reply #269 on: November 24, 2020, 05:03:53 am »
Hello T888,
I'm building a sandown class mine hunter at 1/96 scale. But I did not choose yet  the name.
 Actually, I post some photos on this forum.
frogman3
« Reply #270 on: November 25, 2020, 06:33:32 am »
HI Dave the reason i said the build is coming on slow is due to the wheather as i cant paint spray in my house as its a big hull so got to be sprayed in the garage an its to cold at the moment an i cant get on an fit my smoke unit yet till the plastic pipeing i need arrives nor can i carry on building the rear funnell on tiger as im still waiting for two induction fans so things are on hold so im now starting to try an build some other part of the ship till my bits turn up an your burke is lookin great very realistic an it will be nice to see her on the wet stuff  :-))
chris
frogman3
« Reply #271 on: November 25, 2020, 06:38:06 am »
AN HI  midori gaoka
 yes it would be nice to see some of your photos of your build please
chris
Rob47
« Reply #272 on: November 26, 2020, 06:42:18 pm »
Chris
Look in r&d section, sandown classis top topic
I will finish this model
T888
« Reply #273 on: November 28, 2020, 12:41:01 pm »
The USN seem to have wider companion ways. I looked at PE Royal Navy ones from Scale link, these were to narrow, so I thought I’d have ago at making them my self. If that does not work , them I still can look at SIRMAR Fittings to se if they have some.
Well after several hours and a lot of ****** >>:-( I ended up making the jigs three times for the companion stairs. I’m still not shore if they are correct.
PLEASE NOTE IM CURRENTLY UNABLE TO GET ANY NOTIFICATIONS TO POSTINGS DUE TO A BT MAIL ISSUE.
Regards David
T888
« Reply #274 on: November 30, 2020, 06:33:34 am »
FYI Im now able to receive notifications  :-)) :-)) :-)) :-))  Thanks Martin
Regards David
Page created in 0.151 seconds with 21 queries.
