Pages: 1 ... 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27   Go Down
Author Topic: 1/96 scale Arleigh Burke destroyer Build log  (Read 137449 times)
frogman3
Re: 1/96 scale Arleigh Burke destroyer Build log
« Reply #500 on: August 23, 2021, 10:58:59 am »
Thanks Chris
Work-list
Flag lockers
RIB and supports
Bush mater guns
Chaff launchers
Hanger doors
Detailing on the hanger roof
RU Lockers
Handrails
Rigging
Final small detailing on the superstructure
SO still a bit to do then Dave
chris
T888
« Reply #501 on: August 23, 2021, 11:01:29 am »
Oh yes :-))
If I don’t get the PE Stanchions by end Oct I’ll have to solder up my own.
Regards David
frogman3
« Reply #502 on: August 23, 2021, 11:07:44 am »
Oh yes :-))
WELL Dave i sent for 400 of them from fleetscale an i have yet to fit them in the future
chris
frogman3
« Reply #503 on: August 25, 2021, 11:14:35 am »
HI Again Dave soon i will be fitting in my tiger that power dristuibushion board an you said that it need a switch fitted on on or it will not work so why a switch
? as i dont intend to use it to switch it on an off so cant i just jion it up into a circut so the power board will work ? :-))
chris
T888
« Reply #504 on: August 25, 2021, 11:39:58 am »
Chris,
See the marked photos.
I use the switch to power the model on/ Off as there is no power drain throw the dust board.
Regards David
MartinC
« Reply #505 on: August 25, 2021, 11:49:03 am »
Nice neat work Dave,
Something for me to aim for.
All the best
Martin
frogman3
« Reply #506 on: August 25, 2021, 11:51:33 am »
OH I SEE Dave so that switch cotrolls the whole power board includeing the  6v ubec unit to power the R/X so as ive done away with my becc system on my motors an the power board will be from a seperate batt can i still use this 6v ubec unit to power my R/X ?
CHRIS
T888
« Reply #507 on: August 25, 2021, 11:57:29 am »
Thanks Martin :-)) :-))
Regards David
T888
« Reply #508 on: August 25, 2021, 01:45:19 pm »
Chris,
Attached is the instruction for the Dist board.
Regards David
Rob47
« Reply #509 on: August 25, 2021, 08:51:07 pm »
Chris,
dave
is that not designed only for 6 volt? as I think Chris is using 12 volts.
I will finish this model
T888
« Reply #510 on: August 25, 2021, 08:55:44 pm »
I thought Chris said 6v here is the 12v which is what I’m using
Regards David
frogman3
« Reply #511 on: August 25, 2021, 10:26:32 pm »
HI Dave yes i am usein 12v but i will fit a 12v down to 6 v voltage reducer unit to power the R/X  so no worries  :-))
chris
T888
« Reply #512 on: August 27, 2021, 05:21:03 pm »
This week I’ve been working on the two ships RIBs first one installed. The second is awaiting its cradale.
Regards David
frogman3
« Reply #513 on: August 27, 2021, 07:08:55 pm »
VERY nice work Dave i love the rib boat an the crane looks a nice bit of work your ship will be on a sortie before mine im sure lol ;D
chris  :-))
T888
« Reply #514 on: August 28, 2021, 06:19:46 am »
Thanks Chris,
Hope to get the second RIB fitted this weekend and then that’s another item ticked off the list.
Must say the green painting on Tiger turn out well  :-))
Regards David
frogman3
« Reply #515 on: August 28, 2021, 06:11:09 pm »
HI Dave its lookin good an as you say another step to the finish an yes i was pleased at how the painting is comin on on tiger an at the moment im fitting bridge lights 2mm an would you beleive it fitted 3X 2mm white leds in bothe bridges an im now just treid out the top bridge lights an only two work one of the little blighters wont go but i dont give up easy an ive now found the main live wire was broken in side the plastic core so refitted the wire an solered it again an now all three lights work ok  but theres always one isnt there
chris  :-))
« Reply #516 on: August 28, 2021, 07:03:25 pm »
Those antennae and the RIB are gorgeous!
Answering your question re progress, I am not feeling it at the moment but hope to later in the year.
Keep up the good work, regards Ian :o)
T888
« Reply #517 on: August 28, 2021, 07:10:59 pm »
Hi Ian,
Hope you get the feeling back, I know what it’s like.
Thanks for your comments, I hope my builds will help you get the modelling feeling back  :-))
Regards David
T888
« Reply #518 on: August 28, 2021, 07:12:02 pm »
Chris,
Hope to see your pic of Tiger lighted up.
Regards David
T888
« Reply #519 on: August 31, 2021, 04:04:41 pm »
Both RIBs now fitted.
Regards David
T888
« Reply #520 on: September 11, 2021, 11:29:16 am »
Well gents, at last found some time and the interest in attacking the hanger doors.
So for this TEST method,
I first made a jig so I could keep the milled section all the same. Pic 1
Next milled slots both sides and backs so the hing can be recessed. pic 2
By using some sail cloth for the hinges and glueing in the slots.
I milled slots in the end of each panels so the slid rod can be glued.Pic6
Just know have to work out how the R/C this.  %) %) %) %)
Regards David
frogman3
« Reply #521 on: September 11, 2021, 12:00:15 pm »
Chris,
HI Dave the bridge lights im still workin on today an it will be done soon but i want to make sure it looks good an not like there is a disco lights in the bridge if so i''l paint them over with clear smoke tamiya paint to dull down the lights an ive used them consoles you made me an they look quite good but when in the bridge i dont know untill its all fitted in an wired up AN YOUR HANGAR door looks very good hope you get it to work ok  :-))
chris
T888
« Reply #522 on: September 11, 2021, 08:48:00 pm »
Hi Chris,
Still mulling over how to get these doors working {:-{
Will be nice to se Tigers lighting  :-))
Regards David
MartinC
« Reply #523 on: September 11, 2021, 08:58:19 pm »
Hi Dave,
How about a linear actuator, and a bit of elastic to maintain tension across the door sections?
Nice work by the way
Martin
MartinC
« Reply #524 on: September 11, 2021, 09:11:21 pm »
Dave,
Another option, running a piece of threaded studding up the inside of one channel and attaching the top and bottom panels to it.
Martin
Pages: 1 ... 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27   Go Up
Page created in 0.039 seconds with 21 queries.
