Pages: 1 ... 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27   Go Down
Author Topic: 1/96 scale Arleigh Burke destroyer Build log  (Read 137450 times)
T888
Re: 1/96 scale Arleigh Burke destroyer Build log
« Reply #475 on: June 11, 2021, 09:05:52 pm »
Thanks Chris, It will not be for a few weeks yet :-)) :-))
Regards David
T888
« Reply #476 on: June 21, 2021, 07:27:44 pm »
Just finishing off the second Helo
https://www.youtube.com/watch?v=AeRZDvo6qHI
Regards David
« Reply #477 on: June 21, 2021, 08:23:26 pm »
That looks realistic David, even down to the rocking motion of the helicopter - well modelled  :-))
T888
« Reply #478 on: June 21, 2021, 09:14:10 pm »
Thanks Ray,
 I’m pleased with how both the helo turned out, this one I need to finish off the decals & wheels. Then it’s back to the list of little detailing items that never seems to get less. <:(
Regards David
« Reply #479 on: June 22, 2021, 08:16:38 am »
I need to remove the burn't out motor on mine - I used a mobile phone vibration motor that wasn't up to the task.
T888
« Reply #480 on: June 22, 2021, 09:09:57 am »
Hi Warspite,The motor Ive used for this helo was a Micro Coreless Motor, DC 4.5V 32250RPM Coreless Motor, for Model Aircraft and Electronic Toys. My  reason for using these was they were 4.5 v, which means I can power it directly from the Forge distribution board.
The Motor size is 4mm x 8mm
Regards David
frogman3
« Reply #481 on: June 22, 2021, 11:20:50 am »
HI Dave  HELO looks good but is the helo too small to get the tail rotar goin ?
chris :-))
T888
« Reply #482 on: June 22, 2021, 11:37:46 am »
Hi Chris,
I’d love to have it working , but as the tail sections is only 2 mm thick and the tail rotor head is only 4m, so even if I’d used the fishing wire method to drive it , it would have to bend 90dreg to connect with the rotor. May have worked for a time but would eventually brake and I’d have wreck the model to gain access for repair.
Regards David
frogman3
« Reply #483 on: June 22, 2021, 12:10:14 pm »
OK Dave i fully under stand had the same problem with my 1/72 lnyz chopper
 :-)) chris
T888
« Reply #484 on: June 26, 2021, 08:03:32 am »
Got up early this morning and starting to make the next small detail fitting
Regards David
T888
« Reply #485 on: June 26, 2021, 09:02:49 am »
Parts made ready for assembly
Regards David
frogman3
« Reply #486 on: June 26, 2021, 10:18:06 am »
HI Dave well you havnt said what you are buiilding ?
chris
T888
« Reply #487 on: June 26, 2021, 11:17:00 am »
Hi Chris,
These are external communication - UHF Transmit and Receive
Regards David
T888
« Reply #488 on: June 26, 2021, 11:32:52 am »
Completed units Ready to be fitted
Regards David
T888
« Reply #489 on: July 02, 2021, 10:15:06 am »
After finding a new web site for USS Roosevelt in 2020/21 it showed that the ship has had some upgrades.
One of these is the aft CIWS Phalanx has been changed to the SeaRAM, so I had ago at making a SeaRAM and will change the Phalanx over to SeaRAM
Regards David
MartinC
« Reply #490 on: July 02, 2021, 10:19:04 am »
Great work Dave.
frogman3
« Reply #491 on: July 02, 2021, 01:15:57 pm »
YEA Dave very good work on makin them searams look very realistic  :-))
chris
« Reply #492 on: July 02, 2021, 01:46:32 pm »
That does indeed look the business - upgrades to the armament, more or less in line with the real vessel, shows dedication to 'getting it right' - well done so far Dave :-))
T888
« Reply #493 on: July 02, 2021, 06:41:49 pm »
Thanks guys, :-)) :-)) :-))  I’ll post some picture once I’ve paint and fitted the unit.
Regards David
T888
« Reply #494 on: July 03, 2021, 11:49:20 am »
SeaRAM fitted.
Regards David
MartinC
« Reply #495 on: July 03, 2021, 12:04:48 pm »
That looks really cool.  I bet it is a really nifty gadget in real life.
Martin
T888
« Reply #496 on: July 03, 2021, 03:45:35 pm »
After last week spending all day trying to machine the master of the large funnel caps and using up most of my 32 dia nylon round bar. I Asked my friend John Wills (Scale Warships) if he would 3D print a master for me so I could take a mould. He said he was more than happy to help.
So today I’ve finished casting all four required and have know painted and fitted them.
Regards David
T888
« Reply #497 on: August 21, 2021, 09:36:39 pm »
Toke some time away from my other build too do some work on USS Roosevelt.
There are two RIBs on the Roosevelt so I will cast this master.
Regards David
frogman3
« Reply #498 on: August 23, 2021, 10:37:30 am »
RIB comin on nicely dave how much more is there to do on this build before you can say finto ?
chris :-))
T888
« Reply #499 on: August 23, 2021, 10:56:21 am »
Thanks Chris
Work-list
Flag lockers
RIB and supports
Bush mater guns
Chaff launchers
Hanger doors
Detailing on the hanger roof
RU Lockers
Handrails
Rigging
Final small detailing on the superstructure
Regards David
Pages: 1 ... 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27   Go Up
Page created in 0.03 seconds with 21 queries.
